RE: PHOENIX TUCANO .40-.51 ARF
Tower Hobbies
Logged in as Guest
  Printable Version
52% Edge 540
Seller:  Badge
Details:   $2,500.00   |  7/22/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: PHOENIX TUCANO .40-.51 ARF
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 6:47:55 AM
Gregor32
Status: offline
dlan, the cowl is a decent size it would take 4st with ease, i would go for a 70, you may need to add a little weight as it ballances perfect with a 46 2st, a 4st would mean less cutting of the cowl not more. cheers Greg
(in reply to dlan)
       Post #: 51
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 6:52:48 AM
dlan
Status: offline
Thanks for the reponse Greg. So in your opinion a FS 70 would be sufficient? How bout a 91 (nuj nuj)! Ok maybe a bit over kill.
(in reply to Gregor32)
       Post #: 52
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 7:01:31 AM
Gregor32
Status: offline
every ones opinion of what is good/ great is diferent! i have a fs70 and think that it would be a good match with the tucano but the next guy might not. i think weight would be an issue going bigger. i have a fx46 in mine with a pipe and it goes great. -greg
(in reply to dlan)
       Post #: 53
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 7:10:43 AM
dlan
Status: offline
Ok, I just looked back at your plane, that is a serious pipe! Does it provide more top end or does it come on quicker on the bottom?
Thanks again!!
       Post #: 54
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 7:19:55 AM
Gregor32
Status: offline
it is stronger from mid through to top, bottom end still ok, but i fly mainly 1/2 to full most of the time. unlimited vertical, and a beautiful sound when on song!!
(in reply to dlan)
       Post #: 55
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 7:45:38 AM
mR JoLLy
Status: offline
Oh is still running
I looked at the possibility of installing a Laser 70 but there was insufficient space between the thrust washer and the firewall. The manual specifies 100mm and the Laser is 135mm deep. I doubt many other 4 strokes would be as deep as this so it is not the show stopper.
I think that the only modification you will need to consider is lowering the tank, and maybe swapping it for a shorter design. The tank is high for a 2 stroke as spec, so it would make sense to do so. I know someone who has an "SC" 4 stroke in his and it looks fine. The cowl has plenty of width and depth for it to take most motors (except the Laser 70!)
I have mine stripped down to fit retracts in and to colour it in RAF colours (black), Lowering the tank is restricted for me so I am sticking with an Irvine 53 with a Pitts exhaust. Hoping it has sufficient punch for the extra weight I am adding
JoLLy
(in reply to dlan)
       Post #: 56
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 6:22:17 PM
georgee
Status: offline
Hi Folks,
The day before yesterday I flew for the 1st time the Ph Tucano 1.7m span.Quite honestly this was one of the easiest uneventful maiden flight I "ve ever had.Required only 2 clicks of down elevator nothing else.In fact this birdy a large trainer,easy to fly,has broad speed range from really slow to fast.The landing with flaps is easy too just mix in some down elevator to flaps.Config:Magnum 61 engine,12x8 prop,7x S3003 servo,Fut Dp149 Rx,T9Cap Tx.I recommend this plane for everyone with some low wing experience.
Georgee
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
I"m tired of airplanes.I just want one more.
(in reply to mR JoLLy)
       Post #: 57
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 7:29:47 PM
dlan
Status: offline
Hey georgee, you mention flaps. the kit I have access to here in the States from Tower Hobbies makes no mention of flaps, just alierons (2 servo) rudder and elevator.
The wingspan is 61.5" (1560mm). I wonder did you add flaps or were they standard on your ARF?
BTW - Very nice plane!!
(in reply to georgee)
       Post #: 58
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 8:17:41 PM
georgee
Status: offline
Hey Dlan,
Yes,you"ve got the smaller kit from Ph.
http://shop.lindinger.at/product_info.php?cPath=1130_1137&products_id=63552
I"m flying the larger one,with factory made flaps.
http://shop.lindinger.at/product_info.php?cPath=1130_1137&products_id=65829
Both of them are nice planes
Georgee
(in reply to dlan)
       Post #: 59
RE: PHOENIX TUCANO .40-.51 ARF - 2/12/2008 8:21:38 PM
dlan
Status: offline
Very nice - Thanks for the prompt clarification!!
       Post #: 60
RE: PHOENIX TUCANO .40-.51 ARF - 2/13/2008 5:06:15 AM
Delta3
Status: offline
The Tucano and PC 9 are very similar, needto be overpowered, I run mine with a Saito 72 FS in it, previously had a Magnum 52FS and a TT54FS. Much better with the Saito. Now flies with authority. Have left the engine inverted but fitted a remote glow driver on it because inverted motors are difficult to get at with glow drivers and this keeps fingers well out of harms way.
Great plane to own and fly looks good, sound great with a FS motor as for retracts well each to his own but it flys beautifully just theway it is
(in reply to kochj)
       Post #: 61
RE: PHOENIX TUCANO .40-.51 ARF - 2/14/2008 10:06:05 AM
crycroft
Status: offline
selling it on ebay ? did you fit the retracts your self where is it
plant 'em deep... They will grow"Sometimes I land Vertically!!!
       Post #: 62
RE: PHOENIX TUCANO .40-.51 ARF - 3/22/2008 5:13:23 AM
dlan
Status: offline
Ok, Got my ARF (PHX 40) and it's great. The construction is real nice, especially for the price.
I need advice on engines. I want to use a four-stroke. I may have a good deal on a new Saito 56.
Will this provide sufficient power? If not I may end up going with a new Mag FS70.
The plane is bigger (wingspan and wing area) than my Venus 40 which has a Mag 46 TS.
I would appreciate your guidance.
Thanks!!
< Message edited by dlan -- 3/22/2008 6:46:11 PM >
       Post #: 63
RE: PHOENIX TUCANO .40-.51 ARF - 3/27/2008 9:19:05 PM
dlan
Status: offline
Ok, well the power plant will be an OS 70 Surpass! Ebay is a great place
quote:
ORIGINAL: dlan
Thanks!!
(in reply to dlan)
