Shinden Build
Tower Hobbies
Logged in as Guest
  Printable Version
KAOS /OS91P-SCRATCH BUILT RTF/SPA LEGAL
Seller:  F.Imbriaco
Details:   $500.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Pattern Flying >> Shinden Build
Page: [1] 2 3 4 5 6 7 8   next >   >>
Login
Shinden Build - 5/28/2007 5:39:19 PM
Jetpilot12
Status: offline
All of the parts came in perfect. Everything looks great !
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Shinden Build - 5/28/2007 5:40:32 PM
Jetpilot12
Status: offline
More parts
Click for fullsize
Click for fullsize
< Message edited by Jetpilot12 -- 5/28/2007 5:41:15 PM >
(in reply to Jetpilot12)
       Post #: 2
RE: Shinden Build - 5/28/2007 5:50:32 PM
Jetpilot12
Status: offline
Mounting the landing gear. As you can see the holes are not drilled to mount the gear to the gearbox.
Cut a small square of paper and tape it to the gearbox. Then, using a punch find the holes. Place
the gear over the paper and trace it out. Remove the gear and match up the paper with the gear and mark the
holes with a marker. Drill the holes for a perfect fit.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 3
RE: Shinden Build - 5/28/2007 5:51:59 PM
Jetpilot12
Status: offline
Landing gear
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 4
RE: Shinden Build - 5/28/2007 6:00:20 PM
Jetpilot12
Status: offline
Canopy install: Place the clear canopy over the canopy frame. Using thin tape outline the cut-line. Cut canopy and glue in place.
Click for fullsize
Click for fullsize
       Post #: 5
RE: Shinden Build - 5/28/2007 6:18:31 PM
RC_Pattern_Flyer
Status: offline
did you finsih yet?
i thought that pink version was the PnP version?
hahaha, looks great.. hope to see it in Nederland?
Chuck
_____________________________
Mark Hunt Designs
       Post #: 6
RE: Shinden Build - 5/28/2007 8:34:04 PM
rgreen24
Status: offline
How is the weight on your Shinden?
(in reply to RC_Pattern_Flyer)
       Post #: 7
RE: Shinden Build - 5/28/2007 10:03:20 PM
Jetpilot12
Status: offline
Here are the weights:
Both stabs with spars: 316g / 11.1oz
Left wing: 442g / 15.7oz
Right wing: 466g / 16.4oz
Wing tube: 76g / 2.7oz
Fuselage: 1180g / 41.5oz
Right landing gear: 84g / 2.9oz
Left landing gear: 90g / 3.2oz
Firewall bulkhead: 54g / 1.9oz
Uncut canopy: 156g / 5.5oz
(in reply to rgreen24)
       Post #: 8
RE: Shinden Build - 5/28/2007 11:11:11 PM
rgreen24
Status: offline
What is you final estimated weight?
       Post #: 9
RE: Shinden Build - 5/29/2007 12:18:01 AM
Troy Newman
Status: offline
2120g for an entire model complete without landing gear legs will yield a 10lb even model
Your model from the weights above is 2690g I have found that a model pushing 2500-2550 is the weight limit without landing gear legs. However this weight does include the firewall already glued in place on the above the model. This 2120g also includes the servo trays installed and tank mounts too.
The bottom line difference is 570g from the above numbers. This is 20oz. Make sure you conserve every ounce possible....Absolutely every possible ounce. Add this 20oz to the 10lb model and its 4 oz over weight.
I have a pretty comprehensive spread sheet that goes back to 1999-2000 and based on about 15 different models assembled by myself or buddies and the projected weights are now coming out within 1oz of the predicted on my spread sheet On any of the models I have built recently. This goes back to my Fashion in 1999 and catches other models like a Comp Arf Rev Pro, a couple CA eclipses', a Genesis, Angel Shadow, Beryll, 3 Pinnacles, Astral XXc, Zeque, and the Adventure Bipe. I basically have the spread sheet tuned up to get really close overall weights. The more models that get in entered the closer it gets to actual weights.
The Spread sheet says that your model is 4-5oz over weight as it sits. This is already using many weight saving items like small lipo for RX and lightweight Hydemount. Your wing tube is already pretty light and so on..... Use the heavy batts and so on you might be as much as 6-8oz overweight.
You need to take special care in making sure that everything you do is as light as possible. Of course the uncut canopy will give some weight but its not going to do a full 4-5oz as it only weighs 5.5oz uncut.
Bryan's models always fly well and it will even at the 11lb limit but you need to make weight with it. So work extra hard on your equipment choices and be super careful on every bit of weight you add. Just because its some space aged material doesn't mean its lighter. Get the stuff on the scale and weigh every part. Remake the part 3-4 times and try to get it lighter before you glue it in place. Do a major comparison on the weights and strengths of the parts you add. Minimize silicone fuel tubing, and use aluminum tubing instead its much lighter. Consider a very light tank, If you are using a DZ it doesn't need to hold pressure so a light weight tank from a sport model might work better in weight savings. Super lightweight everything is needed to shave that 4-5oz out of it.
This is not a bash or anything on the model, I would like to get my hands on a Shinden and see how it flies, I'm just crunching the real numbers and have experience doing it with my own models. I'm sharing the experience I have gained in the past few years on these types of models and you need to work hard to get that model to make it. It likley can be done, but I don't want to see you get it all together and then realize its 4-5 or even 8oz over weight. That makes the choices difficult. You can shave weight when assembling that once you do it is difficult to get the excess back out.
Bryan will help you get it... He is way better than I at coming up with creative ideas to shed ozs, and have well engineered pieces. Today's power plants have plenty to carry the legal models. So you won't suffer using a current engine setup, but you need to have it make weight to be in the "Show" Plus the lighter you can get it the better off you be in the future for repairs, and any changes you might make to it over time.
Good Luck with it and keep us posted on how it goes. I'm willing to help offline too just email me and I'll share some ideas with you about getting it lighter. Bryan probably already has a handle on them but just in case.....
Troy Newman
       Post #: 10
RE: Shinden Build - 5/30/2007 6:39:03 PM
Jetpilot12
Status: offline
Mounting the engine:
First: hang the fues on a wall.
Second: clamp the engine with the motor mount, back plate and prop to the
nose of the cowl (make sure to to put a 1/16" piece of balsa between the back plate
and the fuse).
Click for fullsize
Click for fullsize
(in reply to Troy Newman)
       Post #: 11
RE: Shinden Build - 5/30/2007 6:45:33 PM
Jetpilot12
Status: offline
Now, from the inside of the fuse, you can trim the firewall to fit up against the back of the motor mount.
using a small amount of CA tack the mount in place.
Click for fullsize
Click for fullsize
       Post #: 12
RE: Shinden Build - 5/30/2007 6:54:28 PM
Jetpilot12
Status: offline
Now you can remove the motor. Before gluing in place, make sure to put tape around one side of the mount.
This will stop the glue from seeping through to the other side. I used 30min epoxy with cavosil.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 13
RE: Shinden Build - 5/31/2007 5:14:13 AM
Troy Newman
