Flyer Freq
Joined: 8/20/2002 From: Appleton, WI, USA Status: offline
The canopy is only held on with screws. I drilled the holes through the canopy and the cockpit wood. I had some Sullivan, flexible CF push rod material that I cut into 5/8" pieces. I re-drilled the holes in the cockpit to snugly fit the push rod material. I used CA to glue the CF pieces into the side rails, and Gorilla Glue to glue them into the foam/wood front deck material. This gives me a hole to screw into that will resist the screw backing out from vibration. I may add a couple more screws in the front deck, to make sure wind doesn't get under the canopy. The paint I used for the canopy is Rustoleum for plastics. I used painters tape and Tamiya pin stripe tape for masking. I got real sharp paint lines! I am tempted to put a pilot and control panel in the plane, but I think I will fight the urge. I hope this helps! Andy
_____________________________
Lose not thy airspeed, lest the ground rise up and smite thee! If you want to make God laugh, tell Him your plans
