hot bodies lightning stadium pro-r promlem thread
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Baja 5B - RTR
Seller:  lisa2803
Details:   $799.99   |  11/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> hot bodies lightning stadium pro-r promlem thread
Page: [1] 2   next >   >>
Login
hot bodies lightning stadium pro-r promlem thread - 5/14/2007 1:58:15 AM
Mx314
Status: offline
hi i was wanting to make a thread talking about problems with the lsp. I don't want an rude opinion if you dont have one. and i dont want you to say it a peice of junk. the reason im making this thread is to find out whats best for the car. and to find and fix problems with it.so please if you have one take pictures and list what motor, radio, servo, tires, ect...
< Message edited by Mx314 -- 5/14/2007 6:22:31 AM >
_____________________________
no links?
       Post #: 1
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 2:23:23 AM
NewKid
Status: offline
my problem with is it needing to be converted to 17mm hexes...i've read that the chassis has a bit of flex...and as for other problems i am unsure...i haven't built mine and ran it yet...so i'll give ya a real answer in a couple weeks
Caster Racing Team Driver 09''
Sik Wit It Racing Crew For life
(in reply to Mx314)
       Post #: 2
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 2:37:46 AM
Mx314
Status: offline
I have also seen chessie flex on the starter box. Im still breaking mine in. I have the trinity adam drake motor, 403oz steering servo, 162oz throttle, and jr Z1 pro radio. What do you have on yours?
no links?
(in reply to NewKid)
       Post #: 3
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:07:06 AM
Coopz
Status: offline
Its a long chassis, it will flex a little. I put the Pro R buggies alloy front chassis brace on the front, $12 upgrade, took a lot of the flex away. Theres also better upgrades out for the rear.
17mm conversion is pretty much a requirment, 14mm wheels are hard to find (harder than 23mm) and they do slightly redice the buggies cornering. 17mm hexs are also a lot stonger.
The tyres it comes with are not very good either, to soft and spongey.
I put a buggy stone guard on the exhaust side to protect the rather exposed pipe as well, the Pro R buggies fits straight on with some drilling.
Probably also worth upgrading the rear toe in plate, the stock one is plastic and not that strong.
The only part I break is the front body mounts, broken a couple, even with the mount filed as low as possible. But they are under $10 and take 1 minute to swap over.
Other than that its a good truggy that can easily run with the best of them.
< Message edited by Coopz -- 5/14/2007 5:10:14 AM >
HB Lightning Pro, Mach .21
HN X1 CRT Pro, Sportwerks Chaos, 30cc FS Baja
(in reply to Mx314)
       Post #: 4
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:09:32 AM
Mx314
Status: offline
What about maxamizer beedlook rims and pro-line bow-ties?
no links?
(in reply to Coopz)
       Post #: 5
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:10:52 AM
Coopz
Status: offline
Depends 100% on what your track surface is like.
(in reply to Mx314)
       Post #: 6
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:17:57 AM
Mx314
Status: offline
I haven't raced the track at speedworld, but the track seems moist and hard-soft packed dirt.
no links?
(in reply to Coopz)
       Post #: 7
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:26:51 AM
Coopz
Status: offline
Best to pay a visit and just ask what tyres people are using.
(in reply to Mx314)
       Post #: 8
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:31:27 AM
Mx314
Status: offline
I tried asking some guy nicly and he just yelled at me. He wasn't even doing any thing at the time.
no links?
(in reply to Coopz)
       Post #: 9
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:46:59 AM
MBX5T Maniac
Status: offline
Yes, there are ****s like that on this planet. Just keep asking around. It's more likely for you to run into someone helpful than an ass. It's also easy to tell who's helpful/nice, because you'll see people talking to them.
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
(in reply to Mx314)
       Post #: 10
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:47:35 AM
Mx314
Status: offline
Is the trinity adam drake .28 platnium any good?
no links?
(in reply to Mx314)
       Post #: 11
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 5:55:38 AM
MBX5T Maniac
Status: offline
Yes it is. In fact, it is equal in power to the infamous Novarossi 528XR
(in reply to Mx314)
       Post #: 12
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 6:10:03 AM
Mx314
Status: offline
I'm letting mine ittle two tanks and then driving slow for three to four tanks is that a good way to break-in the motor?
no links?
(in reply to MBX5T Maniac)
       Post #: 13
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 6:37:47 AM
badboy2
Status: offline
my problem was chassis flex and shock bodies are weak..chassis flex was resolved by BCE chassis and kingheadz brace..then the axles were replaced by KMW stub axles ,i preferred 23mm instead of 17mm coz all my trucks are 23mm compatible..
SAVAGE QUARK125/8XL,MGT W/lc32,LSP W/REX28, inferno gt,REVO,E-PEDE,MP777 SP2
(in reply to Mx314)
       Post #: 14
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 7:01:27 AM
Mx314
Status: offline
I just got done breaking in my motor, i went to pull the battery out of the reciver and the plug broke can i fix it or do i have to buy a new one?
no links?
(in reply to badboy2)
       Post #: 15
RE: hot bodies lightning stadium pro-r promlem thread - 5/14/2007 7:21:26 AM
MBX5T Maniac
Status: offline
just steal a plug off an old servo.
(in reply to Mx314)
