Pumping Coleman Fuel
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Pumping Coleman Fuel
Page: [1]
Login
Pumping Coleman Fuel - 3/3/2003 12:49:59 AM
bwillhite
Status: offline
After reading the post here on RCU I have decided to use Coleman fuel in my US Engines 25cc.
Do I need to use a gasoline rated pump with Tygon tubing or will a glow pump and regular glow tubing be OK? I am going to use a manual pump, not electric.
Thanks for your time.
bwillhite
_____________________________
They all hit the ground sometime!
       Post #: 1
Pumping Coleman Fuel - 3/8/2003 6:38:51 AM
lynngordon
Status: offline
Coleman fuel is very simular to "White Gas" - very hard to find anymore, and lower octane than regular unleaded. Use a gasoline rated pump and tygon tubing.
Lynn
(in reply to bwillhite)
       Post #: 2
Pumping Coleman Fuel - 3/13/2003 12:34:19 AM
bdtsr
Status: offline
With being less octane, would some of the octane boosters help or are they not compatible with the coleman fuel?
       Post #: 3
Pumping Coleman Fuel - 5/20/2003 5:30:35 AM
rc-mike
Status: offline
I would try the fuel by itself first(with oil of course). I put it in my poulan 46cc conversion and it ran great. Actually seemed a little smoother. I read somewhere that the lower octain is actually better for the smaller engines like we use. I don't know for a fact but that is what I read.
Michael
       Post #: 4
Pumping Coleman Fuel - 5/20/2003 7:06:52 AM
bdtsr
Status: offline
What kind of power were you getting (prop & rpm)?
       Post #: 5
Pumping Coleman Fuel - 5/20/2003 7:58:22 AM
rc-mike
Status: offline
I'll have to check the rpm. My tach is messed up and I need to get another. I am using a 20x10 Master Airscrew. When I was using regular gas it would buck quite a bit at idle. The coleman fuel smoothed it out a little and it transitions smoother. It sounded like it was running just as strong at full throttle as with gasoline. Sure smells better if nothing else!
       Post #: 6
Pumping Coleman Fuel - 5/20/2003 8:00:47 AM
Homebrewer
Status: offline
White gas or Naphtha found in Coleman fuel should work fine in a low compression 2 stroke engine.
       Post #: 7
Pumping Coleman Fuel - 5/29/2003 5:47:21 AM
rc-mike
Status: offline
It is running 7000 rpm. We put some regular gas in it and it was 6800. I didn't think it would have more power but I guess it did!
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.797RCU1
