Alan Hahn
I am not sure if you are referring to the TF ARF version or not, but if it is, I would warn you that the fuse is weaker than the original kit solid plank. The OS35S, while better than a Fox35 in smoothness, still may cause problems for the ARF nose. I would really recommend going to a smaller engine, like an FP20, 25, or LA25 or other equivalent. These have aluminum pistons and run smoother in general than a OS35S four stroking. I run my Flite Streak ARF with a Fox15BB. I know, it has a steel piston, but it is considerably smaller, than a 35 size. My Arf tips the scale at 24oz (with some weight in the front to balance it near the leading edge) and flies great on 52 foot 00.012" lines. If you don't have the Arf, then what I said doesn't apply.
