1938 Mercury - PB .33
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Everything Diesel >> 1938 Mercury - PB .33
Page: [1] 2 3   next >   >>
Login
1938 Mercury - PB .33 - 5/9/2007 2:40 AM
RocketRob
Score: 100
Last Login: 7/3/2009
Status: offline
I think I've finally decided on the right plane for this little engine - a '38 Mercury
The PB 0.33 should move it along quite nicely!
The airframe allows upright mounting with plenty of engine access. Built light - should float nicely.
Thinking 3 channel as the engine has the nicest little carb - I believe this is the smallest throttle carb currently produced.
I'm going to take my time with this build.
I purchased the Mercury model from John at FAI Model Supply
http://WWW.FAIMODELSUPPLY.com
And the beautiful little diesel engine from Peter Burford
http://www.peterburford.com.au/
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by RocketRob -- 5/25/2007 6:55 PM >
_____________________________
Space Available
Hide Signatures
       Post #: 1
RE: 1938 Mercury - PB .33 - 5/9/2007 2:50 AM
RocketRob
Score: 100
Status: offline
Have the wing and fuse pretty well framed up. Good visual progress Need to peal the ca off my fingertips
Click for fullsize
Click for fullsize
< Message edited by RocketRob -- 5/9/2007 2:52 AM >
Space Available
Hide Signatures
(in reply to RocketRob)
       Post #: 2
RE: 1938 Mercury - PB .33 - 5/9/2007 2:54 AM
RocketRob
Score: 100
Status: offline
and the engine looks about right. A little exhaust short stack exiting down the side...... May have to use the prop extension or an engine stand off but will wait till I'm a bit further along to decide dependent on initial CG mock up.
Click for fullsize
Click for fullsize
Space Available
Hide Signatures
       Post #: 3
RE: 1938 Mercury - PB .33 - 5/9/2007 3:05 AM
AMB
Score: 100
Last Login: 7/4/2009
Status: offline
nicely done great choice engine is Burfords from down under I presume looks like a diesel"rolex watch" martn
< Message edited by dieseldan -- 5/9/2007 3:09 AM >
Hide Signatures
       Post #: 4
RE: 1938 Mercury - PB .33 - 5/9/2007 3:22 AM
RocketRob
Score: 100
Status: offline
Thanks Dan,
The little instrument is a beauty!
I just gotta fly it. Can't capitalize the investment sitting in a curio
Space Available
Hide Signatures
(in reply to AMB)
       Post #: 5
RE: 1938 Mercury - PB .33 - 5/9/2007 3:40 AM
Dan Vincent
Score: 100
Status: offline
Bob,
Love those old time Mini-FF models. Adding a throttle equipped engine can only add to the enjoyment.
I keep looking at those SAM .020 models but they are only allowed to use Cox .020 engines and I can't get too thrilled about the class until they allow small diesels to compete. At one time there were some guys in Canada who were trying to legalize small diesels but never did hear if the rules for the class were changed.
I think your using a nostalgic .020 model with an RC diesel is a great idea and today's lightweight radio gear makes it all possible.
Wish I could afford one of Peter's little gems.
Hide Signatures
       Post #: 6
RE: 1938 Mercury - PB .33 - 5/9/2007 3:48 AM
AMB
Score: 100
Status: offline
When you get it done you will have to fly it with the electric guys you will blow some minds and maybe just as quiet 100 ft out..I did this with my cub and OS 10 conversion and yours is 1/3rd the size martin
Flip and go I like that
< Message edited by dieseldan -- 5/9/2007 3:50 AM >
Hide Signatures
       Post #: 7
RE: 1938 Mercury - PB .33 - 5/9/2007 8:32 AM
SGC
Score: 100
Status: offline
I think Peters PB.033 is the finest .5cc diesel ever produced , its a no compromise design useing the best materials hand built by a mastor craftsman, and even with regular use should still be a handmedown to your grand kids.
Stewart
Hide Signatures
       Post #: 8
RE: 1938 Mercury - PB .33 - 5/9/2007 8:42 AM
David Owen
Score: 100
Last Login: 5/13/2007
Status: offline
quote:
ORIGINAL: SGC
Stewart
Stewart,
Don't like to be all pedantic on this crisp forum, but Peter's little engine is a .33cc, not an .033 cu.in. (0.5cc).
regards
David
Hide Signatures
(in reply to SGC)
       Post #: 9
RE: 1938 Mercury - PB .33 - 5/9/2007 3:24 PM
j.hiner@comcast.net
Score: 100
Last Login: 6/29/2009
Status: offline
OK schoolmaster Owen. That makes the little diesel by Peter about .022 cu. in. displacement. Correct? Jack
Hide Signatures
(in reply to David Owen)
       Post #: 10
RE: 1938 Mercury - PB .33 - 5/9/2007 6:32 PM
RocketRob
Score: 100
Status: offline
Jack,
Don't make Schoolmaster Owen get his switch out
Dan,
The little oldtimers seem like a lot of fun. I've had some micro electric experience and looking forward to this one. It would be great if SAM would make this concession - but I think it will be fun anyway. I may need that throttle just to keep the wings on - perhaps a bit of carbon roving at the diehedral joints.
Stewart,
I'm hoping to pass mine to my great grand kids - Peter had quite a chuckle when I ordered an extra cylinder/piston/rod assembly for this engine. Which brings up another point. Parts availability! I'm sick of trying to find parts for discontinued diesel engines. (Anyone got a rod/piston for a John .3? ) Peter can supply any part for his engine including all the "consumables". Or you can keep it in the curio
< Message edited by RocketRob -- 5/9/2007 6:34 PM >
Space Available
Hide Signatures
(in reply to j.hiner@comcast.net)
       Post #: 11
RE: 1938 Mercury - PB .33 - 5/9/2007 11:00 PM
David Owen
Score: 100
Status: offline
quote:
ORIGINAL: j.hiner@comcast.net
That is close, Jack
cheers
David
Hide Signatures
       Post #: 12
RE: 1938 Mercury - PB .33 - 5/10/2007 4:09 AM
SGC
Score: 100
Status: offline
Ooooooooops is too , thank you David
Stewart
Hide Signatures
       Post #: 13
RE: 1938 Mercury - PB .33 - 5/10/2007 7:02 AM
johnvb-RCU
Score: 100
Status: offline
Very much looking forward to seeing your little Mercury built RR. I have had one of these half built for the last 3-4 years, and I really should extractum digitum and get it finished.
Hide Signatures
       Post #: 14
RE: 1938 Mercury - PB .33 - 5/11/2007 3:01 AM
RocketRob
Score: 100
Status: offline
Get busy John! Make some more dust!
I know how it goes though - I've sortof parked a couple myself
Got a little work in on the wing, laminated some carbon roving on the leading and trailing edge diehedral joints.
Don't want to risk folding this wing - to precious a payload.
And a photo of the prettier side of the engine.
Click for fullsize
Click for fullsize
Space Available
Hide Signatures
(in reply to johnvb-RCU)
       Post #: 15
RE: 1938 Mercury - PB .33 - 5/11/2007 12:24 PM
Hobbsy
Score: 107
Status: offline
Bob, have you run the engine to see how the carb performs and what the rpm range is. Thanks
The greatest prerequisite to intelligent tinkering is to save all the pieces. I dunno who said it.
Hide Signatures
       Post #: 16
RE: 1938 Mercury - PB .33 - 5/12/2007 3:06 AM
AMB
Score: 100
Status: offline
As I said looks like a rolex and made like one too---I know where some of my next bonus check is going martin
Hide Signatures
(in reply to SGC)
       Post #: 17
RE: 1938 Mercury - PB .33 - 5/12/2007 3:14 AM
AMB
Score: 100
Status: offline
I think I would use a fail/safe system of some sort on this one this is one you do not want risk a flyaway with martin
Hide Signatures
(in reply to Hobbsy)
       Post #: 18
RE: 1938 Mercury - PB .33 - 5/12/2007 3:42 AM
RocketRob
Score: 100
Status: offline
I've only run up with the 6x4 but getting a solid 10k running conservative.
The 6x3 should give 11k and is the prop for this plane.
I havn't thought to tack the idle but the carb seems very effective - you can drop the revs a significant audible level.
Havn't run her up enough yet on the 6x4 to increase the revs on the 6x3.
< Message edited by RocketRob -- 5/12/2007 2:50 PM >
Space Available
Hide Signatures
(in reply to AMB)
       Post #: 19
RE: 1938 Mercury - PB .33 - 5/13/2007 12:38 AM
RocketRob
Score: 100
Status: offline
Got some sheeting glued on!
Gear bent.
Motor hung - how many times on and off?
Leaving the carb off makes firewall bolts access easier.
Click for fullsize
Click for fullsize
Click for fullsize
Space Available
Hide Signatures
       Post #: 20
RE: 1938 Mercury - PB .33 - 5/13/2007 12:42 AM
RocketRob
Score: 100
Status: offline
First trip to the garden
Click for fullsize
Click for fullsize
Space Available
Hide Signatures
       Post #: 21
RE: 1938 Mercury - PB .33 - 5/13/2007 12:50 AM
AMB
Score: 100
Status: offline
WOW very very nice looks like we are in the "twilight zone time warp" martin
what year are we in??
now suffering from a guilt complex on my ARFs guess I am now shamed into recovering my ladybird by Keil craft it was given to me but just need recoverng and the PAW 033 installed and of of course rudder and elevator revsion for rc it would be a shame not to do this
< Message edited by dieseldan -- 5/13/2007 12:59 AM >
Hide Signatures
       Post #: 22
RE: 1938 Mercury - PB .33 - 5/13/2007 1:58 AM
Hobbsy
Score: 107
Status: offline
Good work RB, you'll be flyin it by Tuesday. Really looks nice.
Hide Signatures
(in reply to AMB)
       Post #: 23
RE: 1938 Mercury - PB .33 - 5/15/2007 12:30 AM
peterburford
Score: 100
Status: offline
RR,
You will have plenty of power for this 'plane, though you may need to try a 7 inch prop. with the frontal area.
On my web-site, I've recently posted photos of Bob's exquisite Waco UEC (FF) and some of his comments on flight.
Best of luck.
Peter
Hide Signatures
       Post #: 24
RE: 1938 Mercury - PB .33 - 5/15/2007 2:24 PM
RocketRob
Score: 100
Status: offline
Thank you Peter, I'll run some tests on the 7" prop once I mount the engine up again.
In the meantime I've gotta get busy on my eppanage.
Space Available
Hide Signatures
(in reply to peterburford)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.344RCU1
