HerrSavage
Joined: 9/17/2005 From: Leipzig, , GERMANY Status: offline
Well, just put two tanks through the Mugster with the LRP back in.. And, problems, problems.. I noticed some crunching when I put the truck back in the car and it rolled backwards.. Sssooooo, sounds like fried bearings... It has a new never used Muggy 12T stock CB on it too - so down 2 from what I had on the Nova.. Running Dynamite long-life shoes and 1.0 springs I think.. Would ceramic bearings make a difference?? And secondly, despite replacing the whole steering linkage, there is a HUGE amount of slop, especially on the left front wheel... The little link that goes under the chassis brace, from left to right, if I tighten it too much, it binds, and worries me for the servo's sake.. Too loose though and it's slop-o-rama.... What's up with that?? I've seen the upgrade thing about using a turnbuckle, but why should I have slop if I've got new parts in there(basically I just replaced the linkage arm itself, and the plastic thingies...)?? Also, the OWB (HPI roto) is slipping badly.. It started slipping the last time I ran it too, but I had taken it out, cleaned things up, etc.. - was expecting it to go a bit better.. Anyway, I assume I can just run the original Mach Spinstart backplate from the Mach that I switched to bumpstart?? In which case I have to use the search.. Something about "elongating the screws"...?? Unless of course somebody could be a peach and clarify that for me real quick... All of that said though, the engine ran like a FREAKIN' DREAM compared to that d.umbass Nova.. Was actually borderline too cold for too long.. Switched to an MC 8(all I had with me..), and temps were still cold.. As in, took like two minutes to get up about 160.. But responded perfectly to needle adjustments, and just is all around nice to drive... Fast, smooth, and just fun.. Killer engine.. Now if I could just get the rest of the stuff sorted out... Talk about a truck living off its good looks.. If it didn't look this good I'd probably have gotten rid of it... (Nnnaaahh... It IS fun to drive too... Just these little nit-picky things.. The truck's got quite a bit of wear and tear on it too, so some of it's to be expected I guess...)
< Message edited by PatrickBW -- 7/7/2008 3:57:40 PM >
