H9 TAYLORCRAFT STRUTS???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> H9 TAYLORCRAFT STRUTS???
Page: [1] 2   next >   >>
Login
H9 TAYLORCRAFT STRUTS??? - 5/23/2007 8:41 AM
blownalcohol
Score: 100
Last Login: 2/2/2013
Status: offline
I finally found a H9 Taylorcraft that is in excellent condition....I've been wanting one for quite a while. Only problem is it doesn't have any wing struts with it. Any of you guys happen to have some left from an aircraft that might have suffered from a re-kitting??? I understand they aren't functional, and that the original mounting was prone to failure....but I really like the way they look on the plane and feel that I can engineer a mounting system that will survive.
I would also be interested in any other components that might be available.
Thanks in advance,
Jeff
Hide Signatures
       Post #: 1
RE: H9 TAYLORCRAFT STRUTS??? - 5/24/2007 12:26 PM
aussie jason
Score: 100
Last Login: 4/27/2008
From: Gold CoastQueensland (Gold Coast Australia), AUSTRALIA
Status: offline
Hi Jeff,
I made my owm out of airo tubing from my local hobbie store and I did not bother to much with installing the kit one's. From all reports they are functional the struts. They came up very good and they stay connect to the wing at all times when travelling to the field, the only mod is the underside of the plane wear you attatch the strut too. I also used JB weild to fuse the alluminum together then some fine grit sand paper to smooth the joint before sanding then painting it, very nice job once complete.
I will post some photo's tomorrow to give you some idea, it only took a couple of day's to complete.
Regards
Jason
Hide Signatures
(in reply to blownalcohol)
       Post #: 2
RE: H9 TAYLORCRAFT STRUTS??? - 5/24/2007 5:28 PM
blownalcohol
Score: 100
Status: offline
Thanks Jason!
I'm looking forward to the pictures.
Jeff
Hide Signatures
(in reply to aussie jason)
       Post #: 3
RE: H9 TAYLORCRAFT STRUTS??? - 5/25/2007 4:26 AM
octanehuffer
Score: 100
Last Login: 5/11/2013
Status: offline
The struts are indeed functional. Never fly without them!
I too have made my own from aero alum. I flatened the end of the alum in a vise for the wing end and inserted a piece of steel in the landing gear end. Both pieces were mocked up on the plane for best fit then welded together off the plane.
Adam
_____________________________
QQ 120" Yak, QQ 86" Evolution, QQ 69" Saito 1.25, QQ 49" 32SX, QQ E-Yak, H9 T-Craft G-26, etc
Hide Signatures
       Post #: 4
RE: H9 TAYLORCRAFT STRUTS??? - 6/27/2007 1:47 AM
aussie jason
Score: 100
Status: offline
Hi Jeff,
How did the strut's come out did you get a chance to do the job.
Cheers
Jason
Hide Signatures
       Post #: 5
RE: H9 TAYLORCRAFT STRUTS??? - 7/21/2007 9:31 PM
bbrundle
Score: 100
Last Login: 5/25/2013
Status: offline
Jeff,
I looked to see if we might have an old set laying around somewhere here at Horizon (Hangar 9), but that model was discontinued so long ago, that I was unsuccessfuol at locating any old spare ones.
Just to clarify one thing on the Taylorcraft struts we included on our Hangar 9 model. These struts are not functional and are only used on our model to capture the look of the full scale. The wing is plenty strong enough to fly without them and was tested quite extensively without the struts attached. So fabricate the struts as you see fit to achieve the desired look that you are looking for and you will be just fine. Be sure to glue the wing spar joiner with a fair amount of epoxy.
Bill Brundle
Senior Product Development Manager
Hangar 9
Horizon Hobby
Bill Brundle
Hangar 9 Senior Product Developer,
Hide Signatures
       Post #: 6
RE: H9 TAYLORCRAFT STRUTS??? - 7/23/2007 3:18 PM
BAS
Score: 105
Last Login: 5/21/2013
Status: offline
The t-craft h-9 with ys 140 on board is one of my favorite planes to fly but i am glad to hear the struts are not functional because due to vibration i keep breaking off the struts end pieces that tie down to the fuse. Thanks for the info.
Bruce A Swartfager
Hide Signatures
(in reply to bbrundle)
       Post #: 7
RE: H9 TAYLORCRAFT STRUTS??? - 8/10/2007 2:49 AM
aussie jason
Score: 100
Status: offline
Hello Bill,
Just thought that I might just show you some of the photo's that relate to the manufactured strutt's for the Taylorcraft. The process was very easy and only took 2 or 3 days to complete and came up very nice, its also good to get some feed back from the peaple that test it like your self.
Cheers
Jason Meli
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 8
RE: H9 TAYLORCRAFT STRUTS??? - 8/29/2007 3:41 AM
harleywings
Score: 100
Last Login: 2/14/2013
Status: offline
I have a damaged windshield, can one be found or made ?????? I ordered one from a diferent manufacture that made a 1/4 scale taylor craft, it was to big. I would have to cut it in hafe to make it work.
Hide Signatures
       Post #: 9
RE: H9 TAYLORCRAFT STRUTS??? - 12/12/2007 7:01 AM
Ricky Blade
Score: 100
Last Login: 1/23/2012
Status: offline
please, who makes a 1/4 taylorcraft kit?
forgiven
Hide Signatures
(in reply to harleywings)
       Post #: 10
RE: H9 TAYLORCRAFT STRUTS??? - 12/14/2007 4:24 AM
octanehuffer
Score: 100
Status: offline
Lanier makes one similar to the H9 version.
Hide Signatures
(in reply to Ricky Blade)
       Post #: 11
RE: H9 TAYLORCRAFT STRUTS??? - 12/20/2007 5:47 AM
Ricky Blade
Score: 100
Status: offline
nice! thank you. if you hear of any others please post them. 1/4 scale is the perfect size too. i do appreciate the help. ricky.
forgiven
Hide Signatures
(in reply to octanehuffer)
       Post #: 12
RE: H9 TAYLORCRAFT STRUTS??? - 1/15/2008 11:18 PM
Ch0pp3r
Score: 100
Last Login: 4/10/2012
Status: offline
I have a Hanger 9 Taylorcraft in like new condition. I have about 15 flights on it. It has an RCS-180 w/Pitts muffler, also new with 15 flights. It has a 3300mah ignition and a 3300mah receiver batteries and all high quality Futaba digital servos. The struts are in the box and never used. And no, they are not functional struts on this airplane.
I also have, NIB a spare cowl, windshield and side windows.
If anyone really has to have it then make an offer, with or without the engine, servos or batteries.
Chuck
Hide Signatures
       Post #: 13
RE: H9 TAYLORCRAFT STRUTS??? - 1/18/2008 1:16 AM
aussie jason
Score: 100
Status: offline
Hey Guy's,
Well I have 2 just got one of the last one's in stock from my local hobby store as the manufacturer has gone out of business,
Minicraft hobbies.
I have installed a os 200 and swinging a 18 by 10 prop, and it flys great, there is another supplier but I will have to do some searching. Here are a few photo's also.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Ch0pp3r)
       Post #: 14
RE: H9 TAYLORCRAFT STRUTS??? - 3/7/2008 2:38 AM
lunns
Score: 100
Last Login: 5/17/2013
Status: offline
Hi Jason,
I have a H9 taylorcraft that I am fixing up, had a small nose in, broke the firewall and windshield, not much else fortunately (cowling in great shape!!) But I will have trouble with the windshield, you or your local shop wouldn't have a spare, or be able to pull one off the existing windshield?
Cheers
Steve (Melb)
Too many models, not enough time...
Hide Signatures
       Post #: 15
RE: H9 TAYLORCRAFT STRUTS??? - 3/7/2008 2:50 AM
ROGER RUSSELL
Score: 115
Last Login: 5/22/2013
Status: offline
Wish they still had/made them.
I would replace mine as it really flew nice and looked nice.
Only had five flights on mine when had a lock out????
Had a MDS 2.18 with pump, made the engine scream.
On board glow
Here are pics.............
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ROGER RUSSELL -- 3/7/2008 2:51 AM >
Remember to FLY HARD and LAND SOFT
Hide Signatures
(in reply to lunns)
       Post #: 16
RE: H9 TAYLORCRAFT STRUTS??? - 3/7/2008 5:02 AM
Ch0pp3r
Score: 100
Status: offline
If anyone is interested I have a like new airplane, plus, I have a spare windshield, side windows and a new cowl. I planned ahead but I never flew the airplane much. I prefer the more scale stick built airplanes and this one just got me over the hump til I could finish my Lanier Taylorcraft.
Chuck
Hide Signatures
(in reply to ROGER RUSSELL)
       Post #: 17
RE: H9 TAYLORCRAFT STRUTS??? - 3/7/2008 5:15 AM
JoeMamma
Score: 115
Last Login: 5/24/2013
Status: offline
Glad to see a Hanger-9 Taylorcraft thread is still alive after about 8-9 years. Too bad they quit making it about 5 years ago.
I put mine together about 7-8 years ago.........still flying it ! Powered with a Saito 1.8 using an ElectroDynamics on-board glow system.
After making numerous phone calls, I was fortunate to get in touch with Harold Hanson (Harold's real Taylorcraft was used by Hanger-9 as a model). Harold shot me a ton of pictures of his real Taylorcraft and then turned them into 10x8 glossies. He then mailed them to me along with documetation. He also gave me the name and phone number of the fellah that built his Taylorcraft.
Using the pictures and information from both Harold and the builder, I was able to fabricate about 100 small scale parts. These included a complete roll cage, detailed instrument panel, pitot tube, carb heat tube, gas cap and main landing gear springs.
One of the things that made Harold upset was the fact that Hanger-9 did not include the 1 degree of anihedral (opposite of dihedral)on the wing. This was also added to my model.
Putting the Taylorcraft together using Harold's help, made this my most gratifying model.
Joe M.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Joe Mamma
Hide Signatures
       Post #: 18
RE: H9 TAYLORCRAFT STRUTS??? - 3/9/2008 5:23 AM
aussie jason
Score: 100
Status: offline
Hi steve,
Sorry to here about the mishap, I will try and get some info from the gold coast club up the road not my club but they would be sure to give some information about the local supplier. Hey what club do you fly at will be down there in two weeks for work? Oh and I got my last Taylor craft from Col Taylor models in NSW. Not sure if he has any left but give him a call.
Cheers Jason
Hide Signatures
(in reply to lunns)
       Post #: 19
RE: H9 TAYLORCRAFT STRUTS??? - 3/11/2008 3:49 AM
lunns
Score: 100
Status: offline
Hi Jason,
I fly with the VARMS club, predominately gliders, but the taylorcraft will ultimately be my tug trainer. Whereabouts in melb for work?
If you find anything out regarding windshield that will be great.
Cheers
Steve
Hide Signatures
       Post #: 20
RE: H9 TAYLORCRAFT STRUTS??? - 3/11/2008 1:04 PM
aussie jason
Score: 100
Status: offline
Hey Steve,
In Japan at moment for work but get back next week so will get onto it asap. Heading down to Leongatha near Philip Island.
I will send you a pm once I am on my way.
Cheers Jason
Hide Signatures
(in reply to lunns)
       Post #: 21
RE: H9 TAYLORCRAFT STRUTS??? - 3/13/2008 8:09 AM
thetireman1
Score: 100
Last Login: 3/24/2013
Status: offline
Does anyone have any extra parts left over from one of these planes? I need a decal set and a pilot seat for mine...
Hide Signatures
       Post #: 22
RE: H9 TAYLORCRAFT STRUTS??? - 3/13/2008 4:18 PM
JoeMamma
Score: 115
Status: offline
To All,
Fiberglass Specialities http://www.fiberglassspecialtiesinc.com/catalog.htm carries a cowl (with airscoop) for $48.00. They also carry a windshield for $22.00.
Joe
Joe Mamma
Hide Signatures
(in reply to thetireman1)
       Post #: 23
RE: H9 TAYLORCRAFT STRUTS??? - 3/14/2008 1:50 AM
lunns
Score: 100
Status: offline
Hi Joe,
Have looked at the windshield from them, at $22US i'm very happy to pay, its the additional $30.50US to get it to australia that I don't like!!
Steve
Hide Signatures
(in reply to JoeMamma)
       Post #: 24
RE: H9 TAYLORCRAFT STRUTS??? - 3/14/2008 3:29 PM
aussie jason
Score: 100
Status: offline
Joe thats great,
As my colw is a lttle bit stuffed I may get one my self, this is a great supplier thanks for your help. Now I have two Taylorcraft models one in a bow and one to flight luckly me. Sorry had to do that.
Jason.
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.816RCU1
