86" Horns
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> 86" Horns
Page: [1]
Login
86" Horns - 5/9/2007 11:10:52 AM
RCFREAK
Status: offline
Heya dudes, i just finished gluing in place the control horns for the elevators, i didnt use the little plastic square base thingos. Will this be ok?
       Post #: 1
RE: 86" Horns - 5/9/2007 3:23:18 PM
Rezagh
Status: offline
As long as you have glued it good, you should be fine
_____________________________
Quique's Aircraft Company
(in reply to RCFREAK)
       Post #: 2
RE: 86" Horns - 5/13/2007 2:24:36 PM
RCFREAK
Status: offline
Thanks mate
       Post #: 3
RE: 86" Horns - 4/1/2008 11:27:40 PM
pani
Status: offline
Hi Reza,
Further on this, is it ok to cut the covering under the square bases and use epoxy there as well?
Panos
       Post #: 4
RE: 86" Horns - 4/2/2008 12:09:31 AM
Rezagh
Status: offline
You really don't need to cut the covering, make sure to iron it down pretty good but if you'd like other than the look, it would be 100% fine to remove the covering and glue it
(in reply to pani)
       Post #: 5
RE: 86" Horns - 4/2/2008 7:47:24 AM
pani
Status: offline
Thanks Reza
(in reply to Rezagh)
       Post #: 6
RE: 86" Horns - 4/2/2008 1:10:23 PM
pani
Status: offline
Hi Reza,
Your valuable help is needed again.
Moved on to the rudder horns.
They are both identical with one nail each (when I say nail I mean the small intendention on each).
Should they both go in from the same side or one from each side of the rudder? It confused me and the pictures are not quite clear.
Thanks again for all your help
Rgds
panos
PS BTW should there be a canopy cover as well in my kit? There wasn't one in there.
< Message edited by pani -- 4/2/2008 6:39:02 PM >
(in reply to pani)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
