Airnondas
QC, CANADA Status: offline
You are going to love the way the plane flies with the Moki. I used a Perry pump that takes pressure from the crankcase. The engine would run to rich and if you leaned the low to get a good idle, the engine would lean in the air. Are you going to use a pump? The problem I encountered with the pump was the pump giving too much fuel. The solution was simple. A tee, installed just before the needle valve going back to the tank, took care of the extra fuel. Now the engine is running perfect, just like my other two Moki's. ___________________________ Airnondas
