NitroModels Yak 54 3D 50 Stab Failure
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> NitroModels Yak 54 3D 50 Stab Failure
Page: [1] 2   next >   >>
Login
NitroModels Yak 54 3D 50 Stab Failure - 5/21/2007 2:04:56 AM
Wing-Ding
Status: offline
Well, I maidened the NitroModels Yak 54 3D 50 today. The first flight was uneventful and the plane handled nicely. The second flight, however, was not so uneventful. I did a four-point roll and then a nice, large loop with about 2/3 throttle on the O.S. .55AX. Then was going straight and level at near full throttle when all of a sudden, I watched in horror as I could see a control surface come loose and fall to earth.
I throttled back, brought the Yak around and unbelievably, was able to land. Upon inspection, I saw that the horizontal stabilizer had fractured on both sides of the fuse and that one of the elevator halves was missing!!
I read about problems with a weak horizontal stabilizer in other forums. So, before purchasing the Yak 54 3D 50 ARF, I called and talked to a guy at NitroModels and he assured me that the new ARF's had a reinforced horizontal stabilizer. I was a bit suspicious and even had a flying wire kit on order before I flew today. I thought that if I only flew some easy pattern stuff today that there would be no problem. Was I wrong! It is clear that the problem with the weak stab is not fixed! Can you please send me a replacement stab free of charge? My Order Number was: 177450.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Bell Electronic Technologies
www.AeroPerfect.com
       Post #: 1
RE: NitroModels Yak 54 3D 50 Stab Failure - 5/21/2007 2:54:18 AM
opjose
Status: offline
I have a Nitroplanes CMP Passion 3D which came with the weak horizontal stab problem.
The wood used on the stab cross-member was soft balsa.
My left and right stabs ripped out in flight w/o any hard moves, one week after the other.
Since I was able to get the plane back down w/o damage I uncovered the stab and replaced the soft balsa with hardwood.
I haven't had a problem since.
You may want to uncover the cross brace where the hinges go into.
See if it's hardwood/basswood or soft balsa.
If the latter, PM them for a replacement, then UNCOVER the replacement.
If it still is soft balsa, you may be forced to fix this yourself.
IMHO this is an oversight, or design flaw.
The large control surfaces should not be held into the softer balsa.
No matter how much CA you wick in, it will NOT be enough.
PM them here as well.
Build em'', fly em'', crash em'' and build more.
(in reply to Wing-Ding)
       Post #: 2
RE: NitroModels Yak 54 3D 50 Stab Failure - 5/21/2007 3:26:27 AM
Wing-Ding
Status: offline
I just uncovered it and there it was. Yep, in fact it is just soft balsa. I agree- it's definitely an oversight / design flaw to use soft wood at a high-stress point. Thanks for your suggestion. I will PM them to see if I can get them to replace the stab / elevator. I will beef up the replacement appropriately.
www.AeroPerfect.com
(in reply to opjose)
       Post #: 3
RE: NitroModels Yak 54 3D 50 Stab Failure - 5/21/2007 7:27:32 PM
opjose
Status: offline
The advertising says "re-inforced tail".
Either this area was not beefed up, or you received the older model.
       Post #: 4
RE: NitroModels Yak 54 3D 50 Stab Failure - 5/21/2007 7:33:12 PM
Wing-Ding
Status: offline
Not sure. I do have the updated color scheme which I thought indicated the new model. The tail is definitely not reinforced in any way. I PM'd them. Still waiting to hear something.
www.AeroPerfect.com
       Post #: 5
RE: NitroModels Yak 54 3D 50 Stab Failure - 5/22/2007 12:23:28 AM
nitrostaff1
Status: offline
Guys,
Yes it is true that the tail horizontal stabalizer was reinforzed but i guess the material choice was not adaquate. Problem noted!
--===www.nitroplanes.com===----
       Post #: 6
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/4/2007 5:00:18 PM
opjose
Status: offline
A quick fix for this which I would advise to anyone purchasing the plane, is simply to add additional CA hinges.
In other words you want to spread the load out a bit more.
Cut a couple of thinner CA hinge strips to make two 1/4 to 3/8 inch wide strips and insert them as well in addition to the provided hinges.
Hand drill out a small center hole to provide for better CA adhesion then cut and install the provided and the two additional hinges.
That should eliminate the minor problem.
< Message edited by opjose -- 6/4/2007 5:01:15 PM >
(in reply to nitrostaff1)
       Post #: 7
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/4/2007 5:45:11 PM
Wing-Ding
Status: offline
John from NitroStaff support said he told the factory about the weak stab problem and that it would be 4 weeks before he could send me a reinforced one. I want to get back into the air sooner than that so I opted for an identical replacement stab that I will reinforce. Since they were out of the red color, he was only able to send me the older color scheme (mostly blue).
I received it last Friday. I will uncover and reinforce with hardwood and ply. Think I'll use either robart point hinges or Dubro heavy duty hinges. I also have a flying wire kit that I plan on using.
I noticed the threads on the small-diameter machine screws that hold the control arms on don't really have enough bite and that they loosened a bit on the rudder (stripped out of the backing plate). Maybe the primary failure mode here is flutter causes by loose control horns. I plan on replacing the stock control horn hardware that includes nylon lock nuts.
www.AeroPerfect.com
       Post #: 8
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/4/2007 6:25:27 PM
opjose
Status: offline
Yeah, that would be another reason to also advise more hinges if you are using the CA ones.
       Post #: 9
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/8/2007 12:42:48 PM
Jerry Sigur
Status: offline
My elevator halves are thicker than the stab, this will cause flutter probs
at higher speeds and structual failure. I plan to build a stab to match the halves.
Cajun Black Sheep Flyers
       Post #: 10
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/8/2007 4:36:06 PM
opjose
Status: offline
Why not seal the hinges?
(in reply to Jerry Sigur)
       Post #: 11
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/8/2007 5:20:24 PM
Jerry Sigur
Status: offline
Sealing the hinge gap will help but not fix the prob. The elevator halves
should not be thicker than the stab, this causes problems.
       Post #: 12
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/8/2007 5:31:25 PM
Wing-Ding
Status: offline
I wasn't aware of that. I'll make sure they're not larger. Thanks.
www.AeroPerfect.com
       Post #: 13
RE: NitroModels Yak 54 3D 50 Stab Failure - 6/8/2007 6:42:58 PM
opjose
Status: offline
quote:
ORIGINAL: Jerry Sigur
I agree, but at the same time it is also ok ( of course not in this case ) if the elevator follows the stab airfoil shape too... for those planes equipped with airfoils instead of flat balsa.
       Post #: 14
