Clutch problem maybe Help !!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI Off-Road >> Clutch problem maybe Help !!!!
Page: [1]
Login
Clutch problem maybe Help !!!! - 5/27/2007 11:01:32 PM
rezca
Status: offline
I think I got a little problem with my clutch the engine is going at full rpm but the power does'nt seem to be going to the wheels,plus I am notable to ajust my brakes properly...... I have very little braking power anybody could help me please I would appreciate
This is my first truck and I am kinda starting to hate it !!! lol
thanx
       Post #: 1
RE: Clutch problem maybe Help !!!! - 5/28/2007 3:07:57 PM
HAWKEYE022
Status: offline
ok here is what u do on your brake rod that connects to a servo there should be a little spring that your servo pushes agents un screw the end and take the spring out then take some fule line and cut a pice the same length as the spring. next throw the spring away and put the brake line in its place and then you screw the adjuster back on give it a frw extra turns maby 3 or 4 that will push the brakeing Fule line ( SPRING ) closer to the servo that should solve your problum. if u do all of that and u still dont have any brakes let me know . as for your clutch just make shure your gear on the engine ( BELL GEAR) is touching your sper gear ( the big gear)
(in reply to rezca)
       Post #: 2
RE: Clutch problem maybe Help !!!! - 5/28/2007 10:04:33 PM
rezca
Status: offline
Thanks for your brake advice men it helps a lot . Now I think I got another trouble ... Like you told me I cheked my spur gear and it is touching properly I took my clutch appart to make sure that there wasn't any grease or anything that could compromise the friction but I am still not getting as much power. Seems like all the power is going to the font wheels and barely nothing is going to the rear wheels .. another interesting thing is that when I brake the rear drive shaft and disk brake stop turning but the wheels keep going.....Do you think my lack of power might be due to me rear differential?
(in reply to HAWKEYE022)
       Post #: 3
RE: Clutch problem maybe Help !!!! - 5/29/2007 7:27:14 AM
HeLLsGoD
Status: offline
Loose shafts or cups? Double check the grub screws that connect the center shafts to the diffs
_____________________________
- HPI RS4 - HPI sprint 2 -
Dream, Drive, Drift.
(in reply to rezca)
       Post #: 4
RE: Clutch problem maybe Help !!!! - 5/29/2007 1:13:20 PM
HAWKEYE022
Status: offline
ya either do that or check your diff it might have broke
(in reply to HeLLsGoD)
       Post #: 5
RE: Clutch problem maybe Help !!!! - 6/1/2007 7:50:33 PM
rezca
Status: offline
thanks guys everything is fixed one of the dog bones was disconnected... I think I should have bought a savage instead........
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.406RCU1
