Diesel Dave-RCU
MI, USA Status: offline
[QUOTE]Originally posted by mwright 20% oil, 30% ether, 2% AN, 48% FAME 10% oil, 30% ether, 2% AN, 58% FAME 5% oil, 30% ether, 2% AN, 63% FAME 20% oil, 20% ether, 2% AN, 58% FAME 20% oil, 10% ether, 2% AN, 68% FAME 20% oil, 5% ether, 2% AN, 73% FAME 10% oil, 10% ether, 2% AN, 78% FAME 5% oil, 5% ether, 2% AN, 88% FAME [/QUOTE] Well lets do this first, I am sure you know how a "real" diesel runs, but I am going to give a fast explanation anyhow, just for the benefit of anyone else reading this. Basically the engine on the compression stroke, is just compressing air. (this is a real diesel engine, like in a semi truck) In the process of compressing air, you create heat. So much so, that at the top of the stroke, when the fuel is injected, the temperature in the chamber is greater than the flash-point of the fuel, causing the fuel to burn instantly. I drive trucks for a living. I happen to know that most diesel engines in the industry have a compression ratio greater than 20 to 1 to achieve this. In a model engine, we don't have a chance at reaching that kind of compression ratio, without a catastrophic failure. This is why the either is in the fuel in the first place. with its much lower flash-point, than kerosene, or FAME in this case, it will start to burn at a compression more realistic for our engines. When the either burns, it in turn starts the kerosene. Either is the igniter, kerosene is the fuel, get it. I see the lower oil mixes, working well, just because the FAME is so oily already. But the lower either mixes you have listed, I think will cause you lots of trouble. You will definitely have to increase the compression with less either. I would not take the compression any higher than 1/2 to 3/4 turn out, especially on a hot engine. Any more than that, you might break your connecting rod, or at least bend it. Dave
