balancing wires
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> balancing wires
Page: [1]
Login
balancing wires - 6/2/2007 9:03:47 PM
zip80
Status: offline
My batteries balancing wires are one black and three red wires in a row,can I use any balancer with this batteries wiring configuration
       Post #: 1
RE: balancing wires - 6/3/2007 9:36:04 AM
mrasmm
Status: offline
well there is a bit more to it than that. What brand of lipo are you using?
basically the balancer has to have a compatible balance end, and it also has to match the polarity. Balancers like the blinky just have metal rods that stick out, so they are compatible with just about anything except TP PQ and the sort unless you buy an adaptor, but you have to make sure you hook up the pack the same every time.
_____________________________
I don't always check every thread I respond to, so feel free to PM me
(in reply to zip80)
       Post #: 2
RE: balancing wires - 6/3/2007 2:58:36 PM
zip80
Status: offline
I have a Mega Power 11.1V 3S 20C 2100mAh LiPo battery from Helidirect.Thank you for your response
(in reply to mrasmm)
       Post #: 3
RE: balancing wires - 6/3/2007 11:11:12 PM
mrasmm
Status: offline
yeah, no problemo. The thing is I don't have that in my list of batteries. but the good news is the website says it has an align connector and polarity. I would still double check it to make sure
http://www.helidirect.com/product_info.php?cPath=31&products_id=2145
now with that said there are alot of balancers you can use, the equinox, the hyperion, align chargers, cellpro charger, blinky ect ect You could even use the esky or eflite chargers if you wanted to go real cheap and didn't mind about a 4 3 hour charge time =P
if you already have a charger most balancers are right around 30 bucks. If you don't plan on going more than 5s then I would recommend the equnix for $30, and if you do plan on going more then I would get the lba hyperion 10 and get 2 of them. I personally don't like the blinky because it is just an IC that is covered with clear heat shrink and you have to remember each time to check the polarity and get it right or you'll fry something. Other balancers once you get it right once then that's all you have to do because unless you really force it you can't put it in backwards
(in reply to zip80)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU2
