RE: New Somenized Yak 102", Gen III
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> RE: New Somenized Yak 102", Gen III
Page: <<   < prev  1 2 3 4 [5]
Login
RE: New Somenized Yak 102", Gen III - 9/27/2007 1:46:39 PM
mxcop114
Status: offline
I replaced the canopy, cowl, and SFG washers with bonded washers.
Lee
_____________________________
Team JR
Horizon Hobby
(in reply to Camel)
       Post #: 101
RE: New Somenized Yak 102", Gen III - 2/3/2008 4:28:39 PM
pelone
Status: offline
Hello,
I started a little build threat on my blog:
http://davidlepore.blogspot.com
I planned to try the 3W-85 XI CS as engine for the Yak, but in the end I had to go with the DA-100, since we have noise restrictions at our field and I couldn't fit a proper muffler in the tunnel without having to do major modifications.
Perhaps this could be modified in the GEN 4 Yak.....
Greetings,
David
< Message edited by pelone -- 2/3/2008 4:29:33 PM >
David
(in reply to mxcop114)
       Post #: 102
RE: New Somenized Yak 102", Gen III - 2/4/2008 1:33:05 AM
octanehuffer
Status: offline
Is there any possibility of getting a DA 85 on this plane and use the cannister? How about a manual for the build like the Python.
Adam
QQ 120" Yak, QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, H9 T-Craft G-26, etc
(in reply to pelone)
       Post #: 103
RE: New Somenized Yak 102", Gen III - 2/4/2008 1:22:23 PM
pelone
Status: offline
No, the DA-85 also needs at least 70mm in diameter in case of a tuned pipe and 80mm in case of a canister. The tunnel is maximum 60mm....
< Message edited by pelone -- 2/4/2008 1:25:44 PM >
David
(in reply to octanehuffer)
       Post #: 104
RE: New Somenized Yak 102", Gen III - 2/4/2008 1:31:51 PM
octanehuffer
Status: offline
They ran one in a Python. The Python is also built for a DA 100 or equivelent.
       Post #: 105
RE: New Somenized Yak 102", Gen III - 2/4/2008 3:33:51 PM
Rezagh
Status: offline
The 102" is designed for DA100. It is not as easily balanced with DA85 as the Python! We won't be showing the 102 with DA85 but ........
Quique's Aircraft Company
       Post #: 106
RE: New Somenized Yak 102", Gen III - 2/5/2008 12:35:05 AM
octanehuffer
Status: offline
Your period button seems to have something wrong with it. Or you are hinting at something. Please PM me with a continuation. I need to order a Python or 102" soon, but if there is an alternative please let me know. thank you.
Adam
(in reply to Rezagh)
       Post #: 107
RE: New Somenized Yak 102", Gen III - 2/5/2008 3:14:21 AM
octanehuffer
Status: offline
Come on, out with it. But what? Are you going to do a DA 85 swap? Want me to do it? What are you saying!!!!!!!!!!!!!
       Post #: 108
RE: New Somenized Yak 102", Gen III - 3/2/2008 1:52:32 PM
Capiche
Status: offline
www.islandhobbies.co.uk
www.flycapiche.co.uk
       Post #: 109
RE: New Somenized Yak 102", Gen III - 3/6/2008 4:08:12 PM
husafreak
Status: offline
I am looking for the quietest possible set up for my DA 100. I already have the cans but I heard 3 blade props are quieter. Are they much quieter? Does vertical performance, like out of a hover, suffer much? And what size and manufacturer is favored? We are getting noise complaints at my club specifically targeting large gas planes flying IMAC patterns.
       Post #: 110
RE: New Somenized Yak 102", Gen III - 3/6/2008 5:14:34 PM
Rezagh
Status: offline
Eric,
What prop are you using now? Size and brand.
3 bladed such as 25x12 Mejzlik will make very quiet. However 26x12 two bladed Mejzlik with Can set up should be very quiet as well.
Pull outs will get a little weaker with 25x12 but you should still be fine. It's a totally different feel on the 3 bladed props. They are good for IMAC for sure, it will be OK with GenIII for 3D as it is not a heavy plane.
Hope this helps,
Reza
(in reply to husafreak)
       Post #: 111
RE: New Somenized Yak 102", Gen III - 3/10/2008 3:27:18 AM
husafreak
Status: offline
Sorry for the delay, I am using Mezlik 27-10 and I love that prop! I just fly for fun, about equal time spent on 3D and IMAC type flying. Thanks for your reply.
       Post #: 112
Jump to:
Google
