RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Turbine Epic Victory Jet - Kit
Seller:  cat-boi
Details:   $3,600.00   |  5/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 7:01 AM
seanreit
Score: 100
Last Login: 4/26/2010
Status: offline
It's a bit small for my taste.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to scalenut07)
       Post #: 26
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 8:21 AM
snoozer
Score: 105
Last Login: 3/6/2013
Status: offline
Are the wings sheeted or are they monokoted?
Are the retract bays for the mains cut out?
Hide Signatures
(in reply to seanreit)
       Post #: 27
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 8:24 AM
seanreit
Score: 100
Status: offline
Monokoted, I didn't look to see if the wings were setup for retracts or not. I'm not that impressed with this thing. I wanted to see what a 250 dollar bobcat looks like. Well, I seen it, and it's about what you would expect for a couple hundred bones. This might be a great electric ducted fan though, but I don't know anything about electric stuff.
Hide Signatures
(in reply to snoozer)
       Post #: 28
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 8:49 AM
busboy722
Score: 100
Last Login: 9/4/2009
Status: offline
okay give us some pics of the wing now please
but i can see why you would say its small
you fly the big ones
Hide Signatures
       Post #: 29
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 10:22 AM
nitrostaff1
Score: 110
Last Login: 3/7/2011
Status: offline
some more pixz
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
THE BEST LIPO BATTERIES
http://www.hobbypartz.com/lipobatteries.html
Hide Signatures
(in reply to busboy722)
       Post #: 30
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 11:47 AM
myersflyers
Score: 100
Last Login: 5/24/2013
Status: offline
Got mine today.
Seems they changed the glue. Looks like hot glue joints.
Paint needs to be sanded and cleared due to flashing here and there.
Fuse can't accommodate a DUBRO 50 oz. I got one 24oz. in, could easily fit another 24 oz or maybe two 32oz + UAT.
Retracts pockets are set up for Robart 550 or 530 size gear. Definitely requires Hysol and reinforcement here.
I don't like the nose retract plate and set up, because it limits what you can do as far as gear and doors without a major overhaul.
Also, they created a receptical for the air tank that prevents you from using about 10 inches of nose area for
weight, batteries, etc.
I also noticed that the white fuse seems a bit heavier than the black one. I'll weight things tomorrow.
The servo setup in the booms are simular to the BC50, but the 2 elevator servos now sits high on the boom near the bottom of the stab.
I thought the tail plane thickness would easily accomodate a retro fitted 8611, but I believe its a tad bit narrow.
I've built a number of balsa kits over the years and this ARF is not that bad, just needs a little TLC in the right areas and
you've got a rock solid jet. For 250, I think I got what I expected. This will make the perfect pactice and small field plane.
I'm planning on putting a turbine in one and electric the other, haven't made up my mind which.
The white one will get striped down and painted in a TBird or Blue Angel scheme.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to nitrostaff1)
       Post #: 31
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2007 9:50 PM
i3dm
Score: 100
Last Login: 5/22/2013
Status: offline
Guys, did you check about the retract wells and mounts in the wing ? pics would be great.
Thinking about a turbine conversion, i know the BVM bobcat (same size but heavier plane) flys very fast on a Jetcat P-80 (8kg thrust), so i figure a JJ1400 with about 6kg thrust should push the Falcon 120 around fairly well !
BTW - the manufacturer of the Falcon sells a kit with some nice looking air up spring down retracts and struts, im not sure why the US distributor decided to buy the gear-less version.
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to myersflyers)
       Post #: 32
RE: Bob Cat Copy Falcon 120 Jet - 6/9/2007 1:41 AM
busboy722
Score: 100
Status: offline
would love to see some wing pics and what kind of retracts to use in this bird looking for as much info as posible
seems this forum has slowed down ummmm
Hide Signatures
(in reply to i3dm)
       Post #: 33
RE: Bob Cat Copy Falcon 120 Jet - 6/11/2007 11:43 PM
NeoGenesis
Score: 100
Last Login: 8/31/2012
Status: offline
quote:
ORIGINAL: myersflyers
I also noticed that the white fuse seems a bit heavier than the black one. I'll weigh things tomorrow.
Any chance you got it mocked together and weighed?
Neo
Fly it like you stole it!!!!!!!!
Revver Brother #122
Hide Signatures
       Post #: 34
RE: Bob Cat Copy Falcon 120 Jet - 6/12/2007 12:37 AM
gadix
Score: 100
Status: offline
a ram500 is a turbine correct?
do you think of reenforcig the wing in any way?
GADI,
ISRAEL
Hide Signatures
(in reply to TCHIEF)
       Post #: 35
RE: Bob Cat Copy Falcon 120 Jet - 6/12/2007 12:41 AM
i3dm
Score: 100
Status: offline
Gadi, where you been brother ?
Lior.
www.liorzahavi.com
Hide Signatures
(in reply to gadix)
       Post #: 36
RE: Bob Cat Copy Falcon 120 Jet - 6/12/2007 7:29 AM
Efishensea
Score: 100
Last Login: 5/17/2013
Status: offline
O.S 1.60 FX With a three blade 16X10 Pusher Prop????????????
Hide Signatures
(in reply to i3dm)
       Post #: 37
RE: Bob Cat Copy Falcon 120 Jet - 6/12/2007 12:04 PM
angelrcdesign
Score: 100
Last Login: 5/26/2013
Status: offline
I just got my today And planing to put a Byron set up. but the Artes would do the job does not eat much
fuel. It also can use another wingtube fore more support. Here goes another project.
If something fails,try and try again until you get it right.
Hide Signatures
(in reply to Efishensea)
       Post #: 38
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 1:20 PM
JIMZACH
Score: 100
Status: offline
Has anyone come up with a better idea for the nose gear? Mine is ready to fly at 13.6 pounds.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to angelrcdesign)
       Post #: 39
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 1:27 PM
JIMZACH
Score: 100
Status: offline
Forgot pics of nose gear strut.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to JIMZACH)
       Post #: 40
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 4:04 PM
NeoGenesis
Score: 100
Status: offline
What engine do you have installed? I'm just curious because it seems that most of the bobcat 50's need a .60 or .75 to really get moving. So....I'm really starting to question whether or not a 1.20 will get this bird moving like it should or not. I can't wait to hear you reports on the maiden!!!
Also.....what is the width between the booms?
Neo
< Message edited by NeoGenesis -- 6/13/2007 4:50 PM >
Revver Brother #122
Hide Signatures
       Post #: 41
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 4:34 PM
tothemax
Score: 105
Status: offline
JIMZACH
What retracts are you using? Your setup looks good.
Steve G
Hide Signatures
       Post #: 42
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 4:49 PM
i3dm
Score: 100
Status: offline
as far as my expirience with the 50 goes, i only enjoyed the speed if i put a 91 motor on it, even a 61 and 75 were nice, but not quite up ther with other prop jets.
i doubt a 120 would move the falcon in a jet like manner.
www.liorzahavi.com
Hide Signatures
(in reply to tothemax)
       Post #: 43
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 5:42 PM
Efishensea
Score: 100
Status: offline
Also, I was wondering about transportation? Dose it break down to fit in the Car?? And if so is it a nightmare or is it eazy to do?????
Hide Signatures
       Post #: 44
RE: Bob Cat Copy Falcon 120 Jet - 6/13/2007 6:33 PM
RCISFUN
Score: 105
Status: offline
How easy do the wings come off, what is the attachment method for the wings, can you take a close up photo of the attachment?
Rich
Jet Central Rabbit, Cheetah, Super Eagle & Rhino owner
Hide Signatures
       Post #: 45
RE: Bob Cat Copy Falcon 120 Jet - 6/14/2007 1:13 PM
JIMZACH
Score: 100
Status: offline
To start with I had a GMS 120 that I put in, but the next engine will be an OS 160. The retrcts are ROBART 520 series with a fork type strut I made. I spoke to robart and ordered parts to install a 656 ROBO STRUT in nose gear. The wings come off easy with a wing nut ( did not use 6mm plastic bolt supplied) and I plan to leave the booms on (THEY ARE A PAIN).
Hide Signatures
(in reply to RCISFUN)
       Post #: 46
RE: Bob Cat Copy Falcon 120 Jet - 6/14/2007 1:20 PM
JIMZACH
Score: 100
Status: offline
Here are a few more pics.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 47
RE: Bob Cat Copy Falcon 120 Jet - 6/14/2007 5:31 PM
NeoGenesis
Score: 100
Status: offline
I take from your post you didn't like th GMS 1.20 on it. Could I persuade you into giving a flight report with it? Also....could you post what the width is between the booms?
Neo
Revver Brother #122
Hide Signatures
       Post #: 48
RE: Bob Cat Copy Falcon 120 Jet - 6/14/2007 5:35 PM
Efishensea
Score: 100
Status: offline
Very Clean Build!!!! You Take Pride in your work. Give us your Flight Report. Thank you!
Hide Signatures
       Post #: 49
RE: Bob Cat Copy Falcon 120 Jet - 6/15/2007 1:28 AM
figueroa
Score: 100
Last Login: 5/25/2013
Status: offline
Great job Jim.
Looks like it's just about ready for maiden.
Good luck.
jef
JetCat P120, JetCentral Super Eagle, Jet Legend L- 39
Boomerang XL II, Futaba 14mz 2.4 ghz
Hide Signatures
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.547RCU1
