Aerozona
AZ, USA Status: offline
Where do I start, well here we go... That is a fact!...bzyguy01's “Downer” did just fine in this Arizona heat. And I really feel as bzyguy01 does, flying in this desert heat of as high as 112 in the afternoon and cooling of at night to 103 as I have for many years that extensive cowling baffle mods is really over exaggerated and un-warranted in most cases. Besides the weight baffling adds and the friction drag when forcing the natural flow of air from one direction to another (from the manufactures design), the benefits when talking “Heat” is almost none. I have done my fair amount of baffle testing and re-works because Arizona’s heat always has a flyer thinking along those lines anyways. I’m no expert on this subject by any means, but I have found that the work involved to baffle never comes close to a justifiable end results. More over than not I have found that when all is said and done… the guys that design and market these planes have already been there and done that! By the same token, in a few extreme engine mods and electronic ignition set-ups, I have seen where cowl baffling mod were needed and worked well. Again, only in a few cases though. I’ve been doing some research in the past few days, after this discussion started about the Sundowner and baffling the cowl… I started asking creditable sources about the Sundowner and its cowling design in relation to air flow and heat: 1) The two horizontal openings on the left and right side of the of the prop opening are air intake to accommodate the various engine arrangements that builders may want to use. The kit itself is basically set up as the default for the Satio 180/220 Glow or the EVO 26GT/35GT2 Gas but was also recognized in that a builder may want something besides these choices to work with. 2) The round or “O”hole is also an air inlet but was designed as a directive air channel to move the incoming air from the horizontal openings at the top toward the air discharge area in the bottom rear of the cowl covered engine compartment. Thanx for the use of your pic bzyguy01 3) To finish...My results have found that by design the overall air movement in through Sundowner’s cowl area was well thought out and meant to achieve the best possible results for the plane just the way it comes right “out of the box”. I am just as guilty as many through the years for trying to OVER COMPLICATE simplicity.
< Message edited by Arizonan -- 8/11/2007 12:08:05 AM >
_____________________________
"If your plane goes up, it WILL come down...your choice of decent is CRITICAL"
