123Splat
Joined: 4/27/2007 From: Austin, TX, USA Status: offline
Douglas4, I have seen two scheems for using the GY240 for HH on the Axe CP: 1) The Heli-Max way: pull the Yaw plug from the recvr to 3-in-1, pull 3-in-1 to tail, replace subcircuit with recvr to GY240 to Tail ESC replacement (Heli-Max, of course, suggests Electri-Fly C-12) to Tail motor (there are some other important details like power to the new tail ESC, but let this suffice. I have installed this configuration, as per HeliMax instructions, and was well pleased with the results and thier effect upon my learning to actually get the Axe off the ground and back in one piece. So, obviously, this is what I suggest. 2) (modeled of an application of the GY240 on a Blade CP, I think) Unplug the recvr Yaw to 3-in-1, Plug the GT240 signal in into the recvr Yaw position, plug the GY240 signal output into the 3-in-1 Yaw line previously disconnected from the recvr. I have not seen one post on RC Universe, or RunRyder, in which Axe CP drivers are satisfied with this hook-up. Everybody who has tried id has problems that seem to have to do with the 3-in-1's gyro gain. There are warnings about, and at least one report that, this configuration can burn out the 3-in-1 (NOT THE GY240). I do not, myself, understand how the GY240 signal out (Servo Drive) line can supply enough current to actually burn out the 3-in-1, but I ain't about to try or recommend this configuration. As stated earlier, I highly recommend the HH gyro setup (Heli-Max way), with one WARNING. I got a little too frisky, went Oops-Oops, and had a somewhat hard landing (no big deal, done it a million times, right?) Some how, I managed to wack my GY240 (busted in a gazillion pieces). Don't know how it happened, how I did it (must have been a boom strike), but my 240 is now a pile of dust! It was mounted on top of the block where the tail boom is connected to the pod. Next GY240, I think, will go in the pod frame, where it is protected.
_____________________________
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
