RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
GJC 1/6 Scale F-16 ARF PRO
Seller:  Flynstuff
Details:   $4,400.00   |  5/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  171 172 [173] 174 175 176 177 178 179 180   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 1:56 AM
david101
Score: 100
Last Login: 5/12/2013
Status: offline
Tim-
Thanks for fast reply. I did not have any failure to communicate with the Falcon. It responded to all of my commands. I did have double servos on the elevator. Never any binding issues with radio. Double a123 packs on rec. (no switches) and servos with fresh charge. I suspect either the aileron disconnect on the port wing or possibly a boom failure was causing the sudden attitude change(45* pitch-up on full throttle,stall and spin on low). Can a single aileron disconnect cause such symptoms??????? I was wondering if any one had a structural failure that resulted in these symptoms. No evidence of failure is present in the wreckage. All pieces were present at the crash site.
My next one will have glassed wings and will be a single unit as I can transport it with-out dissassembly.
Fail-safe was set to neutral and idle with cut-off per JetCat specs. A real puzzle.
Cheers,
Dave
Hide Signatures
(in reply to tim777jet)
       Post #: 4301
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 2:24 AM
Woketman
Score: 105
Last Login: 5/18/2013
Status: offline
I think that an aileron clevis failure would not do this. The aileron would simply weather vane and cause a slight trim change: noticeable but nothing you could not easily overcome. That is unless it fluttered. Hinge failure on the aileron could concievably cause some wild flight anomalies, depending on how it moved/jammed. But a 45 deg pitch-up would not likely be an aileron. Was it a symmetric pitch-up? Or rolling hard while pitching?
Sorry this happened.
Hide Signatures
(in reply to david101)
       Post #: 4302
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 3:08 AM
pulsar110
Score: 105
Status: offline
Just a thought but the pitching up makes me wonder about the servos on the elevator. Cant remember if it was this thread a few days ago but in the last week I read somewhere about servo arms coming loose by either cracking or stripping the teeth. Being that it happened the way you described I think thats where I might start. Sorry to hear about this. Its one thing to dumb thumb but really sucks when its hard to explain.
Hide Signatures
(in reply to Woketman)
       Post #: 4303
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 4:41 AM
Aussie1
Score: 100
Last Login: 4/17/2013
Status: offline
Guys, I was just in my workshop preparing my jets for a big local jet fly at the end of this month, and noticed that my single elevator servo on my Falcon was moving alot slower going up than down. I put a lipo on top off the elevater and to my horror, after a few more movements, the servo got stuck in the full UP position!! It was a quality 10kg Hitec that I bought when I built my Falcon. I have now replaced it with a Spectrum 10kg digital metal geared servo, but can't help that think that I have just narrowly missed certain disaster!
Hide Signatures
(in reply to pulsar110)
       Post #: 4304
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 8:55 AM
BaldEagel
Score: 118
Status: offline
Good catch Aussie1, if that had happened in the air it would have been another unexplained crash of a Falcon, blamed on all sort of anomalous things.
One once of maintenance is worth one ton of retrospect.
Mike
_____________________________
No matter what anyone says 100% is the maximum you can get.
Hide Signatures
(in reply to Aussie1)
       Post #: 4305
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 11:09 AM
tim777jet
Score: 100
Status: offline
yes it was my post about the servo arm crack at the splined hub, but with 2 servos on the elevator, it is unlikely that 2 failed at the same time, but one could have failed many flights before and the other took the load on its own for this flight
. David, have you got nylon servo arms and are they ok, no hair line cracks.
_ After reccovery, did you get normal control back. If during the climb you pushed the nose down to level off, and lets say one servo arm was bad for a while, the other has just gone, then a large down load might allow the arm to jump one spline. NOw when you release the down elevator the elevator would be one spline UP giving a large pitch up movement as the elevator neutral is way off now. During the fight to recovery from the spin, with large loads on the elevator might allow the splines to realign in the correct position. All this is speculation, but please check your servo arms and even try forcing them in either direction to see if the arms jump. Mine did, but only in one direction, not the other, worth a look. cheers tim
Hide Signatures
(in reply to BaldEagel)
       Post #: 4306
RE: Bob Cat Copy Falcon 120 Jet - 5/22/2012 3:24 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: tim777jet
Or the boom fixings pulled out on one side, or the tailplane pulled out one side, or both may have pulled out both sides, we will never know unless someone has film of the incident and it can be watched in slow motion.
Mike
Hide Signatures
       Post #: 4307
RE: Bob Cat Copy Falcon 120 Jet - 5/23/2012 12:12 AM
david101
Score: 100
Status: offline
Thanks for input guys. Checked some of your ideas today. Port wing was intact and no evidence of aileron failure. Stab was intact-no damage to servos (hitec 5245 digitals) ,servo arms were metal,push-rods were 4-40 with metal clevices, elevator links were plastic on 4-40 arms and no damage to any or disconnects. did not use any of the hardware in kit. All flight control surfaces on both wings were solid after the crash .
The pitch-up was not a rolling maneuver, it was pretty much straight ahead. My best guess is that with port aileron disconnected (screw partly out????) it caused a vibration that partially broke loose the port boom and caused the problems I mentioned. The port wing, both booms and the stab are reuseable after some repair. Fortunately I ordered another Falcon last week and it arrived 2 days prior to this incident. So lets try again!!!!!! It was a great flyer for 14 flights.
Thanks, again.
Dave
Hide Signatures
       Post #: 4308
RE: Bob Cat Copy Falcon 120 Jet - 5/23/2012 10:42 AM
comstech
Score: 100
Last Login: 5/15/2013
Status: offline
Has anyone got a spare or broken canopy that they would like to sell. I have looked every where and can not find one anywhere the opening on mine is 13 in (333mm) long x 3  1/4 (80mm) in the centre wide and I do have an 8mm lip all the way round.
Hide Signatures
       Post #: 4309
RE: Bob Cat Copy Falcon 120 Jet - 5/23/2012 1:19 PM
damagedgoodes
Score: 100
Last Login: 5/19/2013
Status: offline
I've got the original one from my kit you can have, you pay the postage. PM me if intersted,
Dave
Hide Signatures
(in reply to comstech)
       Post #: 4310
RE: Bob Cat Copy Falcon 120 Jet - 5/23/2012 5:12 PM
noray1
Score: 100
Last Login: 2/21/2013
Status: offline
Check with NORAY for a high quality replasement.
norray9963@att.net
Good judgment comes from experience....
and a lot of that comes from bad judgment...
Hide Signatures
       Post #: 4311
RE: Bob Cat Copy Falcon 120 Jet - 5/27/2012 11:47 PM
Aussie1
Score: 100
Status: offline
Guys, I was clearing files from my laptop and found this excellent PDF on a highly modified Falcon. I hope the original poster doesn't mind me posting it again as it has lot's of good imfo for new Falcon builders.
Click to see the file in new window.Attachment.pdf
Hide Signatures
(in reply to noray1)
       Post #: 4312
RE: Bob Cat Copy Falcon 120 Jet - 5/28/2012 4:13 PM
Grodus
Score: 100
Status: offline
I was not able to get the PDF file to open.
Hide Signatures
       Post #: 4313
RE: Bob Cat Copy Falcon 120 Jet - 5/28/2012 4:22 PM
pulsar110
Score: 105
Status: offline
Grodus, not sure why it didnt open for ya. It worked for me. It was also listed way back, someone might chime in to the post number that it was posted in.
Another thing I found aluminum bolts to replace the nylon bolts with. Got them from Pro Bolt, a bicycle/motorcycle outfit. They have a number of different bolt designs, 2 of which would work for this plane. The Allen Heads were about $1.50 each and the others were $3+ each. I ordered the Allens yesterday and figured I could put washers under the heads and be fine.
Hide Signatures
(in reply to Grodus)
       Post #: 4314
RE: Bob Cat Copy Falcon 120 Jet - 5/29/2012 3:27 AM
Aussie1
Score: 100
Status: offline
quote:
ORIGINAL: Grodus
Grodus, maybe your virus checker is blocking it?
Hide Signatures
       Post #: 4315
RE: Bob Cat Copy Falcon 120 Jet - 5/30/2012 12:33 PM
Dr Honda
Score: 100
Status: offline
Yep.... it opened for me too.
Looks like they did A LOT of work to beef it up. But, I don't like that it's all one piece. Makes it too hard to transport.
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
Hide Signatures
       Post #: 4316
RE: Bob Cat Copy Falcon 120 Jet - 5/31/2012 1:00 AM
edwarda10pilot
Score: 105
Status: offline
Aussie1:
Thanks for the file. I opened it and the guy really did a wonderful job. Gave me some ideas for my next Falcon.
On a related note, I need to see if anyone can help me. I have been flying one of the Nitro Plane Falcon 120's as a Dynamax powered edf. This past weekend I had a midair with a small electric plane. The wings, tail and booms are damaged but repairable however, the fuse is a write off. I need to see if anyone has a new or used Falcon 120 fuse (don't care about color) that they are willing to sell. I will take a used/damaged fuse as long as it is repairable. I have posted in the classified but it was suggested that I also post here.
Ed
Hide Signatures
(in reply to Dr Honda)
       Post #: 4317
RE: Bob Cat Copy Falcon 120 Jet - 5/31/2012 2:28 AM
david101
Score: 100
Status: offline
Generalhobby.com has for sale new Falcons for $169 - 179 +about $50 shipping. I just bought one about 2 weeks ago and looks ok.
Dave
Hide Signatures
(in reply to edwarda10pilot)
       Post #: 4318
RE: Bob Cat Copy Falcon 120 Jet - 6/5/2012 9:38 PM
alasdair
Score: 113
Status: offline
Does anyone else have light-up problems??
I find that my gas-start Wren in my Falcon is often a bit reluctant to start, but an identical engine in my Gripen lights on gas straight away.  The only difference is the engine orientation.
Does anyone else with a gas-start engine in a Falcon have problems with light-up? and if so is the engine mounted with the plug accessible near the top?
Has anyone had to mount their turbine with the plug below the mount to get a reliable start?
Hide Signatures
       Post #: 4319
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 1:08 AM
SLING MT
Score: 100
Status: offline
Hi all.
About to start a build on this bird so I am just starting to get all my bits together. I purchased a fuell cell from Jet-tech wich holds 90oz.
Has anyone else used this tank on their bird and can they give any feedback as it seems large compared to what others are using, also sits more forward than most I have seen. Wandering what affect it will have on cg and set up.  Thanks.
Hide Signatures
(in reply to alasdair)
       Post #: 4320
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 6:40 AM
ticketec
Score: 105
Status: offline
quote:
ORIGINAL: alasdair
My Gas start Wren has not really had any problems at all lighting off the gas while mounted to the airframe, other than the last 2-3 starts but I think I may have a blocked gas manifold problem..... but then again this won't be a problem for the Falcon 120 anymore because I just removed the wren 54 to install a K-80F!
dave
Hide Signatures
       Post #: 4321
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 1:48 PM
Xairflyer
Score: 105
Status: offline
quote:
ORIGINAL: alasdair
Wrens are always fussy on gas the setting of the restrictor on the gas line makes a big difference to reliable starting
www.letterkennymodelflyingclub.com
www.jmaireland.com
Hide Signatures
       Post #: 4322
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 5:12 PM
alasdair
Score: 113
Status: offline
I have taken out the restrictor, along with the gas solenoid valve, in both these models.
I plug in the gas cannister through a non-return valve and turn on the gas manually after the engine's first spin-up.
The Wren in the Gripen always starts on the first whiff of gas, but the one in the Falcon is temperamental on light-up.  Same can of gas, same day, etc.
I don't know whether to invert the engine, or change the plug or what.
Hide Signatures
(in reply to Xairflyer)
       Post #: 4323
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 9:39 PM
jetdeck
Score: 100
Status: offline
to any members, your information, mods, and experience is greatly apreciated, but i want to build it like it was designed to with a glow engine, gone thru like 150 pages, but everyone talks turbines, gee guys have a heart for us poor folks is anyone in the world building it with glow, need to know what engine size, prop size and diameter, 2 blade , 3blade, should i use any up, down, right or left, thrust on engine, when i mount it, how do you run wires from boom inside fuz. do you cut holes in wing werebooms are mounted, got mine few days ago, got the usaf version, no damage anywhere ready to rock and roll appreciate a reply you gus are awsome
Hide Signatures
(in reply to joeflyer)
       Post #: 4324
RE: Bob Cat Copy Falcon 120 Jet - 6/6/2012 10:00 PM
BaldEagel
Score: 118
Status: offline
quote:
ORIGINAL: jetdeck
Who's gus? I'll apply if needed. LOL
Mike
Hide Signatures
(in reply to jetdeck)
       Post #: 4325
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.703RCU1
