RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
Users viewing this topic: scotthowell
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  173 174 175 176 177 [178] 179 180 181 182   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:24 AM
ticketec
Score: 105
Last Login: 5/22/2013
Status: offline
I run and have done so for many flights with 1 Hs-5645MG in the centre of the elevator with no problems.
dave
Hide Signatures
(in reply to aquaskiman)
       Post #: 4426
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:30 AM
Xairflyer
Score: 105
Status: offline
Single servo works well, I have done it to two tailplanes now, very easy to do to the standard falcon, little bit more difficult to the fully sheeted tail versions.
Details of one of them here post 4244 using a Spektrum DS821 servo
_____________________________
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
       Post #: 4427
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:37 AM
Xairflyer
Score: 105
Status: offline
If you are looking for something in this thread but dont want to go through all the pages just use search at the bottom of the page.
www.jmaireland.com
Hide Signatures
(in reply to Xairflyer)
       Post #: 4428
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:48 AM
vincedecaledo
Score: 100
Last Login: 12/29/2012
Status: offline
thanks a lot for your input guys !!! !
what kind of torque will you put in minima?
8kg ? 10 kg ? more?
i should have a look if i haven't a 5645 mg somewhere on my workshop...
Xair, you think 6KG is enough for this plane with a K80 ?
i have a futaba 9202 just in front of me...do you think it can do the trick...should be a bit short isn't it ?
thanks
Hide Signatures
       Post #: 4429
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:57 AM
Xairflyer
Score: 105
Status: offline
The spektrum DS821 is 5kg toque
www.jmaireland.com
Hide Signatures
(in reply to vincedecaledo)
       Post #: 4430
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 1:39 PM
BaldEagel
Score: 118
Status: offline
I use a Hitec HS5625 on the elevator of my Sprint and did use two on my Elan, all have been without problems, on the Sprint I use a metal ball link and twin carbon horns to try and offset any heat that may get to them.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
       Post #: 4431
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 3:06 PM
aquaskiman
Score: 100
Last Login: 5/21/2013
Status: offline
If you use two elevator servos and you have one fail you have a chance of getting the plane back. If you have one and it fails you get a crash. All of my high end jets have two elevator servos. Look at the field and see how many use only one elevator servo.
George
Hide Signatures
(in reply to BaldEagel)
       Post #: 4432
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:09 PM
ticketec
Score: 105
Status: offline
Yes, but if the the servo motor burns out then the remaining servo may not be able to overpower it. Not being properly rigged could cause them to fight each other and end up causing a failure, etc etc.... there are aguments both ways. it ends up with the user deciding what works best for them.
In 20 years of R/C flying I have never had an elevator servo fail... will it happen? maybe some day, but there is a greater likelyhood of something else like a R/X pack failing first which is why I do run two of those. I also try and stick with servos which I know are reliable.
Thnaks
dave
Hide Signatures
       Post #: 4433
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:39 PM
aquaskiman
Score: 100
Status: offline
I said to slpit the elevators ( cut in half ) so each half works independent of the other.
George
Hide Signatures
(in reply to ticketec)
       Post #: 4434
RE: Bob Cat Copy Falcon 120 Jet - 9/21/2012 11:44 PM
aquaskiman
Score: 100
Status: offline
quote:
ORIGINAL: aquaskiman
I would just split the elevator and run two mini servos
here is the post
George
Hide Signatures
       Post #: 4435
RE: Bob Cat Copy Falcon 120 Jet - 9/22/2012 12:32 AM
Xairflyer
Score: 105
Status: offline
I am not sure that two elevator servos would be an advantage if you lost one, most of the time the servo will go full to the end of its travel if say it was a conventional tail you now have tailerons and it will cause the model to roll, just as many jets like F15 & F16's are flown that way without ailerons.
If you lost a servo and it stayed neutral, I still think when you pulled up on the other it would again cause a roll.
Split elevators inside twin booms like on the falcon & boomerangs would probably work different and not notice as much if one failed unless again it went to full travel.
If you fitting twin servos for the elevators as normal on the falcon then it would make sense to cut the elevator in half to give you the best advantage of using two servos, if you dont then you are better of using just one.
www.jmaireland.com
Hide Signatures
       Post #: 4436
RE: Bob Cat Copy Falcon 120 Jet - 9/22/2012 1:14 AM
chw757s6640
Score: 100
Last Login: 4/19/2013
Status: offline
Hi Guys,
I am pursing a new project, so I have decided to sell my Falcon 120. I have a new Falcon 120 (White/Orange). The only work performed is:
1. Modified fuselage formers to mirror the Tornado design. Added Hysol on the seams.
2. Installed a Modellbau Tornado V3 Engine Mount.
The kit is complete and ready for final turbine conversion.
I will also include a set of Tornado V3 wings and composite tail booms that I received from a friend. They have some damage, but can easily be repaired. The landing gear mounts broke and one boom has a crack along the join seam. I repaired one wing by putting in new hardwood stock for the gear mounts, which are extended to the fourth rib, re-inforced all joints with hysol and re-covered with balsa. I will include the wood stock and balsa to repair the other wing. An extra used Tornado V3 canopy and tub will also be included.
I am just looking to recover some of the money invested in the Falcon. If you are interested, give me a call or send me an email. I have pictures and a solid market place rating. I will gladly give someone a good deal on this to clear up some space in my shop.
If you need a turbine for it, I have a P-70 listed on RCU.
Chris Wilson
St. Louis, MO
Phone: 314-452-8379
Email: cjw_mcp@msn.com
Hide Signatures
       Post #: 4437
RE: Bob Cat Copy Falcon 120 Jet - 9/23/2012 10:18 PM
tim777jet
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Guys, not being pedantic, ref the use of 2 sets of RX batteries in the plane, many guys do this, however i never hear of guys running 2 sets of TX batteries. Batteries are batteries, weather they are fitted in the plane or a transmitter. Many many years ago, i built a LOWBoy, maidened it, it flew great. Refuelled, everything was good, TX battery Meter reading way up the scale, flew for about 10 mins, then lost control of the plane, it flew off quite a way and crashed into a nearby forest. I found it and managed to repair her. I sent the radio back to the manufactures and they stated a cell in the TX pack had failed, strangely, after an overnight charge, it would perform well, but would suddenly fail dragging the other cells with it, it was not old radio equipment.
I also got involved with electric powered gliders way before they were seen at flying sites. I bought a new nicad battery pack, an 1800ma, my most powerfull pack at the time, fresh from the manufacturer. The first few flights were good, but battery drastically reduced in power in a short space of time. I stripped the pack down and found 1 Cell, fitted the wrong way round, unbelievable. I replaced the cell with a similar capacity cell, and the pack was good again, you just cant cover every eventuality.
cheers tim
Hide Signatures
(in reply to chw757s6640)
       Post #: 4438
RE: Bob Cat Copy Falcon 120 Jet - 9/29/2012 10:07 PM
jetdeck
Score: 100
Status: offline
to gary travis, or any other jet jockey. jetdeck here, live in springhill florida, i have a nitroplanes super falcon 120 in the USAF trim scheme, and no this is not a knockoff from hobbyking or anywhere else in the world, it is NEW in box. did take it out to inspect for any damage and there is none. the wings, booms, elevator, rudders are all fully sheeted. i;ve done nothing to it, just describing what i see. i am selling mine for what i paid for it from nitroplanes which is $180.00 can work out shipping details if anyone is interested, you can contact me by e-mail at georgemangold@yahoo.com. i have taken pics of it so if you e-mail me i can e-mail to you, have lost interest in it, are now biulding a vmar f4 phantom with a o.s.95 and robart retracts.
Hide Signatures
(in reply to Gary Travis)
       Post #: 4439
RE: Bob Cat Copy Falcon 120 Jet - 9/29/2012 10:47 PM
Boomerang1
Score: 120
Status: offline
I recently had my first in-flight servo failure on a medium size electric.
One aileron servo went to about 1/2 travel & stayed there solid whenever power was on, power off & you could move the servo
against the gears & motor.
I landed the model ok with a heap of opposite aileron.
Two ways of looking at redundancy.
With one aileron servo I would have crashed?
Or, with one aileron servo my chances of aileron servo failure are halved?
Me, personally, the extra elevator servo is just like that heavy fire extinguisher I carry to the field & never use. - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
(in reply to jetdeck)
       Post #: 4440
RE: Bob Cat Copy Falcon 120 Jet - 10/6/2012 10:27 PM
alasdair
Score: 113
Status: offline
I moulded my own from fibreglass & epoxy over a blue foam plug.
Hold 2.3 litres.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 4441
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 1:39 AM
ticketec
Score: 105
Status: offline
Berri brand fruit juice bottle, holds 2.2lts $3.47 comes with free juice!
Dave
Hide Signatures
(in reply to alasdair)
       Post #: 4442
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 2:24 AM
Jeremy_D
Score: 100
Status: offline
quote:
ORIGINAL: ticketec
Dave
lol!
Global Jet Club Australia
www.aussiejet.com
Hide Signatures
       Post #: 4443
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 4:06 AM
Dc2LightTech
Score: 100
Last Login: 12/21/2012
Status: offline
can you do this with nitro fuel?
Fly ‘till your thumbs bleed!
Hide Signatures
(in reply to Jeremy_D)
       Post #: 4444
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 4:09 AM
Dc2LightTech
Score: 100
Status: offline
i am driving my falcon with a 160FX so I dont need fancy retracts. what are my options for retracts? part numbers would be nice....
Hide Signatures
(in reply to Dc2LightTech)
       Post #: 4445
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 6:30 AM
Sansan
Score: 100
Last Login: 5/12/2013
Status: offline
what epoxy did you use?
Hide Signatures
       Post #: 4446
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 6:31 AM
Sansan
Score: 100
Status: offline
quote:
ORIGINAL: alasdair
Hold 2.3 litres.
Hide Signatures
       Post #: 4447
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 2:52 PM
5skyhawk172
Score: 121
Status: online
I bought a set of retracts from dreamworks.  Don't even want to say how much.  LOL!!!
Hide Signatures
(in reply to Sansan)
       Post #: 4448
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 3:38 PM
BaldEagel
Score: 118
Status: offline
I know what you mean, I have the Digitech ones and they cost more than the airframe. LOL
Mike
Hide Signatures
(in reply to 5skyhawk172)
       Post #: 4449
RE: Bob Cat Copy Falcon 120 Jet - 10/7/2012 6:00 PM
aquaskiman
Score: 100
Status: offline
quote:
ORIGINAL: 5skyhawk172
You will be glad you did, they just work.
George
Hide Signatures
       Post #: 4450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.266RCU1
