kochj
MN, USA Status: offline
Just a update for you guys...... MVVS / or EVOLUTION is comming out with a 40ccGT..... (bored out 35gt) not much difference in weight but will swing moor wood, and that matters some.....\ The yare also comming out with a 50cc 3.3 lb engine.... 80cc and 152 respectivly....... out in August for MVVS..... Not sure when EVolution and Horrizon will get theres..... I also am not sure if the 35gt will be discontinued or not..... But I would think If you wanted more musturd for your SD and you have a 35GT you could get the larger piston and cyl. and drop it in...... Not sure though on that one...... Justin
_____________________________
Winning isn''t everything, it''s all there is.
