RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  10 11 [12] 13 14 15 16 17 18 19   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 8/20/2007 8:07 PM
wingart
Score: 100
Last Login: 5/12/2013
Status: offline
Justabigkid.
Falcon wing section is flat bottom,which is proberley why its such a stable model.
I have had no problems when flying with this wing section which i believe is clark wy.
I do however need a little down elevator when flying inverted, as this is not a simetrical wing.
The c g is in the correct location.
Regards Wingart.
Hide Signatures
(in reply to wingart)
       Post #: 276
RE: Bob Cat Copy Falcon 120 Jet - 8/20/2007 8:08 PM
wingart
Score: 100
Status: offline
Justabigkid.
Regards Wingart.
Hide Signatures
       Post #: 277
RE: Bob Cat Copy Falcon 120 Jet - 8/20/2007 8:27 PM
Grumman
Score: 100
Last Login: 10/17/2012
Status: offline
Thanks Wing
Mojo
Hide Signatures
       Post #: 278
RE: Bob Cat Copy Falcon 120 Jet - 8/20/2007 9:38 PM
BiGToP
Score: 100
Last Login: 12/30/2009
Status: offline
Hi chaps,
BiGToP and Bigplumbs will be getting their finger out shortly!
I've just been waiting for some parts to arrive and I'll be "commensing" Now.
Regards
BiGToP
_____________________________
ThE BiGToP
Out of my Falcon Mind!
Hide Signatures
(in reply to Grumman)
       Post #: 279
RE: Bob Cat Copy Falcon 120 Jet - 8/21/2007 10:38 AM
jitendra.gurjar
Score: 100
Last Login: 9/11/2011
Status: offline
hi there
how is the performance of the falcon. is the cg right in the manual? i plan to install a 1.08 with a 15*8 would it e ok
Hide Signatures
(in reply to JIMZACH)
       Post #: 280
RE: Bob Cat Copy Falcon 120 Jet - 8/21/2007 11:46 AM
tim777jet
Score: 100
Last Login: 5/18/2013
Status: offline
Can anyone give me the length of the main U/C leg, from the retract unit down to the center of the wheel axle. Thanx Tim
Hide Signatures
(in reply to jitendra.gurjar)
       Post #: 281
RE: Bob Cat Copy Falcon 120 Jet - 8/21/2007 8:01 PM
BiGToP
Score: 100
Status: offline
quote:
ORIGINAL: tim777jet
No measurements to be seen BUT.....I would think that the length of the leg will be demanded by the postistion of your retract base plate and the length of the plastic retract wheel pod?
BiGToP
ThE BiGToP
Hide Signatures
(in reply to tim777jet)
       Post #: 282
RE: Bob Cat Copy Falcon 120 Jet - 8/21/2007 9:43 PM
gooseF22
Score: 103
Last Login: 4/30/2013
Status: offline
quote:
ORIGINAL: jitendra.gurjar
hi there
probably not enough power ...there are posts that a GMS 120 isn't enough...
Goose
Wren Turbines USA, Fromeco
Hide Signatures
       Post #: 283
RE: Bob Cat Copy Falcon 120 Jet - 8/21/2007 11:28 PM
BiGToP
Score: 100
Status: offline
quote:
ORIGINAL: tim777jet
Hi Tim,
I've instaled mine tonight and they come out around 165mm
see build thread over on RC Groups:
http://www.rcgroups.com/forums/showthread.php?t=718236#post8033617
Regards
BiGToP
< Message edited by BiGToP -- 8/22/2007 2:51 AM >
ThE BiGToP
Hide Signatures
       Post #: 284
RE: Bob Cat Copy Falcon 120 Jet - 8/22/2007 5:53 PM
Grumman
Score: 100
Status: offline
Hello Gents!!! Can someone measure the width between the 2 Booms please and give the distance from the engine mount to the ground... I am still away from my plane and I would like to continue to round up all the parts necessary to complete it.... I have everything to turn it into a Wren-54 Turbine Machine but I want to fly it with the Nitro 1.30 first..... PROP SIZE??? is the only issue left...I think the 3 Bladed is the way to go.... 14x10 or 15x8 have been suggested.....
Thanks Mojo
Hide Signatures
       Post #: 285
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 3:31 AM
BiGToP
Score: 100
Status: offline
I've gone for rates on the ailerons to bring it down to 10mm travel rather than in the book it says 20mm. But I have the 20mm travel there if I should need it.
Wingart what have you set yours to. Also have you got flap elevator mix?
BiGToP
ThE BiGToP
Hide Signatures
       Post #: 286
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 1:36 PM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: tim777jet
Hi Tim,
Regards
BiGToP
Hello BigTop!!! Can you please measure the width between the 2 Booms, I am trying to decide which propeller to buy, I am not with my plane at the moment I am at sea... I just purchased a SK 1.30 Nitro engine... I will install my Wren-54 later after I fly the bird with the 1.30 first...
Thanks Mate
Mojo
Hide Signatures
(in reply to BiGToP)
       Post #: 287
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 2:01 PM
gooseF22
Score: 103
Status: offline
Mojo
I read where someone was using a 16x10 on an OS 160. so any prop you run on a 1.3 should be ok.
Goose
Hide Signatures
       Post #: 288
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 2:09 PM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: gooseF22
Mojo
Hello Goose and Thanks for the info... I will try the 16x10 as soon as I can get to my plane, still at sea for 1 more week...
Happy Flying!!!
Mojo
Hide Signatures
(in reply to gooseF22)
       Post #: 289
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 3:19 PM
BiGToP
Score: 100
Status: offline
quote:
ORIGINAL: Grumman
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: tim777jet
Hi Tim,
Regards
BiGToP
Thanks Mate
Mojo
Hi Mojo,
I'll put them together tonight and check for you.
BiGToP
ThE BiGToP
Hide Signatures
       Post #: 290
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 3:41 PM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: Grumman
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: tim777jet
Hi Tim,
Regards
BiGToP
Thanks Mate
Mojo
Hi Mojo,
BiGToP
Thank You BIGTOP!!!
Hide Signatures
       Post #: 291
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 4:45 PM
wingart
Score: 100
Status: offline
Hi bigtop.
I also set rates to 10 and 20, you will soon see you wont use 10 its know where near enough movement .20 is fine and its still not vicious.
I `thought about mixing in elevator with the flaps but after the first flight it became apparent you dont need too.
only the smallest amount off trim change.
i put a small amount off back pressure on the stick this is fine doesnt cause any probs.
This really is one of the easiest planes ive ever flown of any type.
Regards wingart
Hide Signatures
       Post #: 292
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 6:14 PM
gooseF22
Score: 103
Status: offline
Grumman,
I reread your post. If you havent spent the money for an SK 1.3, I would recommend you spend the extra 100 bucks for an OS160 for that 16x10 prop. I just dont think you will be happy with the 1.3 on this heavy of an airplane. I dont think you have the power and speed you want. If you look at the GMS 1.20, its specs are nearly the same, but higher revving motor, and its not enough motor for this plane.
I think most folks would agree you need a hi revving 2 stroke 1.40 or better on this to achieve good dash speed, but have enough power to get off the grass.
Please...anyone else chime in. I know folks are pleased with the OS 160. ...BTW, thats what is going on mine...the 1.60 is sitting in the shop at my buddy's house now. I know you will be happy with that combo. I own a GMS 1.20 too, so I had to bite the bullet and get another motor.
hurry up UPS.....
Goose
Hide Signatures
       Post #: 293
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 7:21 PM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: gooseF22
Grumman,
hurry up UPS.....
Turn & Burn!!! Thanks Goose sounds about right, I already have the 1.30 and I will only have it on the Falcon for a short time just to get the handle of the Bird. It will be my first turbine and I already have the Wren-54 standing-by for it... Can't wait to get to it...Thanks for the input, it all helps...
Happy Flying!!!
Mojo
Hide Signatures
       Post #: 294
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 8:15 PM
454
Score: 100
Last Login: 5/4/2013
Status: offline
where ar you guys putting the gas tank
in the turbine powered versions and are all of the
servo holes standerd size or smaller I was going to use futaba 9650 dig srevos
If you''re not crashing do it lower
Hide Signatures
       Post #: 295
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 9:01 PM
tim777jet
Score: 100
Status: offline
Fitted my tank as far back as poss. Trimmed the frames and slid the tank in. The rear of the tank is flush with the rear spar, and is secured with one tie wrap which fits under the front and rear spars and up and ove rthe tank.
I fitted my breather tube exiting the lower wing surface out board of the the boom, with tube facing fwd, to reduce risk of fuel spill going on engine. The tubes join in the wing root with a fuel filter.
Rudder servos are slightly smaller than standard the 225MGs fit.
Elevator, I think are 225MG size again ( Iused one standard size in the Tailplane)
the flaps and ailerons are standard size,
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to 454)
       Post #: 296
RE: Bob Cat Copy Falcon 120 Jet - 8/23/2007 11:40 PM
congoss
Score: 100
Last Login: 3/7/2013
Status: offline
Just finished my falcon. Need some one to tell me where to balance it.Confused about the book.
Johnahalls@aol.com
Hide Signatures
(in reply to i3dm)
       Post #: 297
RE: Bob Cat Copy Falcon 120 Jet - 8/24/2007 12:07 AM
BiGToP
Score: 100
Status: offline
quote:
ORIGINAL: wingart
Hi bigtop.
Regards wingart
Hi Steve,
Thanx for that, I'll just fly it and see.
If I can fly it as good as it looks on the video's then I'll be laughing A LOT!!
BiGToP
ThE BiGToP
Hide Signatures
       Post #: 298
RE: Bob Cat Copy Falcon 120 Jet - 8/24/2007 1:16 AM
BiGToP
Score: 100
Status: offline
quote:
ORIGINAL: Grumman
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: Grumman
quote:
ORIGINAL: BiGToP
quote:
ORIGINAL: tim777jet
Hi Tim,
Regards
BiGToP
Thanks Mate
Mojo
Hi Mojo,
BiGToP
Thank You BIGTOP!!!
Mojo,
It's 437mm
BiGToP
ThE BiGToP
Hide Signatures
       Post #: 299
RE: Bob Cat Copy Falcon 120 Jet - 8/24/2007 1:32 AM
Grumman
Score: 100
Status: offline
Thank You BigTop!!! Thanks for all the info and pictures...ENJOY!!!
Mojo
Hide Signatures
       Post #: 300
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.422RCU1
