HeliSmith
Joined: 1/25/2007 From: Canyon Country, CA, USA Status: offline
Crashes with a TREX450, should I buy the expensive metal only to bend it? I have a Walkera 36, AR7000, Phoenix 35, JGF 450th.. All good gear, need a good frame. Every time I crash even just a tip over the blade will touch the pavement then swing around strike the boom and come to a dead stop. This twists my head assemble and destroys about half the helicopter. Does this same thing occur on a Trex 450? I am wondering if it does then the metal head is meaningless and I may as well buy the cheap version. I am not talking about if you slam it head long into a wall, I mean just a simple blade check..?, i.e. it tips and grazes the concrete and self implodes while still sitting on the **bleepin** skids. I definately want to move up to a Trex 450 but I don't know if I should spend 550 bucks for the SE V2 or just go for a 200 buck SA or what. I can't afford to loose 200 dollars in parts per crash, I am a good pilot but we all know that it's when you will crash, not if. HDX-450SE V3 versus TREX450SE V2 I have been told that the HDX-450SE V3 is better then the Trex 450SE V2 by a tech at HeliHobby in Van Nuys. I dunno if I can believe that, I mean Align is pretty much the standard right? Anyone dare to say it's at least as good as a Trex 450SE? I am looking at the Trex 450SE V2 @ 550 bucks thinking man I would be terrified to fly this thing. I have kids and stuff, I mean I could squeeze out 5 or 6 bills but it would hurt. 300 bucks for the HDX is so much better. Does anyone have any bad experiences with this one? http://www.bananahobby.com/1239.html HS
< Message edited by HeliSmith -- 5/14/2007 5:10:56 AM >
_____________________________
http://www.helismith.com
