RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  124 125 [126] 127 128 129 130 131 132 133   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 1/8/2010 6:58 PM
andy boy
Score: 100
Last Login: 4/29/2013
Status: offline
Yes the landing gear mounts as well will be beefed up and got some plywood from super home center. Thanx for the tips (and the oil )
Hide Signatures
(in reply to andy boy)
       Post #: 3126
RE: Bob Cat Copy Falcon 120 Jet - 1/9/2010 9:22 PM
sweetpea01
Score: 103
Last Login: 2/28/2013
Status: offline
CF wingtube showed up today.........Time to finish the slight mod on the wing to allow the tube past the gear. Then I should be able to glass it up.
_____________________________
www.hobbiesxtreme.com
Hide Signatures
       Post #: 3127
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 3:05 PM
vincedecaledo
Score: 100
Last Login: 12/29/2012
Status: offline
hi guys,
i actually finish a falcon 120.....this one will be fited with a kingtech K80............it should fly well !!
unfortunately, my falcon came without manual......so it would be great if someone could give me the center of gravity and the throws allowed to all surfaces...
thanks a lot guys!!
cheers
Vincent from new caledonia
Hide Signatures
(in reply to sweetpea01)
       Post #: 3128
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 3:11 PM
davo580
Score: 100
Last Login: 5/20/2013
Status: offline
cog is 13 inches
Hide Signatures
(in reply to vincedecaledo)
       Post #: 3129
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 4:58 PM
gruntled
Score: 100
Last Login: 3/25/2012
Status: offline
quote:
ORIGINAL: davo580
cog is 13 inches
From . . . . . . ?
Hide Signatures
(in reply to davo580)
       Post #: 3130
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 5:45 PM
vincedecaledo
Score: 100
Status: offline
hi there,
generaly it's from leading edge.....on the fuse.....
what about throws ?
thanks a lot !
Hide Signatures
(in reply to gruntled)
       Post #: 3131
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 6:13 PM
gruntled
Score: 100
Status: offline
On the Boomerangs, Alan gives the CG from the trailing edge, so it is important to be certain. 13" sounds like a long way from the leading edge and you would end up with an aft CG, if you measured it the wrong way.
EDIT - Sounds like this one is from the leading edge:
http://www.rcuniverse.com/forum/fb.asp?m=8815756
< Message edited by Socomon -- 1/12/2010 6:58 PM >
Hide Signatures
       Post #: 3132
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 10:44 PM
vincedecaledo
Score: 100
Status: offline
ok........thanks a lot....
what about throws now?
thanks !!
vince
Hide Signatures
       Post #: 3133
RE: Bob Cat Copy Falcon 120 Jet - 1/12/2010 11:07 PM
tim777jet
Score: 100
Last Login: 5/18/2013
Status: offline
Hi Vince, CG should be 13inchs back from the leading edge, this is perfect.
- control throws, you can do a search on this thread, there is quite a bit of info, but in general, manual gives
- aileron 20 mm each way
- elevator 15 mm each way ( remember the elevator is rigged so its upper surface is in line with the stab upper surface. Do not align the bottom of the stab and the bottom of the elevator. It will look like the elevator is slightly rigged up in this position, this is completely normal)
- Rudder 15mm each way, I use more, around 20mm
- Flaps 20mm down, but I use as much as I can get, to slow her down and come in with a little power on. Most people do this. Use around 10 to 20mm for take off, if you like, doesnt make any real difference for the take off, then everything youve got for landing. If you have a really strong crosswind, (normal for me), then i do not use all the flap, only the 10 to 20 mm to reduce the swing from the wind.
That will get you safely airbourne, then tinker till you fing your sweet spot. I did notice the later Falcon, required a bit more down elevator when pushing through an inverted loop than the older model, dont know why, easy to increase if you need to, but it will fly inverted no probs with the recomended settings. Happy flying, youll love the model. cheers tim
Hide Signatures
       Post #: 3134
RE: Bob Cat Copy Falcon 120 Jet - 1/13/2010 4:12 AM
Gripenflyer
Score: 100
Last Login: 5/23/2013
Status: online
Here you go!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to tim777jet)
       Post #: 3135
RE: Bob Cat Copy Falcon 120 Jet - 1/13/2010 9:28 AM
vincedecaledo
Score: 100
Status: offline
hello guys........
thank you so so much.....
first flight shoud be on sunday...!!
cheers
Vince
Hide Signatures
(in reply to Gripenflyer)
       Post #: 3136
RE: Bob Cat Copy Falcon 120 Jet - 1/14/2010 10:38 PM
madfreestyler
Score: 100
Last Login: 5/3/2013
Status: offline
Hey All,
Ive just started putting the radio / services tray together but if i put the UAT in front of the main tank it is difficult to access the front wing retainer bolts with the tray in place, i notice many of the pics on here are simular. Was just wondering what people have done to workaround it?
Any pointers or pictures much appreciated.
Thanks in advance
I Just Wanna Fly
Hide Signatures
       Post #: 3137
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 12:39 AM
new2jets
Score: 100
Last Login: 1/31/2012
Status: offline
quote:
ORIGINAL: madfreestyler
Hey All,
Thanks in advance
HI i screwed some m6 bolts in to the tee nuts in the wings with the head cut off and a 60 deg tappered cross hole drill in it ( use center drill ) and fix some blocks in the fuz which these go into and the got a six m/m grub screw with a 60 deg point on it which screws into the block and into the tappered hole pulling the wings up no need to go into the fuz down the field just two small holes in the bottom to put the allen key in works great
http://www.rcuniverse.com/forum/m_5913492/mpage_39/key_/tm.htm
note the small allen key holes next to the screw for the hatch
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
I FEEL THE NEED THE NEED FOR SPEED
Hide Signatures
(in reply to madfreestyler)
       Post #: 3138
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 1:03 AM
madfreestyler
Score: 100
Status: offline
Awesome job new, guess i dont need the foremost retainer then looking at your setup. On mine theres a captive nut just forward of where your wires come out of the fuse.
Are you using the std wing tubes or did you upgrade them?
Cheers
I Just Wanna Fly
Hide Signatures
(in reply to new2jets)
       Post #: 3139
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 1:15 AM
new2jets
Score: 100
Status: offline
standard wing tube with dowel epoxyed in it, turned it down to fit inside because its a funny size to get hold of had over100 flights now with supersport at 18+lbs.
mine must be early version had no bolts at the front only at the hatch do you need them at the front ?
Hide Signatures
       Post #: 3140
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 1:20 AM
joeflyer
Score: 105
Status: offline
It depends on which version of the Falcon 120 you have. The early ones had only one bolt per wing. From his picture this is obviously what new2jets has. It sounds like you have the later version with two bolts per wing. Because the wings on version 2 are not as strong as on version 1 I recommend that you use both sets of wing bolts.
On mine I made the equipment tray end just forward of the front wing bolts. The UAT is mounted in the equipment tray forward of the bolts.
Joe
Click for fullsize
Hide Signatures
       Post #: 3141
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 3:31 AM
BaldEagel
Score: 118
Status: offline
There are two solutions to this problem IMO:
1. Don't use a UAT, use an Orbit fabric clunk, I use one in my Elan without a UAT and it works fine.
2. Put the T nut in the fus and the bolt in the wing, hole in the wing to use a ball allen key to do up the bolt, look back in the thread I detained it earlier.
Mike
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to joeflyer)
       Post #: 3142
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 12:31 PM
tim777jet
Score: 100
Status: offline
My Turbine is heavy, so needed the UAT fwd for balance, mine is just behind nose leg. If you have later model you need both wing bolts, front and rear. I use ally cap head screws and made a screw driver with 90 degree bevel gears, so front bolts can be tightened easily, with no fiddling. Rear bolts , I use a ball end allen driver through access hole in bottom of fuse. Rolson, who make all the cheap but usefull tools in the UK, make a 90 degree attachment (in fact its about 80 degrees) which will do the same job, for around 5 pounds.
Hide Signatures
(in reply to BaldEagel)
       Post #: 3143
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 12:43 PM
madfreestyler
Score: 100
Status: offline
Thanks for the replies chaps, think ill do some head scratching and routing over the weekend.
Hey 777 Did you urgade your tubes? Have you got a source in the uk?
I Just Wanna Fly
Hide Signatures
       Post #: 3144
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 1:14 PM
tim777jet
Score: 100
Status: offline
Yes fitted a carbon main tube, use the ally front one. I bought it from Als hobbies, they have a rack of different size tubes, you have to ask some one to go and get a few out and measure up one that is the right size. If you get the right person, they will do that for you, if not they wont bother. The carbon is a fair bit lighter than the ally. If you get a new tube or even if you are using the supplied tube, Make Sure It Fits all the way to the end of both end ribs in the wings, when it is built up. Fit the tube in one wing and fit the wing to the fuse. Draw a pencil line on the exposed tube on side of fuse without the wing. Now pull out the tube and fit it to the other wing. The pencil line should just go into the wing by a couple mm, if it disappears inside, the tube is too short and the wing will not be supported corrected. The newer wings have the ribs positioned @ 1/2 inch further out than the older wing, but they were supplying the wing tube, cut for the older models in te newer models.
If you want a chat, pm me your number, all best Tim
Hide Signatures
       Post #: 3145
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 7:49 PM
duthie
Score: 100
Status: offline
madfreestyler,
I thread locked in 6mm threaded rod into the wing roots and where they come into the fuz, I use 6mm washers and wing nuts. This makes it easier to bolt on the wings without the use of any tools - just make sure you leave enough room in front of the fuel tank to get your hands in. The rear nuts are accessed through the rear fuz hatch.
duthie.
Hide Signatures
       Post #: 3146
RE: Bob Cat Copy Falcon 120 Jet - 1/15/2010 7:53 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: BaldEagel
Mike
Post 2140 on page 86 shows option 2
Mike
Hide Signatures
       Post #: 3147
RE: Bob Cat Copy Falcon 120 Jet - 1/16/2010 8:05 PM
tim777jet
Score: 100
Status: offline
hi Guys, found this collpasable stowage box with wheels. Wheels arent massive, but seem to cope with the rough terain in my back garden admirably. Our flying site moved slightly, so have to walk everything over to the strip in about 4 treks, this should do the job. It folds done to virtually nothing and can handle 25 kgs, (on the box) but i have sat on it no probs. I will make a plate seat to fit on the top of it eventually. Cost was unbelivable, at £9.99. Avail in corner shops and also Homebase, (made by Rolson i think). I can fit, 20liter fueller, large fire extinguisher, aircompressor, Propane starter gas, and tailplane protector in it perfectly, plus you can fit another box on top if required. cheers Tim
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 3148
RE: Bob Cat Copy Falcon 120 Jet - 1/17/2010 7:10 AM
jetflyr
Score: 100
Status: offline
Got my Falcon with the Thanksgiving sale, and finally getting started.
Popped the formers this afternoon. and started stripping the wing to create my own scheme.
Tried in the wing with tube (mine is short...) and then noticed the fit....
The left wing pulls in tight, but this is the best I can get on the right.
Did anyone else have this problem, and if so, how did you fix it...?
The gap is almost 7/16".
Greg
Click for fullsize
Hide Signatures
       Post #: 3149
RE: Bob Cat Copy Falcon 120 Jet - 1/17/2010 9:32 AM
sweetpea01
Score: 103
Status: offline
That looks really bad. You could sand the front of the wing root so it sits more flush and add some to the aft root. I'd probably look at if the wingtube is in the fuse correctly.
I'd see if wingtip to booms is the same distance on each side as well and check your incidence.
Hide Signatures
(in reply to jetflyr)
       Post #: 3150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.844RCU1
