renglishjr
Joined: 2/12/2007 From: Omaha, NE, USA Status: offline
Did you ever get this issue worked out? I have the same problem with mine, though possibly a bit more pronounced. With the nose level, my Katana 46 will not slow down at all without the nose dropping like a brick (though it will harrier nicely). When carrying a bit of forward speed the plane flys beautifully upright and inverted, but slowing it down produces a pronounced drop of the nose - so much so that it can be almost impossible to get it back to the field in a dead stick situation. I moved my CG a half an inch aft of the suggested 5 1/4" and added down thrust to the motor and saw no improvement. As a side note, I just put together the same ARF (though I believe a little older kit) for another member of our club and found that his flew flawlessly. Landings were an absolute pleasure with no tendancy to drop as I was able to bring the plane to almost a standstill with the nose fairly level pointing into a light wind. I was thinking that maybe a heavier motor could cause this kind of change, but upon investigation found that my motor weighed almost 1 OZ less than his. Any suggestions?
