RE: Bob Cat Copy Falcon 120 Jet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
MBA Tornado V3
Seller:  Modellbau USA
Details:   $380.00   |  5/11/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Bob Cat Copy Falcon 120 Jet
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Bob Cat Copy Falcon 120 Jet - 7/16/2007 2:38 AM
Grumman
Score: 100
Last Login: 10/17/2012
Status: offline
quote:
ORIGINAL: Kevin Greene
Flipping the prop just yields less thrust---Prop still works the same way just less efficiently...You need a reversed pitch prop...
Kevin
Right without changing the rotation...
Mojo
Hide Signatures
(in reply to Kevin Greene)
       Post #: 126
RE: Bob Cat Copy Falcon 120 Jet - 7/16/2007 5:39 AM
knowcrash
Score: 100
Last Login: 4/11/2010
Status: offline
any flight reports yet?
Hide Signatures
(in reply to Grumman)
       Post #: 127
RE: Bob Cat Copy Falcon 120 Jet - 7/17/2007 8:11 PM
Todd Jackson
Score: 100
Last Login: 5/23/2013
Status: offline
Johnny,
Did we fly this weekend????
Todd
Hide Signatures
(in reply to knowcrash)
       Post #: 128
RE: Bob Cat Copy Falcon 120 Jet - 7/19/2007 7:28 AM
BuschBarber
Score: 104
Last Login: 5/24/2013
Status: offline
What about a Jetcat P80? That is all I have!!!
_____________________________
Rich
byronf16@gmail.com
Hide Signatures
(in reply to Todd Jackson)
       Post #: 129
RE: Bob Cat Copy Falcon 120 Jet - 7/20/2007 12:55 AM
Todd Jackson
Score: 100
Status: offline
Thats what I am doing.Todd
Hide Signatures
(in reply to BuschBarber)
       Post #: 130
RE: Bob Cat Copy Falcon 120 Jet - 7/21/2007 5:51 PM
MattyC-130
Score: 100
Last Login: 12/5/2010
Status: offline
I got one. I already have 2 50 bobcats with Tower 75s and they fly great. I am putting a new JetJoe JJ1400 full auto start on mine.
Other components:
- Robart 712 retracts
- Euro oleo struts
- Trim wheels and brakes
- 2 2200 Lipos one for receiver and one for ecu/pump/starter
- 8 Tower digital high torque MG servos in elv rdrs airls and flaps
- FMA copilot 8 ch fail safe receiver( I use a Polk radio system so need fail safe for turbine cut off)
- Fail safe switch with 6v regulator
some mods so far:
- Nose gear will retract forward (filled hole behind mounting plate
- new blind nuts in tail booms for steel cap bolts trash nylon bolts
- Aluminum turbine mount made out of L brackets
- will use glassed 2 Liter coke bottle for fuel and 4 oz UAT
Will update on build and first fly
Matty
Hide Signatures
       Post #: 131
RE: Bob Cat Copy Falcon 120 Jet - 7/21/2007 6:41 PM
i3dm
Score: 100
Last Login: 5/22/2013
Status: offline
Where can i see those trim wheels and brakes online ?
www.liorzahavi.com
www.youtube.com/i3dm
Hide Signatures
(in reply to MattyC-130)
       Post #: 132
RE: Bob Cat Copy Falcon 120 Jet - 7/21/2007 8:40 PM
highhorse
Score: 116
Status: offline
quote:
ORIGINAL: DAVID WILDE
I have built and flown the smaller 46 bobcat with wren 44 gold and i have 5 degrees of down thrust which i will be doing the same to the falcon 120. I believe the bobcat has about 7 degrees of down thrust.The reason for this amount of down thrust is two fold ,one so you don't burn your lovely covering but i suggest you ali tape it and secondly the increased thrust velocity under the flat bottom tailplane if was dead straight increases pressure under the taiplane giving a tail up tendency hence the reason for the down thrust to decrease this pressure and reduce pitching down tendencies.
David Wilde COLCHESTER A1 MODELS UK SELLER OF THESE MODELS
Nope, sorry. Plz no offense but you've got it exactly backwards.
Increased velocity across a surface decreases the pressure, pruducing "lift" on that side of the surface. That's Bernoulli's principle. It's how carburetors work. And sprayguns. And wings.
http://hyperphysics.phy-astr.gsu.edu/hbase/pber.html
So the high velocity airflow under the stab DECREASES pressure, causing a nose-up pitching moment. The Reaction 54 jet has same issues, fixwd same way.
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to DAVID WILDE)
       Post #: 133
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 12:08 AM
SinCityJets
Score: 115
Last Login: 5/17/2013
Status: offline
Johnny,
You get that thing in the air yet??
Hide Signatures
(in reply to highhorse)
       Post #: 134
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 3:46 AM
swat1
Score: 100
Last Login: 5/10/2010
Status: offline
Anyone do an electric one yet?
Hide Signatures
(in reply to SinCityJets)
       Post #: 135
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 4:41 AM
avicom
Score: 100
Last Login: 3/21/2012
Status: offline
quote:
ORIGINAL: i3dm
Rigth here: http://s43500.sites99.storefront-hosting.com/default.aspx Click on weels and brakes in the left side menu.
Rgs
Team Jet Central
Hide Signatures
(in reply to i3dm)
       Post #: 136
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 4:43 AM
MattyC-130
Score: 100
Status: offline
Trim wheels and brakes at Great Northern Models
Here is the link:
Hide Signatures
(in reply to i3dm)
       Post #: 137
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 9:47 PM
Eric Banner
Score: 100
Last Login: 5/5/2013
Status: offline
Hi Guys,
Steve Hart maidened his Falcon today at RAF Honington. All went well. thought you'ed like a few photos...
Eric
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 138
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 9:58 PM
Eric Banner
Score: 100
Status: offline
Second flight of Steve's Falcon was by Keith Whiddett.
Keith will shortly be reviewing a Falcon 120 in RCJI. Get your copy on order!
Pictures from the second flight...
Eric
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Eric Banner)
       Post #: 139
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 11:03 PM
i3dm
Score: 100
Status: offline
Which engie was Steve using ?
Can you provide more info like:
- which fuel tank flight times ?
- which retracts ?
- which mods has he done ? how is the elevator servo mounted ?
etc etc..any info would be great !
< Message edited by i3dm -- 7/22/2007 11:12 PM >
www.liorzahavi.com
Hide Signatures
       Post #: 140
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 11:37 PM
Eric Banner
Score: 100
Status: offline
Don't have too much info...
Engine is the trusty MW54 Mk3 mounted with 5 deg down-thrust. No burning of the stabiliser occurred. Indeed the stabiliser was completely unmarked. Steve had taken the precaution of covering the lower surface with aluminium tape.
Control movements were as the instructions and were O.K.
Retracts were the supplied Graupner units.
3mm control rods and clevises were used throughout. Kavan pinned hinges were used.
The two elevator servos are mounted as the book but with a standard Y lead - opposite side servo arms are used.
The stall when it eventually came was a very gentle nose drop. The Falcon almost came to a halt before stalling in the 5 to 8 mph headwind.
Very little down was needed for inverted flight.
Both pilots reported that it’s a “****cat” to fly.
HTH
Eric
quote:
ORIGINAL: i3dm
- which retracts ?
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to i3dm)
       Post #: 141
RE: Bob Cat Copy Falcon 120 Jet - 7/22/2007 11:54 PM
Grumman
Score: 100
Status: offline
Thank You for the pictures guys really good shooting, always good to see some great shots. Great photographer like to see some of your video work. I can't wait to get a Falcon 120 I also have the Wren MW54 MKlll... Sound like it handled the job just fine... Looking forward to any new material on the flight...
Thanks Again Guys!!!
Happy Flying!!!
Mojo
< Message edited by Grumman -- 7/23/2007 10:03 AM >
Hide Signatures
(in reply to i3dm)
       Post #: 142
RE: Bob Cat Copy Falcon 120 Jet - 7/23/2007 5:20 AM
MattyC-130
Score: 100
Status: offline
I am building one with a JJ1400.
Eric, what servos did you use?
Hide Signatures
       Post #: 143
RE: Bob Cat Copy Falcon 120 Jet - 7/23/2007 11:47 AM
E.Banner
Score: 100
Last Login: 4/21/2009
Status: offline
Hi MattyC-130,
Steve used HS225's on elevators and JR811's on ailerons and flaps.
Eric
quote:
ORIGINAL: MattyC-130
Hide Signatures
       Post #: 144
RE: Bob Cat Copy Falcon 120 Jet - 7/23/2007 6:51 PM
jonkoppisch
Score: 106
Status: online
A good plane to make would be a similar design to the baby boomer. Have one slighty smaller for the ram 500/jj 1200 series, one the same size as the baby boomer, monokote and also a composite version. If nitro could do the composite for $350 then!!!!!!!!!!!!!!!
"Washington in their infinite wisdom has lost their marbles"
Pappy Boyington
Hide Signatures
(in reply to E.Banner)
       Post #: 145
RE: Bob Cat Copy Falcon 120 Jet - 7/24/2007 2:39 AM
Grumman
Score: 100
Status: offline
Hello Guys!!! Can you provide the AUW of the ready to fly model please???
Thank You,
Mojo
Hide Signatures
(in reply to i3dm)
       Post #: 146
RE: Bob Cat Copy Falcon 120 Jet - 7/24/2007 4:22 AM
i3dm
Score: 100
Status: offline
jonkoppisch , dont forget these guys dont make jets, this is after all - a prop plane.
So guys, is this the ultimate turbine trainer at about 300$ for an ARF ?
www.liorzahavi.com
Hide Signatures
       Post #: 147
RE: Bob Cat Copy Falcon 120 Jet - 7/24/2007 10:42 AM
wingart
Score: 100
Last Login: 5/12/2013
Status: offline
Hi Guys
Iam Steve Hart, The all up wieght of my falcon was 13 pounds dry.
The fuel tank is 1500cc durobo turned on its side,with a 6oz hopper tank for a air trap.
Flight time with the Wren 54 MK3 is a good 7minuets with go round fuel too spare.
And for the money its fantastic value.Iam very pleased with mine so far.
Will try yoo post some video in the next few days.
Hide Signatures
(in reply to i3dm)
       Post #: 148
RE: Bob Cat Copy Falcon 120 Jet - 7/24/2007 12:57 PM
Grumman
Score: 100
Status: offline
quote:
ORIGINAL: wingart
Hi Guys
Thank You Steve for the information sounds great... As far as the landing gear goes I guess I can figure for an up to 18 lbs. model, should be fine...
Thanks Again and Happy Flying... Can't wait to see the video...
Hide Signatures
(in reply to wingart)
       Post #: 149
RE: Bob Cat Copy Falcon 120 Jet - 7/25/2007 2:02 AM
wingart
Score: 100
Status: offline
Here is a short video of the Falcon 120 in action on her second flight......................... Hope you enjoy
http://media.putfile.com/Falcon-120-Wren-54
PS Had 7 flights in total now and just gets better all the time !
Regards
Steve Hart
Hide Signatures
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.906RCU1
