TURBINE    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> TURBINE
Page: [1]
Login
TURBINE - 6/2/2007 1:39 AM
white death
Score: 100
Last Login: 6/14/2007
Status: offline
hello I'll built an A-7 corsair II made of polyester and I want to use it with turbine, but I have a ploblem. The turbine will be homemade I know how to built a tourbine but I don't know what material I must use. Can anyone tell me what I should use and how I can work whith it ?
thank's a lot whitedeath.
Hide Signatures
       Post #: 1
RE: TURBINE - 6/2/2007 9:05 AM
AERORICH73
Score: 115
Last Login: 5/10/2013
Status: offline
Hi White: I believe you will find that the turbine blades are made of tungsten, with the rest of the assembly made out of stainless steel. Both of these materials are difficult to work with. Purchasing a factory made turbine within your budget would be a far better idea.
Richard Scherer BSIT
Retired Aircraft Mechanic
HORIZON AIRLINES
Portland, Oregon
Hide Signatures
(in reply to white death)
       Post #: 2
RE: TURBINE - 6/2/2007 3:27 PM
Flying freak
Score: 100
Last Login: 8/27/2012
Status: offline
I would think asking this in the jet forum would get you alot more replies umm turbions are complicated machines and myself dont trust my work for 20 ooo rpm let alone 160 000 rpm
Hide Signatures
(in reply to AERORICH73)
       Post #: 3
RE: TURBINE - 6/2/2007 5:28 PM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
If you have the capability to make a Turbine, and you succeed in doing so, PLEASE don't let anyone near it when you test it!
And one more thing... Polyester melts
_____________________________
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
(in reply to Flying freak)
       Post #: 4
RE: TURBINE - 6/2/2007 7:28 PM
Ed Smith
Score: 113
Last Login: 5/23/2013
Status: offline
Minnflyer,
I truly wanted to say something in a similar vein. I decided to let somebody else get into trouble.
Ed S
Hide Signatures
(in reply to MinnFlyer)
       Post #: 5
RE: TURBINE - 6/2/2007 11:36 PM
TFF
Score: 148
Last Login: 5/25/2013
Status: offline
I think turbine blades are made of titanium. The early turbine kits and home builds used turbocharger compressor and turbine wheels; now they make them to their own specs. the big thing is controling the fuel. there are kits out there to make your own
Hide Signatures
(in reply to Ed Smith)
       Post #: 6
RE: TURBINE - 6/3/2007 1:38 AM
khodges
Score: 126
Last Login: 2/18/2011
Status: offline
quote:
ORIGINAL: Ed Smith
Minnflyer,
Ed S
Well, two people said something about it, why not three. My thoughts were, if you KNOW how to build a turbine, then you'd also KNOW what kind of materials to use.
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
Hide Signatures
       Post #: 7
RE: TURBINE - 6/3/2007 3:12 AM
allanflowers
Score: 105
Status: offline
I was wondering if he actually meant "ducted fan"? Even then, it would be far better to buy one.
Hide Signatures
(in reply to khodges)
       Post #: 8
RE: TURBINE - 6/3/2007 4:54 AM
khodges
Score: 126
Status: offline
Got an interesting PM from our thread starter, saying as how I was rude, etc to say what I did in post #7 above. I stand by what I said. If a carpenter knows how to build a house, he knows he uses wood, and what kind works best for a given structure. Same goes for any engineer. As in my reply to his PM, I'd like to see whatever he comes up with, a video of it in operation would be great.
Hide Signatures
(in reply to allanflowers)
       Post #: 9
RE: TURBINE - 6/3/2007 7:26 AM
Square Nozzle
Score: 105
Last Login: 5/24/2013
Status: offline
Search through some of the turbine manufacturer pages like Jet Cat, PST, Wren, SimJet etc. I think you'll find that the turbine blades are typically cast Inconel. Tough stuff and more heat resistant than lower grade steels, titanium and aluminum.
< Message edited by John Palica -- 6/4/2007 5:04 PM >
John
Hide Signatures
       Post #: 10
RE: TURBINE - 6/3/2007 4:03 PM
Ed Smith
Score: 113
Status: offline
khodges byline
What other trouble can you get into? Easy, just respond to a dubious Turbine builder.
Ed S
Hide Signatures
       Post #: 11
RE: TURBINE - 6/3/2007 5:02 PM
MinnFlyer
Score: 390
Status: offline
I got that PM too. If saving lives is being rude, I'll be rude.
Hide Signatures
       Post #: 12
RE: TURBINE - 6/4/2007 8:18 AM
nitrohog
Score: 100
Last Login: 5/1/2011
Status: offline
Unless you're doing one of those "convert a turbo into a turbine" kits, which will be heavy, I don't see any reason to even attempt to build something like this. The cost in tooling, balancing, casting, and materials will BY FAR exceed the savings over buying a quality specific built engine. The safety factor is a big thing in my eyes, just think if a little kid rode by on his bike, or something like that when this thing decides to have a hot start and come apart. Shrapnel will literally fly everywhere injuring, or killing anyone or anything in the area. IMHO its just not worth it. Unless your working in a huge machine shop with millions of dollars worth of tooling and you have a engineering degree to back this thing up, PLEASE leave something like this to the pros. Let your conscious be you guide.
Hide Signatures
       Post #: 13
RE: TURBINE - 6/4/2007 4:30 PM
Ed Smith
Score: 113
Status: offline
Maybe, just maybe, he is trying for the 2007 Darwin trophy!
Ed S
Hide Signatures
(in reply to nitrohog)
       Post #: 14
RE: TURBINE - 6/4/2007 5:08 PM
DelRay
Score: 100
Last Login: 2/24/2013
Status: offline
When this post first started, I myself thought "if one knows how to make a turbine, one should know the materials needed". I was going to reply with those very words, but I felt it might offend the person making the post, even though that's the bottom line. Possibly this post was started for a reaction rather than information. Either way, I feel that no-one here meant to offend or had rude attitudes in their responces.
AMA # 173709 Have traveled to the East
I.M.A.A. # 4971 Nosen 310 club # 6
Hide Signatures
       Post #: 15
RE: TURBINE - 6/4/2007 5:10 PM
Steve Collins
Score: 100
Status: offline
White Death,
Go here for the information you need:
http://www.gtba.co.uk/
Steve Collins
Hide Signatures
       Post #: 16
RE: TURBINE - 6/4/2007 9:16 PM
white death
Score: 100
Status: offline
likely there are persons who answere in my questions without judge them
thank's to those people
< Message edited by white death -- 6/4/2007 9:22 PM >
Hide Signatures
(in reply to Steve Collins)
       Post #: 17
RE: TURBINE - 6/5/2007 1:00 PM
j.duncker
Score: 121
Last Login: 5/22/2013
Status: offline
This is a good book to start with.
Gas Turbine Engines for Model Aircraft
Kurt Schreckling, Keith Thomas
<--Amazon.com: 108 pages, Traplet Distribution USA Ltd. (December 6, 1994)
<--Amazon.co.uk: 108 pages (November 1994), Traplet Publications
A reader, UK, November 2, 2001
Great book if you want to build a small gas turbine
If you want to build a gas turbine then this book is for you. It gives you all the information on how to build and run the engine along with equations on working out the stresses etc. The engine can easily be built using a lathe, pillar drill and scrap metals.
But the way I beleive that at least one of the early engines had a wood based compressor fan.
The dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
