melted pipe in my volcano    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> melted pipe in my volcano
Page: [1]
Login
melted pipe in my volcano - 6/4/2007 10:34 PM
gatucar
Score: 100
Last Login: 8/5/2008
Status: offline
Hey guys,
I just got my stock exhaust pipe melted and I am wondering if that happened because they are just cheap plastic or because I was running too lean ?
Thanks for your help!!!
Hide Signatures
       Post #: 1
RE: melted pipe in my volcano - 6/4/2007 10:52 PM
IL2mSturmovik
Score: 100
Last Login: 7/17/2011
Status: offline
quote:
ORIGINAL: gatucar
Hey guys,
My guess
_____________________________
Mugen M-Spec MBX6 Buggy & MBX6T Truggy
Hide Signatures
(in reply to gatucar)
       Post #: 2
RE: melted pipe in my volcano - 6/5/2007 1:51 AM
DirtBonez
Score: 100
Last Login: 12/21/2007
Status: offline
Lol a plastic exhaust system? You may want to richen your HSN and upgrade to something aluminum. I guess you were running too hot but I would think that a plastic pipe would melt anyways.
Hide Signatures
(in reply to IL2mSturmovik)
       Post #: 3
RE: melted pipe in my volcano - 6/5/2007 2:36 AM
p8ntball
Score: 100
Last Login: 12/9/2007
Status: offline
plastic pipes wont melt too easily... they wouldnt put them on the car. Do you have a temp gauge??? if not GET ONE trust me, they are worth the $20. if your pipe melted, your temp must be SUPER high... get the temp guage.
Jato 2.5 w/ upgrades. Savage X, oh yea
A great man once said, "Wars may come and go, but my soldiers stay eternal..."
Hide Signatures
(in reply to DirtBonez)
       Post #: 4
RE: melted pipe in my volcano - 6/5/2007 3:23 AM
DirtBonez
Score: 100
Status: offline
ya I guess you are right, if they have it on there it must work. But still a plastic exhaust? thats weak. The header must be aluminum though right?
Hide Signatures
(in reply to p8ntball)
       Post #: 5
RE: melted pipe in my volcano - 6/5/2007 5:39 AM
webdr
Score: 120
Last Login: 1/17/2012
Status: offline
I have two redcats and I never had the pipe melt or deform.
Maybe you got a bad one? LOL ...What was the temp during this meltdown?
Hide Signatures
       Post #: 6
RE: melted pipe in my volcano - 6/5/2007 10:42 PM
gatucar
Score: 100
Status: offline
Thanks for your hap guys! I will get the temp gun! A guess the car was running way to hot because the "spit test" was close to a second. However I tried to richen up the nitro mix but my car stopped working after the pipe melted ( I ordered a new one but mean time I repaired the one that I have with a piece of metallic pipe). The symptoms were these:
Truck stopped working. I pulled the start cord several times and suddenly the starting cord got stacked (the starting cord was perfect since when I toke It out from the engine it worked OK). The flywheel did not move either. So I removed the cooling tower and remove the piston sleeve. Then I rinsed the chamber with a bit of nitro (a small piece of dirt got out) and the flywheel started to move again so I put all parts together again. Now It happens the following:
1) I can get the engine running but for a few seconds each time (2-4 second and it stalls).
2) the engine seems unresponsive to throttle since when I pull the throttle I can see the carburetor does not rev up and stalls.
3) Even thought the engine starts when I am able to rev it up a little bit the car does not move at all.
These make me think a little in a clutch problem? Can it be that I set it back too tight and it is not moving properly? can the engine be damaged? Please give me some feed back. I have try to get some information with no luck so far .
Thank you!
Gatucar
Hide Signatures
(in reply to webdr)
       Post #: 7
RE: melted pipe in my volcano - 6/5/2007 11:38 PM
p8ntball
Score: 100
Status: offline
possibly a stripped spur gear... have you tried to set your carb to factory settings... it should work.
Hide Signatures
       Post #: 8
RE: melted pipe in my volcano - 6/6/2007 2:12 AM
gatucar
Score: 100
Status: offline
Yes, I already tried the factory settings for carb! I will try again today.
Hide Signatures
       Post #: 9
RE: melted pipe in my volcano - 6/6/2007 11:51 AM
Alteramod
Score: 100
Last Login: 8/3/2009
Status: offline
Hey man I will make this mistake sometimes to (not saying its your problem but a good chance). Before you throw your tune all out of whack change the glow plug. If it was running that hot there is a reallllll good chance thats the problem. It sucks when you get an awesome tune then it quits running and you play with the needles for an hour..... then bam! You think to your self, I should try another plug. Then another bam (only its the engine running) then you spend 2 hours trying to get that awesome tune again haha
Mgt nearly bullet proof, Ofna ultra lx comp, and a pile of xxx-t mf parts.
Hide Signatures
       Post #: 10
RE: melted pipe in my volcano - 6/6/2007 6:42 PM
gatucar
Score: 100
Status: offline
Thanks for your help Alteramod!
You may be right it could be a new spark plug. Even thought it has a new one installed (with which I've run no more than 4 fuel tanks) I will try this.
Do you know what is the average life for a spark plug? It is maybe that short and I do not know
Thanks again
Hide Signatures
(in reply to Alteramod)
       Post #: 11
RE: melted pipe in my volcano - 6/7/2007 12:03 AM
drummerboy68028
Score: 100
Last Login: 5/29/2011
Status: offline
well, just depends on how well your tune is. Some people go through them like tissue paper, and then others, they go maybe a gallon or two. I had a great tune on my revo and didn't have to change my glow plug untill 1 and half gallons of 20 % was ran throught it.
In all honesty, i dont think its the glow plug. Did you clutch show signs of slipping before this. Maybe you spring holding the clutch shoes together broke. Those redcat motors aren't that too tough to take apart. I would just check to be sure.
Anyone know what I can do with a spare O.S. .18 cv-rx?
Hide Signatures
       Post #: 12
RE: melted pipe in my volcano - 6/7/2007 12:33 AM
gatucar
Score: 100
Status: offline
Drummerboy,
Thank you fro your response.
I already checked the clutch and the clutch spring and they are OK.
How is your Revo 3.3 working? I am seriously thinking in an upgrade like that. Is is fast and reliable? are the gears made of steel? do they wear out often?
Hide Signatures
(in reply to drummerboy68028)
       Post #: 13
RE: melted pipe in my volcano - 6/7/2007 12:38 AM
drummerboy68028
Score: 100
Status: offline
i have broke stripped 2 spurs... and lol no not metal, but theres an upgraded steel spur.
1st spur= sis ran into curb, truck flipped and hit engine first pushing it away from the spur and making it not mesh correctly, and
2nd spure= i didn't know how to mesh the gears correctly then.
Very reliable, very fun, and very fast all of the above, er, to the left lol
Awesome upgrade. BIG step up from redcat lol
Hide Signatures
       Post #: 14
RE: melted pipe in my volcano - 6/7/2007 12:55 AM
gatucar
Score: 100
Status: offline
I checked the video that you posted. It is great! Was that a Revo 3.3 ?
I saw your profile and it said that you are a "market authorized" Do you sell this truck? If so how much?
Do you recommend me any other RELIABLE brand and model of trucks or buggies. I would like to get something below 400 dollars (but something decent!!!) able to give at least 45 MPH, 4x4, with good gears and engine.
Thanks again
Hide Signatures
       Post #: 15
RE: melted pipe in my volcano - 6/7/2007 1:03 AM
drummerboy68028
Score: 100
Status: offline
As far as the market authorization, i didn't even know i was authorized lol. And that wasn't my video, it was freez's, but i liked it also. As fat as selling my revo.... No can do. I finally got a truck that i can run a tank of gas through without breaking a part lol.
And for finding a truck with 4wd, under 400$, and capable of going 45mph, i draw a blank
However, my revo was 500 (plus the charger, easy start battery and some other micellaneous things) it was 600$ altogether. But i hear the t-maxx is good, LST, LST2, savage, aftershock, monster GT and a couple others i can't think of right now are great trucks.
EDIT: just adding more trucks i think of
Hide Signatures
       Post #: 16
RE: melted pipe in my volcano - 6/11/2007 7:36 AM
gatucar
Score: 100
Status: offline
Thank you drammerboy! I will remember those car brands.
Hide Signatures
       Post #: 17
RE: melted pipe in my volcano - 6/11/2007 5:47 PM
IL2mSturmovik
Score: 100
Status: offline
Get an Aftershock, $320 on Killer Hobbies
Hide Signatures
       Post #: 18
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.922RCU1
