So I was nearly killed yesterday (5/9)... (Long read)
Tower Hobbies
Logged in as Guest
  Printable Version
Walkera 53#8!! 5G6-1. Nine Eagles Kestrel 500's - RTF
Seller:  travis@rchelizone.com
Details:   $165.00   |  11/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> So I was nearly killed yesterday (5/9)... (Long read)
Page: [1]
Login
So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 12:47:57 AM
chazdraves
Status: offline
Just a warning: This is a long post!
Many of you are familiar with my buddy who has a number of large and expensive helicopters that he doesn't always know enough about. Not surprisingly, this story revolves around him.
Every Saturday for the last month or so I've been driving 30 mintues to see him and do a fair bit of flying. We take up everything from Shoguns and REX 450's to Bergen Twin Industrials and a JR Voyager GS with extended boom and 800mm carbon fiber blades. You'll notice I gave the most information on the last helicopter mentioned - perhaps it's involved in this story, eh?
For the first time since I've known him, he had time enough to drive toward my home town and meet me for a full day of flying. I still have my REX in the repair shop, but I happen to have his Venture 30CP and Nexus 30 in my garage to fly on. To supplement, he drug along a Shogun, 450SA, TREX600CF (sweet, sweet bird!), Benzin Trainer (Gas), and Voyager GS (Gas) along with one TX for each helo. We had spent from 1PM to 6PM giving each one of them a work out at a local baseball field, and it was about time for him to be leaving. It was (wait for it...) the last flight of the day, and we had decided to grab the Voyager GS and REX 600CF to leave on a good note. Both had been flying excellently all day long. We logged about 30 minutes on the REX that day (only one battery) and about 60 minutes on the Voyager (all by myself, actually).
Well, we had to relocate to the nearest ice rink (errr... grass at this point) as a softball game had formed at the diamond, but the conditions were perfect. I spooled up the Voyager and gave it just enough to get it off the ground. There wasn't a ton of room in the rink, so I was taking it slow with some nose-in and the random "bump the throttle, throw it way up there" maneuver. One of these times, however, I noticed that the helicopter seemed to stop responding... I brough it down from about 20-30ft immediately and spun it down. We spent a couple minutes investigating the control surfaces to ensure everything was working properly before I decided it must have been the wind or something. We felt it best to play it safe, but the thing had been so solid that we figured it safe to give another go. I took it a mere couple feet off the ground and everything felt real good. I knew that such a large helicopter was pretty dangerous if it got out of hand, so I kept it real close to the ground and tail in while we ensured it was working. For just a quick second, the receiver cut out again. I dropped throttle immediately and it came down rough but in tact.
At that point I told my friend it was simply too unsafe to fly. I recommended we pack it up and I passed it over the fence to him. He wasn't satisfied with that (of course) and suggested I run the 600CF dry (which I did not mind doing ) while he gave it a quick check on his side of the fence. I watched him as he fired it up and tested the control surfaces hoping to relieve myself that I must have been imagining things. I was almost convinced too as it seemed just fine (again). I moved about 8 feet from the wall to the 600 on the side away from the wall in question. I engaged the BEC only to find that it wasn't plugged in. I was fiddling with the power connector as it wouldn't quite reach when I heard him scream, "LOOK OUT!". With my hands wrapped around the 600, I dove straight over it and rolled smack into the fence. I kept my face to the fence and hands over my head as I felt the wash of the Voyager go over top of me. I picked up my head just as the Voyager smashed into the exact spot I had been sitting...
Now, I understand that this is a rare occurence, but I think it makes some strong points. Firstly: if you plan on owning a large helicopter, it is your DUTY - there is NO QUESTION - to keep it very well maintained. There should never be any of this, "Well, I haven't flow it for three years, but..." crap - PERIOD. Secondly, if something doesn't seem to be working (especially TX/RX signal) stop NOW! Kill the engine and find the safest method you can think of to test it out. By safest, I'm hinting at "engine off".
Secondly, I'd like to ask how many folks have experienced something like this? I don't mean a crash, I mean someone nearly being severly injured or killed because of a crash. After the event I told him that I never want to see something like this happen again; he said that if I plan on staying in the hobby, I should expect it someday as he's already had it happen twice in three years (with two years' inactivity inbetween, I should mention). I will not believe this is normal. Unfortunately, I believe it's a poor statement against my friend...
Now, I imagine that most of you would like to know what we belive the problem is. I do not think it was a PCM lockout. We had flown it for about one hour at that point and had drained the first receiver pack. We grabbed the second pack (a 2400mah) which was freshly-charged but hadn't been used in three years (I didn't know) to get it going again. I believe that the connectors were damaged or corroded and the vibration was causing power interruptions to the receiver. This would explain why it was so brief and would make sense given the lack of maintenance his helicopters enjoy.
On a side note: he has vowed at this point that he will scrap every electronic piece off of that bird and re-equip it with new parts, but I'll be darned if I trust his gas helicopters ever again. I think the point I'm making is: if you cannot take the time to maintain and properly repair something so large and so dangerous you do not deserve to own it.
Anyhow, I wanted to get that out there. Thanks for hearing me out, guys! I appreciate your comments/responses.
- Chaz
P.S. I know he took some pictures of it when he got home. If I can get a hold of those, I'll try and post them here.
_____________________________
"If it moves when it shouldn't use duct tape. If it doesn't move when it should use WD-40!" - firemanbill
       Post #: 1
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 1:43:51 AM
WhtBronco
Status: offline
I was nearly hit in the head my a plane 16 years ago while I was flying. A buddy of mine had lost control of his plane, back then none of us performed proper maintenance(we were invincible teens) nor did we replace aging batteries or anything else. Anyway I hear duck and as I ducked a wing tip grazed my hair and then the plane logged itself in the windshield of my 79 Bronco. We figure the plane was doing about 75-80 mph.
These models will never be perfectly safe, but proper maintenance and proper parts replacement at set intervals can help a great deal.
I replace my batteries every 2 years now and perform about an hour of maintenance on my helis after flying them. I've been flying again for 5 years now and have had 2 crashes. 1 just after getting back in and flying a plane in wind that was too heavy and just stalled and nosed in on a landing. The other I finally smacked my Raptor 50 in last weekend due to the following things: a 25mph wind gust while I was checking the blade tracking at 6'(stupid move), failure to loctite the seesaw hub mounting bolts and finally over correcting twice.
Chris
Wish I was flyin'!
(in reply to chazdraves)
       Post #: 2
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 4:40:57 AM
archiebald
Status: offline
Scary story Chaz,
I was trained as a maintenance engineer, my job now revolves mainly around process troubleshooting and customer training. This has led me to the firm philosophy of "Assumption is the mother of all ****-ups" which can also be applied nicely to heli maintenance.
As a result, my nickname down at my club has become "The Engineer". I have now been flying helis for 2 years (after a brief stint a few years ago) and I have crashed about 5 or 6 times in approx 300 flights. Some of theml think I'm a bit anal but I really don't care.
It may sound strange, but one thing I am proud of is that all my crashes have been pilot error. Not one loose bolt, worn cable, loose plug, radio glitch etc has occurred.
Unfortunately, some of my club-mates are not so strict, we have had mufflers dropping off (exciting when they go through the rotor disk in an inverted hover!!), linkages dropping off because of ball link wear, gyros dropping off because the foam wasn't changed in two years and other similar occurrences. Up to now, no one has been hurt - but I can see it coming.....one day.
(in reply to WhtBronco)
       Post #: 3
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 8:03:11 AM
credence
Status: offline
Wouldn't be the first time someone has been severely injured or killed flying a model helicopter.
It's a risk you take any time you spool up that head. But preventative maintenance can go a long way to ensuring your model is safe to fly. I check my models over before every single flight.
Hell of a story chazdraves. Good to know you got out of it unscathed .
Daniel
True Northern Hobbies, Inc.
(in reply to archiebald)
       Post #: 4
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 12:49:19 PM
chazdraves
Status: offline
Thank you. Yeah, it scared the living daylights out of me.
archiebald: Never an "oops" crash, eh? Now that's something worth boasting!
Well, I think recommending a helicopter of this size to a guy like my friend is similar to suggesting a giant-scale plane to a new flyer - it's just not a good idea. He simply cannot be bothered to maintain his helicopters and expects they perform regardless of his negligence. He may be a buddy, but what I said applies to him as much as anyone. I'm doing my darndest to ensure that he gets the point of this accident, but I don't think he can see past the dollar amount. I will make certain he keeps those larger birds grounded when I'm around. In fact, when we spooled up his Benzin Trainer for the first time that day it turns out the flybar was off a whole ruddy inch to one side and the grips that are supposed to pitch it weren't even tightened! He's got three helicopters that I trust: REX 450SA, 600CF, and a Venture 30 CP. The only reason I have faith in those is because I set them all up for him. They are dust-free and the connections have been thoroughly inspected. Of course, the 450 and 600 are also brand new, which helps my confidence
Oy!
- Chaz
(in reply to credence)
       Post #: 5
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/11/2007 7:48:08 PM
bdavison
Status: offline
Ive never had a major issue with a helicopter, but I have cheated death with an airplane.
In Denver Colorado, I was leaving the local field walking towards a bus stop shelter on the edge of the field. All of a sudden It felt like something big exploded and knocked the wind out of me. I turned around and about 3-5ft behind me was a .40 powered trainer that had obviously augered in at full throttle with ALOT of airspeed. Cause of the crash was that a nylon pushrod link came off the elevator linkage. It was a newbie that was learning to fly, and unfortunatly didnt know about those darn nylon clips. Anyway...thats another story.....
If your friend is failing to maintain his helicopters, perhaps you should assist him in learning how to properly maintain them. Helicopters can and do kill. Proper maintenance is a REQUIREMENT. Anytime you have a problem at a field with ANY piece of equipment on a helicopter, STOP FLYING IT.
Also whenever you are working/testing on ANY model airplane or helicopter, the motor should be off and disabled. NEVER EVER have a running engine in the pits. EVER!!!
Its very easy...just unplug the motor. Ive seen countless threads where some guy sent a heli flying unexpectedly while working on it because they didnt disable the motor.
Your friend needs to be educated in proper safety protocol.
There were a few major things that he ignored.
1. Possible radio interference, or glitching problem with the helicopter
2. Failure to disable the motor.
3. Working on an HOT helicopter in the pits.
Your friends comment "he's already had it happen twice in three years" speaks volumes. He is clearly irresponsible, and is a darwin award waiting to happen. Ive been flying for over 18 years, and that one isolated experience is the only scary or potentially dangerous accident Ive ever had.
Personally, if I was you, I wouldnt go flying with him again until he cleans up his act.
teamflyingcircus.com
       Post #: 6
RE: So I was nearly killed yesterday (5/9)... (Long read) - 5/12/2007 2:43:22 PM
chazdraves
Status: offline
^--- 18 years and that's it, eh? Well, let's hope I go another 17 years now with no more encounters.
I expressed to him very frankly yesterday that this kind of stuff will not fly if I'm around. The akward part of the whole thing is that he's been involved with RC Helis for about 8 years now and I've got 7 months under my belt. To top it off, he's about 35 and quite successful while I'm 21 and living in the smallest house in town with my wife. It's awful hard to get any ideas accross in that situation, but I've kinda thrown that all out the door as I have to believe that his safety problem is bigger than our differences.
When I talked to him yesterday I detailed a lengthy maintenance plan that should be completed every 2 weeks to a month in addition to extensive testing, cleaning, and inspection after every-ruddy flight. I also told him that if he intends to continue flying these helis, we need to set down for a couple hours on each one and do some very thorough testing and maintenance. I also made mention that I don't want to see anything larger than the TREX 600 in the air while I'm over. Heck, the only reason I even suggest the 600 is because it's brand new and I installed all the electronics myself and inspected all of his linkages before the first flight; plus, all the parts are brand new on the 600. I also suggested that he take the engine out of any helicopter he doesn't have time to maintain and use it as a display model. He's one of these guys that can afford to have 3 Bergens and all the rest, but he can't fly nose-in on a .30-size nitro. The fact that he can afford to replace any of them often overshadows the concern of maintenance for him, and that's what I'm up against.
You're right about him, and it's unfortunate because he's a great guy, but I'm going to be very blunt with him if he doesn't straighten up.
Regards,
- Chaz
(in reply to bdavison)
       Post #: 7
RE: So I was nearly killed yesterday (5/9)... (Long read) - 8/19/2008 9:31:22 PM
vaca69
Status: offline
Unfortunately, in Brazil, am 08/17/2008 a 5 years old child was killed by an out of control raptor helicopter. Here is the link where you can read about:
http://g1.globo.com/Noticias/Brasil/0,,MUL727351-5598,00-CRIANCA+MORRE+ATINGIDA+POR+HELICOPTERO+DE+AEROMODELISMO.html
It is in portuguese language, but it can be translated to english language. See the picture, there's blood on blades.
       Post #: 8
RE: So I was nearly killed yesterday (5/9)... (Long read) - 9/13/2008 7:01:38 AM
bloftin
Status: offline
I think you may have over reacted. Why would you feel safer around a 600 EP? If you'll consider the mass of the blades and the rotor speed of the 600, it is just as dangerous as the Voyager GS. (in terms of impact trauma) The 600 just doesn't make as much "scary" noise as the nitro does . Many of your other "complacent activities" are much more dangerous.. You just haven't fixated on them as hard... for example driving your car (probably with a phone stuck to your face), smoking or second hand smoke, taking prescription drugs, having unprotected sex, eating processed high fat fast food, driving under the influence etc....... the list goes on and on. (And I think these activities kill way more people than RC helicopters do) Consider this; you WERE focused intently on the helicopter, and your friends maintenance negligent personality flaws. And in the back of your mind (based off the detailed description you gave) you knew the probable outcome of what your friend was trying to do, and were prepared to react so quickly. Control over injury or death is an illusion, my advise don't wast your time making up guidelines and rules to prevent death, (they will only prevent you from living your life) Fly the nitro, Have FUN!!!
Now lets go crash something!!
(in reply to vaca69)
       Post #: 9
RE: So I was nearly killed yesterday (5/9)... (Long read) - 9/13/2008 9:45:06 PM
snappa
Status: offline
A few point to make here.... unless I am reading it wrong you really do need your ass kicked, to quote you "We had spent from 1PM to 6PM giving each one of them a work out at a local baseball field" and "Well, we had to relocate to the nearest ice rink (errr... grass at this point) as a softball game had formed at the diamond" did you not realise this kind of model should not be flown with the public around? and you proved it with a failure.... imagine if it was someones unsuspecting child out for a walk..... you would be going to jail dude
< Message edited by snappa -- 9/13/2008 9:55:39 PM >
(in reply to bloftin)
       Post #: 10
RE: So I was nearly killed yesterday (5/9)... (Long read) - 10/26/2008 1:30:34 PM
qldviking
Status: offline
one aspect of heli crashes that scare me, the ends of those weighted blades. I have a 3 1./2 scar on my leg from a gash caused by a heli crash over 25 ards away, it needed 17 stiches. The fool was learing to 3D his heli and ploughed it in right on the runway. I have left one club in the past because heli fools insist on flying over the runway, and not in the designated heli area. I have now witnessed 4 accidents causing injury from the same cause, the worsrt being 28 stitches in the scxalp and concussion, and in each case the injured party did not fly heli's. I am about to get in to heli's myself and I am trying to learn as much as I can before I even look at flying. I understand they they are complex mechanical machines that need a lot of tlc to keep flying safely, but too often I see the same pilot bring the same heli to the field and its still wearing last sessions oil stains etc, but the clown just fuels up, and goes flying. doesnt say much for safety. The guy who will have the pleasure (?) of teaching me will come to the field, and go over all linkages, nuts and bolts and everything else to be sure his bird is safe, and never flys over the runway. Even he says there are too many fools flying heli's..
and its these fools that will cause our respective gov'ts to look into our hobby and start laying down laws and regulatios that can only detract from our enjoyment of our great hobby
think outside the square? what square?
(in reply to snappa)
       Post #: 11
Page:   [1]
