Ringmaster S1A plans
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Control Lines >> Ringmaster S1A plans Page: [1]
Login
Ringmaster S1A plans - 6/2/2007 11:52:22 PM
green river rc
Status: offline
Where can I find plans for this plane? My Grandfather and I use to fly one years ago and I was wanting to take a strole down memory lane. We had an OS .35 FP on ours, is this to much engine? What about a Brodak .25 or OS LA .25? There is a kit on eBay but I have plenty of materials for building it from plans.
_____________________________
With the parts left over, I'm going to build a motorcycle.
       Post #: 1
RE: Ringmaster S1A plans - 6/4/2007 1:30:18 AM
gcb
Status: offline
Most people build the S-1 over the S-1A because it is OTS eligible. If you can't find S-1A plans, perhaps you can modify the S-1 plans. I know the "A" used LE sheeting and a plastic canopy. Not sure of other changes or "improvements". BTW, the kit came with isometric views and assembly instructions so you could not use the plans to build from.
Good luck.
George
(in reply to green river rc)
       Post #: 2
RE: Ringmaster S1A plans - 6/4/2007 9:40:45 PM
green river rc
Status: offline
I have been told it's not a very good plane, it has no flaps.
(in reply to gcb)
       Post #: 3
RE: Ringmaster S1A plans - 6/4/2007 10:20:45 PM
da Rock
Status: online
quote:
ORIGINAL: green river rc
Actually, that's not very good advice. It really doesn't need flaps to do what it can do. And it can do adequate square turns quite nicely. That is, if either the pilot knows to fly the airplane, not just yank the handle for the square turns. The Ringmaster has always suffered from having builders set up the elevator so it'll go 90degrees up/down, and then being flown using all that movement. They're often flown that way by beginners.
Rig the linkage so it takes a fair amount of handle to deflect the elevator and the sucker flies great. And makes one fine trainer. Setup the linkage too fast and it's a marginal trainer. And the people saying it isn't good because it doesn't have flaps probably setup theirs too fast.
       Post #: 4
RE: Ringmaster S1A plans - 6/5/2007 12:53:38 PM
Larry S
Status: offline
I totally agree,
I have built several C/L planes and the ringmaster is one of the best. It was the one I first learned on over 40 years ago and it was still flying until a year ago when I crashed it beyond repair. Since then I bought another one on EBay. It is still new in the box and still wrapped in plastic, never opened. If somoene doesn't come up with plans, I will go ahead and open it and copy the plans for you. Your cost will be the price of a copy and mailing.
Larry
PS: The kit I have is the Sterling models Ringmaster 35 Pro by Estes. By the picture on the box, it looks exactly like the older version S1 Sterling models had.
< Message edited by Larry S -- 6/5/2007 1:05:19 PM >
(in reply to da Rock)
       Post #: 5
RE: Ringmaster S1A plans - 6/5/2007 5:42:12 PM
Jim Thomerson
Status: offline
Here is a site for you. Looks like you have to register to be able to log in. http://www.brotherhoodofthering.info/flightline/logon.asp?error=needregistration
Lots of foks flying Ringmasters and having fun.
(in reply to Larry S)
       Post #: 6
RE: Ringmaster S1A plans - 6/7/2007 2:58:55 PM
PipeMajor
Status: offline
None of the designs of that era had flaps. For a 56 year old design, it does pretty well.
I've had a half dozen Ringmasters. An S-1a version with the venerable Fox 35 was one of the best flying models I've ever piloted.
       Post #: 7
RE: Ringmaster S1A plans - 6/7/2007 3:07:53 PM
Jim Thomerson
Status: offline
Most did not have flaps; however, the Sterling Yak and Mustang of the same era had flaps, as did several older designs: Nobler and Chief for example.
In PAMPA Old Time Stunt there is a 10 point no-flap bonus. I would like to build a British design called Lil' Abner. It has flaps maybe 1/2 inch wide and I can't decide if I fly well enough that losing 10 points is no problem, or if I fly so poorly that losing 10 points would nt be noticed.
(in reply to PipeMajor)
       Post #: 8
RE: Ringmaster S1A plans - 6/7/2007 5:15:14 PM
green river rc
Status: offline
I'm going to order the S-1 plans and build it while I'm off for a week this summer
(in reply to Jim Thomerson)
       Post #: 9
RE: Ringmaster S1A plans - 6/8/2007 1:38:28 AM
vauxhall
Status: offline
I fly a SIG Akromaster, without flaps. It's performance never ceases to amaze me. Great little plane with only 34" span, powered by an OS.15FP, 8x5 prop and 50' lines.
Click to see fullsize image.
Click for fullsize
       Post #: 10
RE: Ringmaster S1A plans - 7/24/2007 6:49:00 PM
TGC
Status: offline
Did you " git 'er done?"
I also ran across this source for plans: http://www.clstunt.com/plans.htm
Sterling Ringmaster S-1. Mat Kania's OT legal classic flapless profile stunter as originally kitted by Sterling, 1952. This was the biggest selling kit of all time. 42 inch span. 381 square inches. For 20-35 size engines. AutoCAD plan showing all ribs and pieces. One sheet 34 x 43.
Original Ringmaster. NOT THE PROFILE. Harry Williamson's full bodied, non-flapped Old Time style stunter. 40 inch span, straight wing, with sheeted leading edge. Low wing with upright engine makes it somewhat top heavy. Original had SIG canopy and was powered by Fox 35. Plan shows all formers. One sheet 24 x 44.
Sterling P-51 Mustang. Full-scale plan of the Sterling S-2 kit. 38 inch span, profile with coupled flaps for .19 to .35 size engines. An excellent flyer that turns tight when built straight. On sheet, 24 x 45 inches. (Somebody wanted flaps? ... BTW, back then, Sterling also had the matching combat adversary to this one for you, the YAK-9)
Best of Luck to you!
TOM ~ AMA1940
       Post #: 11
RE: Ringmaster S1A plans - 7/24/2007 7:18:07 PM
TGC
Status: offline
Ooooops! ... I guess I can't edit my post here ...
The YAK-9 was Sterling Kit S-3 ! ... At that time, during the Korean "Conflict" , Sterling representatives toured the country with S-2 & S-3's popularizing a new sport known as Control Line Combat Flying.
(If it weren't for flashbacks, I'd probably have no memory at all left ... )
TOM ~ AMA1940
(in reply to TGC)
       Post #: 12
RE: Ringmaster S1A plans - 7/25/2007 2:01:44 PM
gcb
Status: offline
Additional thought on flaps:
The whole purpose of using flaps is to create more lift for a tighter turn in CL Precision Aerobatics. You are shooting for the elusive five foot radius square turn that must be performed in miliseconds. For most of us, it is unattainable...but we try.
For all but top level flyers, non-flapped planes can fly better than we can anyhow. Even some of the top level flyers have fun with non-flapped planes. Note the "Fancherized" Twister, Brett Buck's modifications to the Skyray 35, and ultra light versions of the Ringmaster, designed to wring out as much performance as possible, to name a few.
Some top flyers suggest that flaps only be used when you have gone as far as you can go without them. That said, most of us want to tinker with them WAY before we really need them. That just complicates building and trimming, but hey, that's what tinkering is for.
The point is, don't think you NEED flaps to have fun. Remember the KISS principle.
Enjoy a Ringmaster!
George
(in reply to TGC)
       Post #: 13
RE: Ringmaster S1A plans - 7/25/2007 2:51:12 PM
da Rock
Status: online
__________________________________________________
Looking forward to seeing your work AND very interested in seeing the motorcycle.
But do look closely at the rigging to the elevator. The close hole in the bellcrank helps keep the throw managable as does rigging the pushrod further out on the elevator horn. This is one time that having the ability to move the elevator horn connection is really worthwhile.
< Message edited by da Rock -- 7/25/2007 2:53:43 PM >
