RE: 50cc Sukhette Build Thread, now in progress!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> WildHare R/C Support >> RE: 50cc Sukhette Build Thread, now in progress!! Page: <<   < prev  8 9 [10] 11 12 13 14 15 16 17   next >   >>
Login
RE: 50cc Sukhette Build Thread, now in progre... - 7/9/2007 5:10:03 AM
mstroh3961
Status: offline
quote:
ORIGINAL: tomriddle
In case it saves somebody from getting as frustrated as I feel at the moment...when applying the wing graphics, remember that the wings sit in recessed pockets and allow for that when placing the graphics...doh!!
Tom as a quick fix how about wrapping the words up on the fues side?
_____________________________
Regards
Mark
(in reply to tomriddle)
       Post #: 226
RE: 50cc Sukhette Build Thread, now in progre... - 7/9/2007 5:58:48 AM
tomriddle
Status: offline
Hmmm...worth a try; I'll give it a look tomorrow. Thanks, Mark.
"Life is tough;
but its tougher when you're stupid!"
(in reply to mstroh3961)
       Post #: 227
RE: 50cc Sukhette Build Thread, now in progre... - 7/9/2007 10:37:36 PM
SAL98
Status: offline
Let me see, what can I say about this new WH 50cc Sukhoi..........................WOW, WHAT A RUSH
I fianally fixed the RFI problem I was having, Ignition module was the culprit, not the cap or the lead but the actual module. I ordered one of there newer modules the chrcexl, and wala no more problems. Then on suday morning I was able to finally do the maiden.
Every thing went excellent, the motor ran great and the plane flew like it was on rails. I am a very very finicky flier. I like my planes to fly like pattern ships, very true and neutral. A well built and setup IMAC plane has these attributes and I'm happy to say so does this 50 size Sukhoi. After a few circuits getting the trims just right I went for a 45 degree up line and rolled her over, She continued on that 45 degree line for a good 2-3 seconds. Then I leveled out and pulled a long and shallow 180 degree banked turn. Very little elevator was needed. This all ment the CG was really close to perfect. Knife edge needed some mixing but I just flew the sticks, Figure I would take care of that later after the CG was a definite. But wow what rudder authority, I could fly the length of the field and pull a tight up line all while in knife edge.
Up lines, Down lines, Upwright and inverted snaps all where really close to perfect. I could not find anything to complain about. Then I tried my infamous dead stick landings. I love to stretch out my downwind legs as far and shallow as possible and then turn into final and float her all the way back. If a plane has really really light wingloading you can pull this off without touching down to soon. I was able to pull off landing that had there rollouts end at the tip of my feet.( I pick this technique up from an old 3D tape I had of jason shulman). This is a big deal when dealing with Giant scale. I have test flown planes that went deadstick and you only had so much play before you ran our of speed or space to land, But planes like this sukoi are floaters and they eliminate all the fear of a dead stick landing completely.
Im hoping to get some videos this coming sunday. But all in all I've been blessed to get exactly what I was after, an affordable and capable 50 size aerobat that excells in Imac and 3d flying. I have to thank the lord JESUS CHRIST for Tom and Whild Hare for being such a blessing to me.
< Message edited by SAL98 -- 7/9/2007 11:08:35 PM >
       Post #: 228
RE: 50cc Sukhette Build Thread, now in progre... - 7/9/2007 10:56:10 PM
marzo91
Status: offline
I have the new Sukhoi too. I agree with everything you've stated.
(in reply to SAL98)
       Post #: 229
RE: 50cc Sukhette Build Thread, now in progre... - 7/9/2007 11:36:32 PM
mstroh3961
Status: offline
Sal98 Congrats man! have you posted pictures of your install? where is your CG?
Regards
Mark
(in reply to SAL98)
       Post #: 230
RE: 50cc Sukhette Build Thread, now in progre... - 7/10/2007 12:26:33 AM
japan3d
Status: offline
Looks like you're a happy pilot. Where do you have your CG located?
quote:
ORIGINAL: SAL98
"http://www.giantscaleinjapan.com/index.html"
(in reply to SAL98)
       Post #: 231
RE: 50cc Sukhette Build Thread, now in progre... - 7/10/2007 2:07:14 AM
tomriddle
Status: offline
Gosh, I can't tell if he liked it or not...
"Life is tough;
(in reply to SAL98)
       Post #: 232
RE: 50cc Sukhette Build Thread, now in progre... - 7/10/2007 3:04:45 AM
tomriddle
Status: offline
SAL98s pix are here: http://www.rcuniverse.com/forum/m_5989467/anchors_5997526/mpage_1/key_/anchor/tm.htm#5997526
"Life is tough;
       Post #: 233
RE: 50cc Sukhette Build Thread, now in progre... - 7/10/2007 6:12:24 AM
SAL98
Status: offline
I'm sorry guys, After my initial maiden all my cg adjustments are done by flight test. I never really know where exactly the cg distance moves to. I will test fly over and over until it flys right. Usally thats when inverted flight feels close to the same as my upright flying. After the cg feel right then I will move on to thrust adjustments and knife edge mixing if nescesary.
I did mark the initial cg location on each wingtip so when I go out again possibly this week I will see how far back I went. I do know that the plane was more tail heavy than the stock settings.
       Post #: 234
RE: 50cc Sukhette Build Thread, now in progre... - 7/10/2007 6:36:09 AM
mstroh3961
Status: offline
Thanks SAL98 any info is good. I'm getting close to completion, but back out on the road I go....stupid work is interfering in my fun again.
Regards
Mark
(in reply to SAL98)
       Post #: 235
RE: 50cc Sukhette Build Thread, now in progr... - 7/10/2007 5:31:18 PM
rctom
Status: offline
Stupid work!
       Post #: 236
RE: 50cc Sukhette Build Thread, now in progr... - 7/10/2007 6:31:34 PM
mstroh3961
Status: offline
quote:
ORIGINAL: rctom
Stupid work!
Tom you said a mouthful!
Regards
Mark
(in reply to rctom)
       Post #: 237
RE: 50cc Sukhette Build Thread, now in progr... - 7/11/2007 3:58:18 AM
tomriddle
Status: offline
Tom,
Any progress with the Toc can header?
tom
"Life is tough;
(in reply to rctom)
       Post #: 238
RE: 50cc Sukhette Build Thread, now in progr... - 7/12/2007 4:29:58 AM
rctom
Status: offline
I have a new one to test, weather has been a problem.
(in
