Multiplex mixing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Multiplex mixing
Page: [1]
Login
Multiplex mixing - 6/2/2007 8:00:54 PM
jrplane
Status: offline
I need help with mixing:
rudder to ailerons, rudder to elevator. I have a 35% edge and I want to mix the coupling away for knife edge flight. I have wore the buttons out trying to figure it out on my own. I have the standard ailerons on 2 and 6, elevator on 3 and 8, rudder on 4. The plane flys great, I just can't fine tune it!
I have the tutorial and the manual. Neither are much help. They seem to be heli and glider friendly., Not for airplanes.
I have the Evo 12.
Help Please!
Jeff
< Message edited by jrplane -- 6/4/2007 12:59:12 AM >
_____________________________
fast is good
       Post #: 1
RE: Multiplex mixing - 6/4/2007 5:53:41 PM
tohm
Status: offline
You need to create two new mixes. Create one for the elevator and name it elev++ or something along those lines. Then create one for the ailerons with a similar name (ail++).
For the elevator mix, on line one, add elevator and make it asynchronous. On line two add rudder, the next column add mix1 and make it asynchronous also.
For the aileron mix, on line one add ailerons and make them synchronous and line two add rudder with the same settings as the elevator mix.
Go into the setup menu and assign Mix1 to a switch, whichever is not currently being used will work.
In the assignments, assign the two mixes to the elevator and aileron channels respectively.
In the mixes menu, add values to the columns. This will depend on your setup so all I can say is set the elevator and ailerons arbitrarily to 100% and the rudder to -50%. Work on the settings until you get the values you need.
If you need other features within the mixes (flaps, spoilers, etc...) add them during the creation of the mixes.
Tony Ohm
Hitec / Multiplex USA
Tony Ohm
Hitec/ Multiplex USA
(in reply to jrplane)
       Post #: 2
RE: Multiplex mixing - 7/24/2007 9:49:36 PM
Bo Ingram
Status: offline
tohm...is there a Multiplex EVO suppory thread? I have the EVO 12...had it for two years. Need mixing help and would like to see a regular support thred.
Bo
(in reply to tohm)
       Post #: 3
RE: Multiplex mixing - 7/25/2007 7:06:35 PM
MikeMayberry
Status: online
Go here: http://www.rcgroups.com/forums/showthread.php?t=356549
Mike.
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to Bo Ingram)
       Post #: 4
RE: Multiplex mixing - 2/11/2008 12:45:05 AM
Joser95
Status: offline
how can i do mix for my nemesis slope i need flaps with elevator and ilerons or butterfly mix which chanel numbers, and the process to mixed i only have 12 years my radio sistem is a royal evo 9 where and were can i find readings for this radio others than the manual, wich internet pages are related.thanks
       Post #: 5
RE: Multiplex mixing - 2/11/2008 6:59:20 PM
MikeMayberry
Status: online
I would strongly suggest you ask this question in the forum I had a link to in the previous post.
Mike.
Hitec RCD Rep
(in reply to Joser95)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
