RE: VELOX.. Build thread with Photo's..    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: VELOX.. Build thread with Photo's..
Page: <<   < prev  12 13 14 15 16 17 [18] 19 20 21   next >   >>
Tower Hobbies Today's Special Offer! Brands Products
Login
RE: VELOX.. Build thread with Photo's.. - 4/14/2009 10:30 PM
Lil Hoss
Score: 100
Last Login: 1/29/2012
Status: offline
I couldn't imagine putting a 120 in a Velox. It's very fast with a P80.
Microdat, please post how his flight was with the 120.......... If it holds together
I'm sure it will
Hoss
_____________________________
Ahhhh Wisconsin, 3 months of Great skiing, 9 months of pretty good skiing
Hide Signatures
(in reply to MicroDat)
       Post #: 426
RE: VELOX.. Build thread with Photo's.. - 4/21/2009 3:08 AM
MicroDat
Score: 100
Last Login: 7/3/2010
Status: offline
quote:
ORIGINAL: Lil Hoss
I'm sure it will
Hoss
I would imagine it would go as fast as the bobcat with p120's (225 mph +++++ ), and I've seen a few bobcats with p120s.
I put 8 more flights on the Velox, she flies really good but on the 6th flight my retracts did not come down and I had to belly land her. I tried to get her as slow as possible as to minimize damage to the bottom. However, I totally forgot about the cobra manuer and she cobra'd on me 5 feet off the ground! It started to nose up so I gave it down elevator and some throttle (P60 mind you) and I was able to softly pancake her into some grass. Damage wasn't bad, only a few stratches on my aileron arms and the bottom of the booms. After a 15 minute fix and a quick check over the entire plane to make sure nothing critical was broken I took her up again for 2 more flights.
Hide Signatures
(in reply to Lil Hoss)
       Post #: 427
RE: VELOX.. Build thread with Photo's.. - 4/21/2009 6:24 AM
GreenAcre
Score: 105
Last Login: 1/31/2012
Status: offline
MicroDat. Where did you balance it? Mine is balanced in the middle of the anti rotation pins, with 2 7cell 1700mah nicds in the nose! A P-80 for power. This also includes 2 5cell Nimh 1400 for the Rx and a 6 cell 1200 ECU battery! When I was flying it I had to give a bit of up elevator. Just seems to be a bit nose heavy with all the fuel in front of the cg. Maybe when the fuel burns off during flight it will not be so nose heavy..
Hide Signatures
       Post #: 428
RE: VELOX.. Build thread with Photo's.. - 4/21/2009 10:42 AM
MicroDat
Score: 100
Status: offline
quote:
ORIGINAL: GreenAcre
I also balanced mine on the anti-rotation pins. I use two 2300 mAh A123 batteries for the receiver and 1 3200 mAh 2S LIPO for the ECU (All three in the nose in front of the nose gear). I do have to hold some up elevator when I am below 100 mph but once I get it going its flat and level hands off. I did trim it for WOT so maybe it is a little nose heavy; but I'm not going to change anything as I don't mind holding on to the sticks when I'm flying. I usually fly very tight patterns with it anyways so it is rarely flat and level.
Hide Signatures
(in reply to GreenAcre)
       Post #: 429
RE: VELOX.. Build thread with Photo's.. - 4/23/2009 6:26 AM
GreenAcre
Score: 105
Status: offline
Thanks I decided to put in some down thrust. 1/8" (don't know how many degrees that is) Hopefully this should be fine. (P-80) Why do the Bob cats/King cats have SO much down thrust?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 430
RE: VELOX.. Build thread with Photo's.. - 4/23/2009 11:27 AM
MicroDat
Score: 100
Status: offline
quote:
ORIGINAL: GreenAcre
The bobcats and kingcats' have down thrust (i think) because their elevators are a lot lower than the Velox. Its even more down thrust as you go bigger in engine.
Hide Signatures
       Post #: 431
RE: VELOX.. Build thread with Photo's.. - 4/23/2009 12:49 PM
JET FX
Score: 105
Last Login: 7/21/2011
Status: offline
Been flying my Velox without flaps functional and it flies great, I think a lot of the dramas people have had with this plane have occured getting it to slow with flaps out and behind the power curve.... personally I just dont think this model needs to use flaps for normal sport flying so I fixed mine using straight hollow carbon shaft to replace the stock pin hinges. I have a Kingtech K80-E 8 kg (18 lb) thrust turbine installed and find it just about perfect power wise also. I am really enjoying flying this model, lots of fun
Click for fullsize
Click for fullsize
Click for fullsize
MARTY COWAN CEO
JET FX ~ JETS & WARBIRDS
Hide Signatures
       Post #: 432
RE: VELOX.. Build thread with Photo's.. - 4/23/2009 8:29 PM
MicroDat
Score: 100
Status: offline
quote:
ORIGINAL: JET FX
Flaps are nice but I can see why you wouldn't need it. I can land mine with full flaps on 10 to 20 feet of runway with a 5 to 10 mph headwind. You really have to get the plane super slow for it to cobra on you, and I mean really really slow.
Hide Signatures
(in reply to JET FX)
       Post #: 433
RE: VELOX.. Build thread with Photo's.. - 8/20/2009 10:28 AM
=skywalker=
Score: 100
Last Login: 6/10/2010
Status: offline
Do u want speed?? I have a P120SE in mine. It goes super fast. Radar clocked at 240mph down wind and 225mph level flight. Wings and fuse was reinforced with fiberglass on the leading edges for high speed turns.. Dry weight 21.5lbs with full UAT. Also added an extra 35oz tank for longer flights to consume the P120SE. 6min flight time at full power just to be safe but can go longer. Check out my photos with a custom paint Job for visibility.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by =skywalker= -- 8/23/2009 3:38 PM >
Hide Signatures
       Post #: 434
RE: VELOX.. Build thread with Photo's.. - 12/22/2009 2:21 PM
frizlot
Score: 100
Last Login: 10/27/2011
Status: offline
Hi everyone - I recently got a velox and starting build it - I have noticed that the hinges are not glued into the wing but do appear to be glued into the flap and ailerons. Can someone please tell me if this is the case or not The factory says that the hinges are not glued at all but I think I would have to break something to get them out of the control surfaces.
Hide Signatures
(in reply to =skywalker=)
       Post #: 435
RE: VELOX.. Build thread with Photo's.. - 12/22/2009 8:37 PM
RobinLeblond
Score: 100
Last Login: 2/2/2012
Status: offline
I got mine a few weeks ago (factory assembly), and on mine hinges were NOT glued on any side... But they were effectively very tight...
Robin Leblond
Sherbrooke-Qc, Jet Rally - June 1 to 3, 2012
Hide Signatures
(in reply to frizlot)
       Post #: 436
RE: VELOX.. Build thread with Photo's.. - 12/23/2009 5:45 AM
jkirkon
Score: 100
Last Login: 2/3/2012
Status: offline
Mine has live hinges. I think I would have preferred the Robart style hinges.
Hide Signatures
(in reply to RobinLeblond)
       Post #: 437
RE: VELOX.. Build thread with Photo's.. - 1/1/2010 12:28 AM
jephry
Score: 100
Status: offline
Hi,
I have just completed mine fitted a K80.
Can anyone advise on the CG & where to balance from as there are some mixed info.
Can also advise the Throws? and also any maiden advise for the jet?
Just want to Fly!
www.rc-ms.com
Hide Signatures
(in reply to jkirkon)
       Post #: 438
RE: VELOX.. Build thread with Photo's.. - 1/1/2010 1:43 AM
CJ2002
Score: 100
Status: offline
Extract from my build thread on JMA website...
.........having flown the model quite a lot now and having moved the CG back 5mm (now 5mm aft of the C/L of the wing anti-rotation pin), reduced the full-flap travel and corresponding elevator compensation trim, I flew the model twice again yesterday to check out the latest changes and am happy with how it feels and performs. The set-up I have settled on is:
CG - 5mm aft of the C/L of the wing anti-rotation pin
Aileron movement - 14mm each way (measured at the tip - no expo...gives the very soft aileron I like)
Elevator Movement - 30mm each way (12% expo)
Rudder movement - 25mm each way (measured at the top - no expo)
Flap travel (measured at outb'd flap/inb'd aileron position):
Take-off: 20mm with 9mm up elevator trim mixed in
Full-flap: 35mm with 11mm elevator trim mixed in
(so that means there's 20mm up elevator trim required with full flap travel)
Happy New Year!
Dick
England
Hide Signatures
(in reply to jephry)
       Post #: 439
RE: VELOX.. Build thread with Photo's.. - 1/8/2010 3:51 PM
frizlot
Score: 100
Status: offline
Hi Robin
Thanks for the reply - Did you have to break anything to get them out. Mine are really tight and I am a little scared of forcing them
Hide Signatures
       Post #: 440
RE: VELOX.. Build thread with Photo's.. - 1/8/2010 4:17 PM
RobinLeblond
Score: 100
Status: offline
No, I just removed them, but it was hard, but they get out... Try to rotate them, you will see if they are glued or just tight... If you can't rotate them, it may mean they are glued...
But as I said, mine wasn't... Also, some may be easier to remove, then if some are not glued you may assume that none of them are... I remember that some get out easily while other where very hard... Let us know, it may be usefull for future builder/buyer...
Robin Leblond
Hide Signatures
       Post #: 441
RE: VELOX.. Build thread with Photo's.. - 1/18/2010 8:29 PM
frizlot
Score: 100
Status: offline
Hi Marty
I see you have put a K80 in yours - My standard mounting seems to be just a little narrow to allow for enough meat for the mounting screws - Can you possible explain how you did yours
Hide Signatures
       Post #: 442
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 12:25 PM
RCISFUN
Score: 100
Status: offline
No posts in a month, anybody working on these?
I picked on up and I about to do an install.
Rich
Jet Central Rabbit owner... my new Cheetah has arrived!
Hide Signatures
       Post #: 443
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 3:10 PM
jephry
Score: 100
Status: offline
I am about to maiden mine this week! Changing out the Aileron servos from Hitec 5125 to 645MG
Just want to Fly!
www.rc-ms.com
Hide Signatures
(in reply to RCISFUN)
       Post #: 444
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 5:50 PM
RCISFUN
Score: 100
Status: offline
quote:
ORIGINAL: jephry
Good Move, I wouldn't hit a dog in the butt with 5125's for critical surface functions on jets, the gear train is too fragile, it's tough to make a strong gear when the thickness of the gear tooth is so thin!
Let us know how the maiden goes!
Rich
Hide Signatures
       Post #: 445
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 6:15 PM
jephry
Score: 100
Status: offline
Sure do!! Mine is powered by a KT K80. Will try post some pix of the setup..
Also trying to complete my JL T45 Just short of the Air Valves from Airpower.
At the same time trying to build the formost. By the way thanks for the mods plan for formost
Just want to Fly!
www.rc-ms.com
Hide Signatures
       Post #: 446
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 7:42 PM
RCISFUN
Score: 100
Status: offline
Hey are you stocking me , you have all the same aircraft that I have or had
Rich
Hide Signatures
       Post #: 447
RE: VELOX.. Build thread with Photo's.. - 2/17/2010 8:24 PM
jephry
Score: 100
Status: offline
quote:
ORIGINAL: RCISFUN
Ha.. I prefer have!!
Just want to Fly!
www.rc-ms.com
Hide Signatures
       Post #: 448
RE: VELOX.. Build thread with Photo's.. - 2/19/2010 8:42 AM
RCISFUN
Score: 100
Status: offline
Well tonight I did a little layout work to fit my Rabbit into the Velox, I came up with some adapter plates that will allow me to flip my Rabbit between my Flash and the Velox.
See attached full size PDF document
Click to see the file in new window.Attachment.pdf
Rich
Hide Signatures
       Post #: 449
RE: VELOX.. Build thread with Photo's.. - 2/22/2010 6:04 AM
ciromoreira
Score: 100
Last Login: 10/23/2011
Status: offline
Hi Skywalker!!
I use a P-80SE on my Velox and clocked 246,3mph down wind and 226,1mph level flight!! I LOVE this plane!!!! My 300Ft runway just enoughs for this... Thanks FeiBao!! Here is one flight inside cam > http://www.youtube.com/watch?v=Epab1tN0i0Y
I have more videos at my channel!!
Thanks!!
Ciro Moreira
Hide Signatures
       Post #: 450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
RC Universe is a service of Internet Brands, Inc. Copyright © 2001-2012.
6.844RCU1
