Ryan Smith
NC, USA Status: offline
Rodney, You'll likely be better off with the 1.40, unless you're at a high altitude. For a good fuse floor, if you don't have honeycomb, or don't want to put any in, I've had good luck with sealing some 3/32 contest balsa with Balsarite and then glassing both sides with very light fiberglass. The Shinden shouldn't be hard to stick a tunnel in.
_____________________________
www.somenzini.com, www.yspartsandservice.com, www.evil-rc.com
