Mustang Exhaust
- Kit
Seller:tony-howard Details:
$35.00
| 9/21/2008
| Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
Joined: 1/12/2004 From: Red Bluff, CA, Status: offline
Easton, what is the weight of your spitfire with the g26? I'm waiting for someone with the spe 26 to chime in. I wonder how much perfomance difference between them. Power and weight.
As to the engine positioning I found and marked the Horizontal & Vertical line and then the engine mount six millimeters to the left giving me the correct amount of side thrust.
KY, USA Status: online
OPkay, I finaly got mine in the air, with the SPE 26 and a 18x6 prop...It flies like a dog, lumbering around, in a high Alpha attitude. I keep thinking she's gonna stall out on me. Both times the engine ended up quitting on me and I've dead-stiched her safely back, but I can't imagine it's th eplane... It must be the engine. I can't figure it out? I started out w/ a 15x 7 3 bladed prop, and it was a slug so i changed her tio the 2, but I still am not getting the love I want. CG is correct, but it flies like a .60 is pulling it around. Anyone else w/ and SPE 26 on board ? What is anyone turning RPM wise ?
< Message edited by NoFlaps -- 3/12/2008 2:49:32 AM >
NC, USA Status: offline
No way a 18-10 is too much prop for a 26. Try a 16-8 apc. I have one on mine with a g26 and it turns it 9200 rpm. Mine flies great. I like the way it flies so much I upgraded the retracts with robarts and struts and 3.5 robart wheels. Just try a 16-8 apc and you can compare the rpm and if it anywhere close it should fly great. Good Luck Nelson
