mxcop114
NJ, USA Status: offline
Hey Marc, I used the template in the manual and everything fit fine. Make sure you line it up with the top edge of the motor box, you can pop the top cover in when you mark it to be sure. This is the best flying out of the box plane I've owned, the only mix I have is 4% rudder to up elevator. The blind nuts will be fine, you have to cut the tri-stock a little to install them. If you want a little extra security you could install nylon lock nuts with the blind nuts. I took the option of cutting the stringers out in front of the gear so the stingers came out there, otherwise you have to cut the headers down a little. That is explained in the instructions. Your going to love the plane, good luck with it. Lee
< Message edited by mxcop114 -- 7/21/2007 7:50:17 PM >
_____________________________
Team JR Horizon Hobby
