92" edge hybrid question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> 92" edge hybrid question
Page: [1] 2   next >   >>
Login
92" edge hybrid question - 5/9/2007 8:27:41 AM
tiktock
Status: offline
hi ,
i'm thinking of getting the 92" edge hybrid for my DA50. will a single 5945 be ok for the aileron?
also, what is the RTF weight people are getting with the DA50.
for OMP
i also need the dimensions and the weight of the box for the 92" edge.
thanks
       Post #: 1
RE: 92" edge hybrid question - 5/9/2007 5:31:13 PM
AFSalmon
Status: offline
The box is 49" x 13" x 6" and weighs probably about 12 lbs. You will need at least 200 oz for each aileron as these are huge. We have recommended two servos of at least 100 oz each per wing however with the advent of the new super strong servos, many have built the Hybrid with only one servo per wing. Still though you will need more torque than a single 5945 for best performance. We had two Hybrids with DA 50s both at 16 1/4 and 16 1/2 lbs.
_____________________________
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to tiktock)
       Post #: 2
RE: 92" edge hybrid question - 5/9/2007 6:01:24 PM
tiktock
Status: offline
thanks mike...... i will PM you regarding purchase and shipping questions
(in reply to AFSalmon)
       Post #: 3
RE: 92" edge hybrid question - 5/14/2007 4:58:01 PM
tiktock
Status: offline
i have just ordered the big kit......... i'm really excited, i've been wanting to get it for about a year now and i've finally done it.
       Post #: 4
RE: 92" edge hybrid question - 6/4/2007 8:06:09 AM
tiktock
Status: offline
i was about to get some servos and thought i would ask....... is it better to put 2 HS 5945's or 1 HS 5955 on the aileron? if i use 1 servo...... do i need to do any mods to the wing? or could i use one of the two servo bays?
if it's 2 servos....... will i be able to do all the servo matching with my TX ( Futaba 9 CAP ).
i already have 4 5945's and 1 5955. i'm using the 5955 on the rudder and i could ether use 4 5945's on the wing and get 2 5955 for the elevators, or get 2 5955 for the wing and leave the 2 5945's on the elevator.
just a thought.........if i use 2 servos instead of 4 on the wing...... i save about 4oz's and if i don't use a choke servo then it's another 2 more.
thats a saving of about 6oz's which is not bad.
thanks
       Post #: 5
RE: 92" edge hybrid question - 6/4/2007 9:59:14 PM
AFSalmon
Status: offline
That's a popular question asked and when the Hybrid was designed we didn't have these monster torque servos. You really need minimum 200 oz torque on the ailerons so you can use two or one as long as you get the min torque. The plan shows two servo bays and to use only one, just build the servo bay in the middle of the wing. The construction is standardized so it can be applied to any wing bay. Pick the center wing bay for one servo.
Oh, and one caution: If you use one servo, remember all the loads are now on that one location versus two so even though the mega servo can handle it, you need to make sure the structure can. Make all glue joints perfect and sheet both top and bottom of that servo bay.
< Message edited by AFSalmon -- 6/4/2007 10:00:54 PM >
       Post #: 6
RE: 92" edge hybrid question - 8/28/2007 7:38:32 PM
Crash90
Status: offline
Mike. Do you recall how you ran your choke with the DA50?
       Post #: 7
RE: 92" edge hybrid question - 8/29/2007 2:18:55 AM
AFSalmon
Status: offline
Pushrod running either up or down through the cowl. If I recall it has to be angled towards the front to get the geometry right. Don't have my Hybrid anymore as it got totalled. John Drakes though is set up that way as well if I recall.
(in reply to Crash90)
       Post #: 8
RE: 92" edge hybrid question - 9/5/2007 9:00:25 AM
tiktock
Status: offline
hi mike,
i've seem to have lost the paper wing tube and need a get a new one from you. is it possible to cut it in half and send it across since the whole tube might be to long for USPS.
it has to be shipped to india.
please tell me how to make the necessary arrangements to get the paper wing tube. ( i don't need the aluminum wing tube )
on another note.......... when rounding the leading edge of the stab, should i also shape the side and back of the elevator? would it be the same for the fin and the rudder ?
thanks
       Post #: 9
RE: 92" edge hybrid question - 9/5/2007 1:10:39 PM
AFSalmon
Status: offline
Yes we can ship another wing socket. Please email OMP directly with your shipping info and I'll get a tube ready. Shaping the sides is a personal preference however most folks leave the trailing edge flat and the sides flat as well although you can round the sides if you like.
       Post #: 10
RE: 92" edge hybrid question - 9/7/2007 8:16:31 PM
tiktock
Status: offline
hi mike
i just ordered the wing socket and since i was getting this tube from you, i thought i would take the opportunity and get the new edge47" v3 kit and the hardware pack for it
thanks
       Post #: 11
RE: 92" edge hybrid question - 9/9/2007 6:45:32 PM
tiktock
Status: offline
progress so far......... i've finished the fuse and i'm going to start the wing.
mike, how much of the wing can i build without the wing socket? it will take about 2 weeks before i get the new wing socket.
in the instructions....... you need the wing socket quite early on to align the ribs, do you thing i should start without the tube?
thanks
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by tiktock -- 9/10/2007 5:49:30 PM >
       Post #: 12
RE: 92" edge hybrid question - 9/10/2007 1:23:07 AM
Crash90
Status: offline
Looks great. What are you using for power?? I am about where you are in construction. I am waiting for the header to arrive from DA so I can get the fuse cut before I sheet the front. Then it's on to the wings.
       Post #: 13
RE: 92" edge hybrid question - 9/10/2007 1:29:29 PM
AFSalmon
Status: offline
You should be able to construct almost all the wings except for some of the sheeting. Just make sure you leave access for installing the tube and all the glue joints.
       Post #: 14
RE: 92" edge hybrid question - 9/14/2007 4:58:31 AM
Crash90
Status: offline
Mike. Do you remember what cannister you used with your hybrid? I have the KS cannister with the outlet in the front. The outlet will not allow the header to fit without cutting about 2" off which I believe is a no no. Thanks.
