CRG
Justin, The owner/pilot is required to be able to answer questions about how the aircraft is built, and that it uses appropriate materials and techniques. These are not just some thrown together models with ever larger motors put in them. On most of the models the internal structure is visible, and it is checked with the wing off during every pre-race inspection. If an inspector needs to see more they will ask the owner to remove panels as necessary. Models are inspected again if any damage is sustained. Wings have appropriately sized spars and shear webs, skins are laid on a bias for torsional strength etc. Wings have been static loaded to check integrity. The engine choice is in the hands of the owners up to a limit- max. weight for Unlimited, capacity limit for the other classes. Safety is NOT compromised for the sake of all out speed. The USRA has some desire to maintain the scale portion of racing. The full size Sundowner did not have a two foot diameter pipe down the fuselage.... Pipes are permitted in Unlimited but they have to be internal. Any other organization or club that wants to run Sundowner races can obviously do as they choose. Craig. quote:
ORIGINAL: kochj CRG, I undestand that they are inspected for those things that you have mentioned! But, NO one takes them aside and says "Where are your build photos?" "I want to see the Intirnals of the that wing and how you used the material" " I also want to see the CAD drawings and the Load Barrings that a engineer had figured" My point of my previous commnet was not to Digrade those that have taken time to build a plane for all out speed and high g's, but to place the engines choice in the hands of the owners and have it be there responsibility to reinforce what needs to be to make it safe to fly with the engine of choice! Perhaps limit the engine to a max 50cc's? I am sure that there are a few good builders, that can suggest a few mods to make the plane wistand huge G' forces. Perhaps this plane can already take a 50cc gas engine WOT and then bank hard with no wing mods other than harwere upgrades and hing sealing? OR it may disinigrate! I do not know..... This is all irrelivent though, as I am not some AMA official and do not have any kind ot legitimacy of these coments........ I would however, like to put the fun back into the sport of pylon racing..... But not on the expence of Safety.... bY THE WAY, The BME 50cc with the tuned pipe looks fantastic!!!! I would think that at least the Sundowner class sould allow the use of a Tuned pipe!! It would make it that more interesting! Justin Justin
