RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 6/22/2007 9:07 AM
i3dm
Score: 100
Last Login: 5/22/2013
Status: offline
On that subject, why does the BVM bobcat use so much down thrust angle on its turbine ?
_____________________________
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to ChuckC)
       Post #: 76
RE: Bob Cat Copy Falcon 120 Jet - 6/22/2007 3:14 PM
Woketman
Score: 105
Last Login: 5/24/2013
Status: offline
I have heard that it was due to the higher velocity air going under the horizontal stab due to the turbine exhaust. Said higher velocity air causes higher downward stab lift and, therefore, a nose-up pitching moment. The exhaust downward turbine incidence compensates. I do not know the angle (and Bobcat guys here? Can you add the details?). But I agree: you should tilt the turbine nose-up a few degrees.
Hide Signatures
(in reply to i3dm)
       Post #: 77
RE: Bob Cat Copy Falcon 120 Jet - 6/22/2007 4:16 PM
TCHIEF
Score: 100
Status: offline
does anyone think with the flat bottom stab that it may make a diifference ,im not sure but i would think with that airfoil on it it would produce positive lift on the tail and give a tendancy to push the nose down
could explain the take off jumping (high speed,lift on the tail keeps the nose planted) and when the throttle was cut it dove toward the ground again lifting tail
not sure how that works
Hide Signatures
(in reply to Woketman)
       Post #: 78
RE: Bob Cat Copy Falcon 120 Jet - 6/22/2007 4:22 PM
bruce88123
Score: 108
Last Login: 5/21/2013
Status: offline
quote:
ORIGINAL: TCHIEF
question for the moderater why does it say FL, afghanistan when im in jacksonville fl.
Go to the top of the page where it says "my account" and see if you can fix it.
3-D is for Monster Movies
Hide Signatures
(in reply to TCHIEF)
       Post #: 79
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 7:30 AM
rocketman-RCU
Score: 100
Last Login: 5/14/2013
Status: online
Angel, Where did you buy the OS 45 degree exhaust adapter and the 45 degree curved header for the OS 91? I don't see it in Tower Hobbies. Regards, Gary
Hide Signatures
       Post #: 80
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 7:20 PM
Woketman
Score: 105
Status: offline
"take off jumping (high speed,lift on the tail keeps the nose planted) and when the throttle was cut it dove toward the ground again lifting tail".
That could also be cured by tilting the turbine ala Bobcat.
Hide Signatures
(in reply to rocketman-RCU)
       Post #: 81
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 7:48 PM
rcjets12
Score: 105
Status: offline
I am no expert but to me any time that you have down or up thrust on a turbine or engine you are compensating for some thing in the air frame. I have seen the so called original bobcat fly when it was called the RAMBAT only one made that I know off and the turbine is mounted on straight and it flys very well no up or down tendencies. Also why most of all the other twin booms design don't have the problem of the bobcat. By the way yes I do have a BVM Bobcat and my friend has NP bobcat 50 with no down thrust at 105mph and no pitch up problems like my BVM Bobcat, So be carfull of how much down thrust you put on the NP Falcon you might not need as much if any at all.
Jose
Jose
Global Jet Club
Hide Signatures
       Post #: 82
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 8:03 PM
SinCityJets
Score: 115
Last Login: 5/17/2013
Status: offline
Just an FYI, the King Cat also has built in down thrust.
Hide Signatures
(in reply to rcjets12)
       Post #: 83
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 8:10 PM
Kevin Greene
Score: 105
Last Login: 1/21/2013
Status: offline
With a flat stab airfoil I would think that the problem with the jet exhaust efflux causing a lifting moment of the stab would be magnified...
Kevin
Hide Signatures
(in reply to SinCityJets)
       Post #: 84
RE: Bob Cat Copy Falcon 120 Jet - 6/23/2007 8:14 PM
Kevin Greene
Score: 105
Status: offline
Perhaps the prop versions of this plane will not exhibit the pitching problem due to the way the air is distibuted over and under the stab from the prop and not just totally under the stab as does jet exhaust...At a VERY high velocity I will add...
Kevin
Hide Signatures
(in reply to Kevin Greene)
       Post #: 85
RE: Bob Cat Copy Falcon 120 Jet - 6/24/2007 4:13 AM
Woketman
Score: 105
Status: offline
If the flat side is on the bottom, that would tend to make the stab lift more creating a nose-down pitching moment. The high speed jet eflux would do the opposite. So they should tend to work against one another.
Hide Signatures
       Post #: 86
RE: Bob Cat Copy Falcon 120 Jet - 6/24/2007 8:21 AM
swat1
Score: 100
Last Login: 5/10/2010
Status: offline
What are you going to use to make it electric?
Hide Signatures
       Post #: 87
RE: Bob Cat Copy Falcon 120 Jet - 6/24/2007 9:31 AM
Kevin Greene
Score: 105
Status: offline
quote:
ORIGINAL: Woketman
Yep, you're right--Basic aerodynamics 101..Now I know why you work for NASA!!!
Kevin
Hide Signatures
       Post #: 88
RE: Bob Cat Copy Falcon 120 Jet - 6/24/2007 9:48 AM
TCHIEF
Score: 100
Status: offline
i think ill give it the nasa try if it dont work build anouther
Hide Signatures
       Post #: 89
RE: Bob Cat Copy Falcon 120 Jet - 6/24/2007 11:01 AM
Woketman
Score: 105
Status: offline
If you do decide to tilt the turbine nose-up a bit, ala BobCat, I would start easy. I'd measure a BobCat and use half the angle to start. In other words, if a BobCat has 3 degrees of tilt, I'd go with 1.5 degrees to start. See how it works and adjust from there. Should be easy to change by shimming with washers.
Please let us know.
Hide Signatures
       Post #: 90
RE: Bob Cat Copy Falcon 120 Jet - 6/25/2007 5:33 AM
angelrcdesign
Score: 100
Last Login: 5/20/2013
Status: offline
Sorry
I thought it was OS But its MACs' header. They should help you.
If something fails,try and try again until you get it right.
Hide Signatures
       Post #: 91
RE: Bob Cat Copy Falcon 120 Jet - 6/25/2007 8:23 PM
KHORTON
Score: 100
Last Login: 5/25/2010
Status: offline
Got mine last week. I was looking for a everyday, local field, beater I which would work with my 4 year old Wren 54 (fully manual version). Our runway is only 300 ft aspalt. The smaller Nitro Bobcat was too small however this one seems to be a perfect fit.
Quality of the ARF better than I had anticipated considering the price. A couple of the fuse formers are loose but that is a good thing, because it makes them easier to remove which is necessary to mount the 50oz fuel tank and equipment. In my opinion there are way too many formers anyway. The fiberglass fuse is pretty thick and the wing root is reinforced with a ply doubler. I am also replacing all the plastic bolts w/ metal bolts for the boom and stab attachments. I am doing away with the twin elevator servo setup in favor of a single 9411 mounted in the stab. All of the retract wells/rails are installed and precut ready to accept your retracts. Anybody have their retracts installed yet? I am thinking about Robart 630's
Here are a few pics. I think I just finished the hardest part of the build which was , How to mount the turbine?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to angelrcdesign)
       Post #: 92
RE: Bob Cat Copy Falcon 120 Jet - 6/25/2007 11:02 PM
Todd Jackson
Score: 100
Last Login: 5/23/2013
Status: offline
All my formers were loose also so I pull all of them out except the very front one and the two rear ones with no trouble at all..
I will reglue the remaining ones and I plan on putting in a tray front to rear to mount everything on ..I have started putting Robart 630's in mine but had to make up my own mount for the nose gear because it is a little to wide for the blocks they had and the steering arm will hit the formers that they installed plus it needed to go up inside some so the steering cables would be inside the fuse. Will go to work on the wings next putting the gear in it and overall I am imprested with the plane for what you pay...(Got to get the turbine next).. I am wanting to ad some paint detail and clear it. Anybody know what it is painted with? Will try to post pics tonight....
Todd
Hide Signatures
(in reply to KHORTON)
       Post #: 93
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 12:01 AM
i3dm
Score: 100
Status: offline
For you turbine guys, when are you planning to get this baby air born with a turbine? should be ab wesome combo i believe..
www.liorzahavi.com
Hide Signatures
(in reply to Todd Jackson)
       Post #: 94
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 12:20 AM
KHORTON
Score: 100
Status: offline
Todd, How about a few pics of the retract installation. What is the lenght of the strut?
Hide Signatures
(in reply to i3dm)
       Post #: 95
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 1:07 AM
Todd Jackson
Score: 100
Status: offline
I will have to adjust them for this jet they were in a t-28 plus I will wait till I have the mains in to set the length because I think it needs a little nose high attitude for takeoff roll. Will post pics tonight.
Todd
Hide Signatures
       Post #: 96
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 3:35 AM
DAVID WILDE
Score: 103
From: COLCHESTER,ESSEX,CO3 4DF. U.K., UNITED KINGDOM
Status: online
I have built and flown the smaller 46 bobcat with wren 44 gold and i have 5 degrees of down thrust which i will be doing the same to the falcon 120. I believe the bobcat has about 7 degrees of down thrust.The reason for this amount of down thrust is two fold ,one so you don't burn your lovely covering but i suggest you ali tape it and secondly the increased thrust velocity under the flat bottom tailplane if was dead straight increases pressure under the taiplane giving a tail up tendency hence the reason for the down thrust to decrease this pressure and reduce pitching down tendencies.
David Wilde COLCHESTER A1 MODELS UK SELLER OF THESE MODELS
Click for fullsize
Hide Signatures
       Post #: 97
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 5:16 AM
figueroa
Score: 100
Status: offline
Nice install ,
Looks like the wren 44 is a perfect size for the airframe.
JetCat P120, JetCentral Super Eagle, Jet Legend L- 39
Boomerang XL II, Futaba 14mz 2.4 ghz
Hide Signatures
(in reply to DAVID WILDE)
       Post #: 98
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 7:54 AM
Todd Jackson
Score: 100
Status: offline
Here are some pics but having to do them one at a time for some reason..Todd
Click for fullsize
< Message edited by Todd Jackson -- 6/26/2007 8:10 AM >
Hide Signatures
(in reply to figueroa)
       Post #: 99
RE: Bob Cat Copy Falcon 120 Jet - 6/26/2007 8:00 AM
Todd Jackson
Score: 100
Status: offline
more... well 2 worked I will try for 3...
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 100
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.902RCU1
