xlr82v2
IL, USA Status: offline
Fire is not likely as long as the pump doesn't leak, which is what happens to most of the cheaper gear type pumps... they start to leak around the motor shaft seals, or in the pump body itself. Then, if you get fuel in the motor, along with electricity, then it's anybody's guess as to what can happen. That being said, I've seen a lot of pumps leak, but I have never seen one catch on fire, yet. Hopefully I never do. If you're really that concerned with the fire hazard, then I would go with a manual pump. That would be the lowest risk option for you. But, like I said earlier, I've never seen a flight box catch on fire, yet, out of my 25 years flying RC airplanes. I've never seen an engine fire yet as well, for that matter. And that's where you're trying to get the fuel burning All in all, I would say, from my experience, that as long as you stick with glow fuel, the fire risk is very, very low, even with an electric pump. Assuming that all of your wiring on your flight box is safe (no exposed wires, good tight connections, etc.) If you twist wires together and then wrap them with duct tape, well, all bets are off, if you know what I mean. As far as short circuits, any time you have a 12 volt lead acid battery (either wet or sealed gel cell), a short circuit could make for an exciting event. Wires can get hot and burn very quickly. It's a very good idea to put a fuse in your flight box electrical system. I've got a 30 amp fuse protecting my box electrics. A 20 amp fuse might even be sufficient... I don't really know. With the starter at full stall (as it would be when cranking an engine and stopped against compression) and the power panel running the glow plug driver, I'm sure that it's getting close to 20-30 amps load through the wiring. But a short circuit will blow the 30 amp fuse almost instantly before the wires get hot enough to start a fire. I use 10ga wire from the battery to the power panel, and 14ga wire out to my fuel pump. The 14ga wire will carry enough amps to blow the 30 amp fuse before getting hot enough to burn should there be a short circuit out at the fuel pump end of my flight box (I've got a Sig Field Boss flight box with a 12AH motorcycle battery for power.)
_____________________________
Brian
