RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 8:09 AM
Todd Jackson
Score: 100
Last Login: 5/19/2013
Status: offline
Well just 2...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Todd Jackson)
       Post #: 101
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 1:49 PM
i3dm
Score: 100
Last Login: 5/18/2013
Status: online
Amazing how these formers pulled out.. seems that the chinese guys were thinking about these turbine conversions and helping us out here..
_____________________________
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
       Post #: 102
RE: Bob Cat Copy Falcon 120 Jet - 6/27/2007 5:03 AM
TJK
Score: 100
Last Login: 5/14/2013
Status: offline
Any flight reports yet?
Hide Signatures
(in reply to i3dm)
       Post #: 103
RE: Bob Cat Copy Falcon 120 Jet - 6/27/2007 7:16 AM
SinCityJets
Score: 115
Last Login: 5/17/2013
Status: offline
At last, poor Chinese build quality finally pays off!
Hide Signatures
(in reply to TJK)
       Post #: 104
RE: Bob Cat Copy Falcon 120 Jet - 7/2/2007 6:09 PM
Todd Jackson
Score: 100
Status: offline
Any one made any more progress with there Falcon yet? I have the new nose gear mounts done and cut the covering off the bottom of the wing to change out the gear mounts for the bigger Robart gear. By the way can I change my 85 degree to 90 for the mains that I was putting in till I found that yesterday? Todd
Hide Signatures
(in reply to figueroa)
       Post #: 105
RE: Bob Cat Copy Falcon 120 Jet - 7/3/2007 5:41 AM
angelrcdesign
Score: 100
Status: offline
Yes I had three flights on sunday. on the ali. a little trim , on the elevator, little trim up.
On the ele. make sure that the top of the stab is even with the ele. NOT THE BOTTOM.
The C/G is perfect at 13 inches. I even had one deadstick. and it like to glide. I did not use flaps. The Byron fan system works great at 4-1/4 outlet. I will try 4 inch outlet next , after that some props. I use spring/air Robarts.
If something fails,try and try again until you get it right.
Hide Signatures
       Post #: 106
RE: Bob Cat Copy Falcon 120 Jet - 7/3/2007 3:43 PM
Todd Jackson
Score: 100
Status: offline
I am glad yours flew well and has any got there’s ready with the turbine? Thanks Todd
Hide Signatures
(in reply to angelrcdesign)
       Post #: 107
RE: Bob Cat Copy Falcon 120 Jet - 7/5/2007 8:19 PM
gliderpilot
Score: 100
Last Login: 3/12/2013
Status: offline
I just got my Falcon 120. I'd like to know what size motor to put in this jet? I'm thinking about a GMS120 or an OS140.
Have any of you out there tried these combinations? Thanks.......
Hide Signatures
       Post #: 108
RE: Bob Cat Copy Falcon 120 Jet - 7/5/2007 8:26 PM
rcguy!
Score: 108
Status: offline
quote:
ORIGINAL: gliderpilot
For a jet I'd use a turbine. For a pusher prop job go with the OS140. Can't ever have too much power.
Dave
Hide Signatures
(in reply to gliderpilot)
       Post #: 109
RE: Bob Cat Copy Falcon 120 Jet - 7/5/2007 8:54 PM
NeoGenesis
Score: 100
Last Login: 8/31/2012
Status: offline
quote:
ORIGINAL: JIMZACH
To start with I had a GMS 120 that I put in, but the next engine will be an OS 160. The retrcts are ROBART 520 series with a fork type strut I made. I spoke to robart and ordered parts to install a 656 ROBO STRUT in nose gear. The wings come off easy with a wing nut ( did not use 6mm plastic bolt supplied) and I plan to leave the booms on (THEY ARE A PAIN).
This from earlier in the thread.
Neo
Fly it like you stole it!!!!!!!!
Revver Brother #122
Hide Signatures
(in reply to JIMZACH)
       Post #: 110
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 5:16 AM
Todd Jackson
Score: 100
Status: offline
I have run out of room in my falcon 120 for fuel. Any suggestions about a external centerline fuel tank. Thanks Todd
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to NeoGenesis)
       Post #: 111
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 5:25 AM
Todd Jackson
Score: 100
Status: offline
Some of my gear mount upgrade for the bigger gear. The blocks that were there came out without breaking any ribs........HUMMMMM.
Todd
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 112
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 7:25 AM
Randy M.
Score: 100
Status: offline
Click for fullsize
Silence is golden,,, but duct tape is silver.
Hide Signatures
       Post #: 113
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 7:53 AM
Woketman
Score: 105
Status: offline
I wonder whom THAT might be?
Hide Signatures
(in reply to Randy M.)
       Post #: 114
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 8:01 AM
i3dm
Score: 100
Status: online
Randy, has that falcon flown on turbine power ?
If so, which turbine is that and how did it fly ? please tell us..
www.liorzahavi.com
Hide Signatures
(in reply to Woketman)
       Post #: 115
RE: Bob Cat Copy Falcon 120 Jet - 7/10/2007 8:05 AM
Randy M.
Score: 100
Status: offline
I have no details. I was not at the field when this pic was taken. I believe it's a ram 750. I don't think it has flown yet. The same fellow has 2 of the 50 size bobcats with jet joes on them.
Hide Signatures
(in reply to i3dm)
       Post #: 116
RE: Bob Cat Copy Falcon 120 Jet - 7/12/2007 6:00 PM
Todd Jackson
Score: 100
Status: offline
Any flight reports on the Falcon in the pic Randy and what size tanks have any body fitted in it for turbine use?
Thanks Todd
Hide Signatures
       Post #: 117
RE: Bob Cat Copy Falcon 120 Jet - 7/12/2007 6:51 PM
knowcrash
Score: 100
Last Login: 4/11/2010
Status: offline
i have a super bee on mine but i would like to hear some flight reports before i fly it, especially the take offs and landings.
Hide Signatures
       Post #: 118
RE: Bob Cat Copy Falcon 120 Jet - 7/13/2007 7:10 AM
Johnny Isaiah Woods
Score: 100
Status: offline
The Falcon pictured in Randy M. post is mine. It is packing
a Ram 750 air start. Fuel is 90 + ozs in a bottom 50 oz, 32
oz sitting on top of the 50 and the tank that comes with the
plane. The dry weight is 16.5 lbs and ballanced forward of the
13 in. for the test flight (nose heavy is much better than
tail heavy on first flight). The plane has not flown yet because
of other problems unrelated to flying, but hopefully by this
week end. Results will be posted, good or bad, using the new
XPS 10 channel reciever in a JR 10S.
Johnny
Hide Signatures
(in reply to knowcrash)
       Post #: 119
RE: Bob Cat Copy Falcon 120 Jet - 7/13/2007 8:51 AM
NUNU
Score: 100
Status: offline
i have been flying mine for about a week now. CG is the stated 13 inces and that is perfect...the plane is great for power i have a supertigre 2300...at this time the motor is not performing well..gotta break it in and i am also planning for a header tank, but you guys will love it
Hide Signatures
(in reply to Johnny Isaiah Woods)
       Post #: 120
RE: Bob Cat Copy Falcon 120 Jet - 7/13/2007 10:52 PM
i3dm
Score: 100
Status: online
Johnny, PLEASE make a video for us.
www.liorzahavi.com
Hide Signatures
(in reply to NUNU)
       Post #: 121
RE: Bob Cat Copy Falcon 120 Jet - 7/13/2007 11:37 PM
Terry Holston
Score: 100
Status: offline
Johnny, Ya think that 'll be enough power??????????????????????????????????????????
Terry Holston,I Fly Jets
I''''m NOT speeding, I''''m QUALIFYING
Hide Signatures
       Post #: 122
RE: Bob Cat Copy Falcon 120 Jet - 7/15/2007 6:02 PM
Grumman
Score: 100
Last Login: 10/17/2012
Status: offline
Hello Guys!!! Looks like a great project and lots of nice work guys....
Where can I purchase one retract ready??? I would like to put my new Wren MW54 MKlll on it... I can purchase it in the States or in Europe as I will be here for the Summer to Fall months...
Thanks and Happy Flying...
Mojo
Hide Signatures
(in reply to Terry Holston)
       Post #: 123
RE: Bob Cat Copy Falcon 120 Jet - 7/16/2007 12:35 AM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: JIMZACH
Hi guys, First flight was UGLY. GMS 120 with the 14x7 three blade is not enough, needs more blade to start with. RPM'S in the air were verry high but no push. Take off took for ever and then shot straight up , landing after cutting power went straight down. I found out on second flight both problems were better wih at least half flaps. For you guy's with JR radios down load BVM data safe program for BOB CAT it will give you basic set up and crow. Next step will be to replace GMS 120 with OS 160, Already ordered pusher pipe from WESTON UK.
Hello Jim, do you need that special pusher pipe that you mentioned or can you just run it with the conventional silencer, I'm not looking to set any speed records or anything like that... Another Question Bud, when you order that OS 160 do they have a different model for the rotation or do you just flip the prop???
Thank You Jim,
Mojo
Hide Signatures
       Post #: 124
RE: Bob Cat Copy Falcon 120 Jet - 7/16/2007 1:29 AM
Kevin Greene
Score: 105
Last Login: 1/21/2013
Status: offline
Flipping the prop just yields less thrust---Prop still works the same way just less efficiently...You need a reversed pitch prop...
Kevin
Hide Signatures
(in reply to Grumman)
       Post #: 125
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.750RCU1
