changing nitro content bad why ? or myth ?
Tower Hobbies
Logged in as Guest
  Printable Version
giant scale engines - RTF
Seller:  race44
Details:   $2,995.00   |  4/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> changing nitro content bad why ? or myth ?
Page: [1]
Login
changing nitro content bad why ? or myth ? - 5/8/2007 11:43:08 PM
paulrich
Status: offline
Why people do not recomend using a fuel with a differnent nitro content then the one you started with ?
does this make any sense ?
Thanks for the help Paul.
       Post #: 1
RE: changing nitro content bad why ? or myth ? - 5/9/2007 2:59:39 AM
downunder
Status: offline
It's a myth. It comes from the (incorrect) idea that an ABx type piston wears in to match the liner at a certain temperature and that different nitro percents will give different temperatures so causing a mis-match between the piston and liner. Another part to this myth is that when an ABx engine starts to wear out and begin to lose compression then you go to a lower nitro fuel where it'll run cooler and so restore the fit. Call that Myth Part 2 .
In actual fact, once an engine is run in (on any fuel) then you can change fuels all over the place without any problem so long as you retune. If that myth was actually true then you would be wearing out an engine by letting it idle or even running at part throttle let alone running it rich.
(in reply to paulrich)
       Post #: 2
RE: changing nitro content bad why ? or myth ? - 5/10/2007 2:09:50 PM
Sport_Pilot
Status: offline
The temprature differance is not that much anyway, running at idle (cool) or full speed (hot), or run ups on the ground (hot), or in the air (cool), make a much larger temperature differance than the amount of nitro.
(in reply to downunder)
       Post #: 3
RE: changing nitro content bad why ? or myth ? - 5/22/2007 7:11:04 PM
iexion
Status: online
That answers my quesion to
_____________________________
Waiting...
(in reply to Sport_Pilot)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.453RCU1
