RE: Another Custom Camera Mount
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Draganfly Innovations Products >> RE: Another Custom Camera Mount
Page: <<   < prev  1 [2] 3 4   next >   >>
Login
RE: Another Custom Camera Mount - 6/16/2007 7:24 AM
dart340
Score: 100
Last Login: 8/22/2009
Status: offline
Hi Mike,
Thanks for the posting the Deshaker setup, I'll try it out. Keep up the good work. One of the things I tried was sharpening the video. Because your videos were captured in progressive mode, sharpening helps your video quite a bit. I tried it with your 794 video. Here is the result:
http://members.shaw.ca/the.photographer/Deshake794dssharp.avi
I used a sharpening level of 50.
Tim
Hide Signatures
(in reply to Old Man Mike)
       Post #: 26
RE: Another Custom Camera Mount - 6/21/2007 12:09 PM
Dirk Schooner
Score: 100
Last Login: 9/5/2007
Status: offline
Mike, use QuickTime Pro, it does eveything you need, Windows Movie Maker is a joke, Avoid at all costs!
Not been on here for a while (nearly a year) nice to see some great progress with camera mounts and video/stills stuff.
I am able to fly mine again now in the UK that the weather is getting better.
Check my YouTube channel for some of my latest Footage. http://www.youtube.com/profile?user=DirkSchooner
< Message edited by Dirk Schooner -- 6/28/2007 4:31 PM >
Hide Signatures
       Post #: 27
RE: Another Custom Camera Mount - 7/25/2007 11:05 AM
Old Man Mike
Score: 102
Last Login: 11/21/2008
Status: offline
Now that I can accurately measure height with the on board altimeter, I've been trying to see how high I can take video and stills. Here's the best so far at a peak of 270 feet:
DF video at 270 feet
DF still at 270 feet
Still using the green foam custom mount and the Panaxonic DMC-FX07 camera.
Dirk, I agree that QuickTime Pro is good if you keep everything in MOV mode. I have been using Sony's Vegas Movie Platinum 8.0 for editing and conversions.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to dart340)
       Post #: 28
RE: Another Custom Camera Mount - 7/25/2007 6:42 PM
Sky High
Score: 100
Last Login: 2/22/2010
Status: offline
That video was great Old Man Mike! It was really stabile too. It's good to see what almost 300 ft looks like. How high is your radio tower? Can you post a version of the video without processing? Thanks.
_____________________________
Up there, you don''''t have time to think, if you think, you''''re dead!
Never mess with an aircraft with more rotors t
Hide Signatures
       Post #: 29
RE: Another Custom Camera Mount - 7/26/2007 6:43 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: Sky High
Thanks! The radio tower is 90 foot. The unprocessed video file is around 500mB for a 5min flight. Here is what the video looked like before the deshake processing:
Video before Deshake
I've also include the altimeter log graph. It is amazing to me that it even shows the change in height when I picked it up for the TI arming at the beginning and when I picked it up to cut off power at the end.
Click for fullsize
< Message edited by Old Man Mike -- 7/28/2007 4:48 AM >
Hide Signatures
(in reply to Sky High)
       Post #: 30
RE: Another Custom Camera Mount - 7/26/2007 5:36 PM
Sky High
Score: 100
Status: offline
I meant uprocessed for stabilization. Could you post the video unstabilized but still compressed? Thanks.
Hide Signatures
       Post #: 31
RE: Another Custom Camera Mount - 7/28/2007 4:54 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: Sky High
Sorry it took me a while. I had not kept that intermediate step and had to reproduce it from the original mov file. I've edited my post so that it will now show the same period of time without the deshake processing. It did not look as bad as what I thought it would without the video deshake. But I still like the deshake version better.
Mike
Hide Signatures
       Post #: 32
RE: Another Custom Camera Mount - 7/28/2007 5:35 AM
Sky High
Score: 100
Status: offline
Yes, I agree. The picture looks alot better than the SAVS camera and it doesn't bounce! The processing makes it even better. So, is there a way to know how accurate that altimeter is? You could fly level with the top of your tower which you know is 90 ft and see if the altimeter shows 90 ft.
Hide Signatures
       Post #: 33
RE: Another Custom Camera Mount - 7/28/2007 6:18 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: Sky High
I've done exactly that for not only my tower but at a friend's tower which is at 120'. Both times it was within a few feet of the actual height. At the beginning of the recording, I have it set for an auto zero. At the end of a 10 min flight it is sometimes as much as 8 feet in error. With the more typical 5 min flights it is almost always within a few feet of zero. I am quite amazed that it works so well and thought I might eventually use it to implement an altitude level hold.
I tried the image measurement technique by calibrating the number of pixels for a known reference size object at a known straight line distance. But unless your camera is pointed straight down at an object of known size, calculating the straight line distance based on estimated angle makes for a very inaccurate measurement. For example, I had use the image measurement technique on that crash video I posted and thought it was close to 500' high. Based on the flights I've made with accurate measurements from the altimeter, I think the crash video was closer to 250 feet in height.
Mike
Hide Signatures
       Post #: 34
RE: Another Custom Camera Mount - 7/29/2007 7:58 AM
Old Man Mike
Score: 102
Status: offline
I've also been experimenting with different settings on the camera for stills. Here's one taken at 200 feet while flying with the TI OFF (Cloudy conditions seemed to make TI mode fly erratic):
Pointing West at 200 Feet
Mike
Hide Signatures
       Post #: 35
RE: Another Custom Camera Mount - 7/31/2007 8:01 PM
BB_DF
Score: 100
Last Login: 5/24/2009
Status: offline
quote:
ORIGINAL: Old Man Mike
Mike
Hi Mike,
I picked up the Panasonic FX07 today. How do you trigger it for stills? Is there a way to have it shoot continuously, or do you have to use the timer (10 seconds is not enough time to spool up the T-Rex and climb into position).
Bruce
Hide Signatures
       Post #: 36
RE: Another Custom Camera Mount - 7/31/2007 9:41 PM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: BB_DF
Hi Mike,
Bruce
After so many hours of research and development, I'm not sure that I should release the final design. Final cost might be too high for some. Anyway, here it is:
Click for fullsize
Hide Signatures
(in reply to BB_DF)
       Post #: 37
RE: Another Custom Camera Mount - 7/31/2007 10:11 PM
BB_DF
Score: 100
Status: offline
Ah yes, simple and elegant! Great little camera - thanks for the recommendation. I just ran a test and it will shoot high-res pictures for over 12 minutes with a 2GB SD card, which was only $24 at Best Buy.
Here's my camera mount for the T-Rex. Since conventionals tilt a little in a hover due to the side thrust of the tail rotor, you need to have a complicated pendulum mount if you point the camera forwards, to keep the horizon level. I figure it's just as easy (maybe easier) to shoot from the side, and all that complexity just goes away! The camera and 1/16" aluminum angle are so light I can't tell any change in the CG when I pick it up by the head. Any side tilt due to translating tendency in a hover will just change the downward angle, and not affect the horizon (in theory). Flight tests coming soon.
BTW it's such a joy to fly the 600 without that boat anchor hanging out underneath! That might have to wait for the Maxi-Joker.
Cheers,
Bruce
Click for fullsize
Click for fullsize
< Message edited by BB_DF -- 8/1/2007 12:00 AM >
Hide Signatures
       Post #: 38
RE: Another Custom Camera Mount - 8/1/2007 1:34 AM
Old Man Mike
Score: 102
Status: offline
Yeah, I really like the camera. I have thousands of dollars in Nikon gear but I end up shooting more with this camera because I can carry it in my pocket. I also enjoy pulling out the SD card, plugging it in the computer and browsing the 500+ pictures taken during a DF flight. There are always some excellent shots which I'm sure I would never had taken using a remote control shutter. You probably discovered that you can keep the button held down and just cut the power switch on and off to start and stop the shooting. Just be sure that the first shot has enough light, otherwise it will not continue to shoot.
Looks like you've got a good first mounting attempt. I like the advanced popsicle controls. I am most interested in see the resulting video to see if the hard mounting couples much vibration into the camera. Seems like you could hang a foam mount design and have that extra protection just in case you come down a little hard.
Mike
Hide Signatures
(in reply to BB_DF)
       Post #: 39
RE: Another Custom Camera Mount - 8/1/2007 2:27 AM
BB_DF
Score: 100
Status: offline
...You probably discovered that you can keep the button held down and just cut the power switch on and off to start and stop the shooting. Just be sure that the first shot has enough light, otherwise it will not continue to shoot.
I hadn't tried turning the power on/off with the button depressed. My MK III Starbucks stirrer switch comes equipped with a little wedge that raises the lever off the button - but your idea is simpler.
The manual says that the whole sequence uses not only the light, but also the focus settings of the first frame, and I found this to be true. I turned it on with the camera close to the ground and all the subsequent aerial shots were blurry. I verified this with some hand-held tests. I'll need to hold the airframe up so the camera sees an infinite focus when I turn it on. If you're not already doing this on purpose, your aerials will be even more crisp. Couldn't tell if that was just haze, or slightly out of focus.
I'm going to concentrate on stills instead of video for awhile, because I think I have a lot better chance of making a few bucks selling them, but I'll also shoot some test videos. With the T-REX 600, Spektrum DX7, AP-2000i and Lumix combo, I think I'll have a great winning package. Surprisingly, I've got WAY less than the cost of my SAVS tied up in this rig. However, there's still a lot of interest in the DF from our government clients, and I'm about to start training one of their pilots on the DF Thursday. Not a bad way to make a few shekels!
- Bruce
Hide Signatures
       Post #: 40
RE: Another Custom Camera Mount - 8/1/2007 3:40 AM
Old Man Mike
Score: 102
Status: offline
Actually for continuous burst mode, the shutter speed and aperture will vary for every shot based on the amount of light and image movement. Only the focus remains fixed on the first frame. But I think I have been getting sloppy about making sure that the camera is pointing at a far object when I turn on the camera for burst mode stills.
For video, focus and aperture are both fixed on the first frame. There does appear to be some sort of auto slow adjustment for light while recording the video, almost like an agc.
I have been shooting at a fixed ISO400 since that made a real difference before going to the suspended foam mount. I have just started using the IISO setting which adjust ISO based on the movement of the subject and brightness. I'm also starting to use the MODE 2 deshake which does a greater deshake but is available only for stills. Now that the foam mount seems to be doing so well, I need to go back and test some of the other camera modes. There are quite a few possible combinations. It will be interesting to compare best settings.
Mike
Hide Signatures
(in reply to BB_DF)
       Post #: 41
RE: Another Custom Camera Mount - 8/1/2007 11:31 PM
BB_DF
Score: 100
Status: offline
Here are a couple of pics shot today with the above rig, and the camera set to ISO 800. I put a little foam between the alum angle and the skid support, otherwise no changes. It's amazing how your flying skills go to h*** when you're distracted by something new. Still in 6 minutes I got over 20 "keepers" out of 500 frames. Can't complain about that! With a little practice, I think it would be pretty easy to guess what approximate altitude and offset would get the job done. Then just loiter around up there awhile and catch some nice fish.
Cheers,
Bruce
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 42
RE: Another Custom Camera Mount - 8/2/2007 6:16 AM
Old Man Mike
Score: 102
Status: offline
Nice! Looks like the picture is perfect for a listing in the local real estate marketplace.
I envy your flying with a light payload. The DF is really at the limit with my camera, mount, metal rollcage, altimeter and color tape. I'm up to a total payload weight of 9.4 oz and you really have to be careful during the decent not to come down too fast.
Mike
Hide Signatures
(in reply to BB_DF)
       Post #: 43
RE: Another Custom Camera Mount - 8/2/2007 6:23 AM
Sky High
Score: 100
Status: offline
You are both getting great shots. Do your cameras have a sports mode? I have heard that helps with dampening vibrations and exposure.
Hide Signatures
       Post #: 44
RE: Another Custom Camera Mount - 8/2/2007 7:39 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: Sky High
Yes, but my initial tests with the early mount did not show much if any improvement. With the current mount I'm getting about 70% good shots that have no visible motion blurring. With the available camera options, there are around two dozen setting combinations that probably should be tested. I suppose I could set up a Taguchi Design of Experiments but that would remind me too much of my working days......
Mike
Hide Signatures
       Post #: 45
RE: Another Custom Camera Mount - 8/2/2007 9:27 PM
BB_DF
Score: 100
Status: offline
Mike, you're a handful!
Some shots taken today at the Government Training Institute, with the Panasonic FX07, ASA 400. Very overcast/smoky due to numerous fires. The big T-Rex is a crowd pleaser. I got 24 good shots from this session, because when I cherry pick the batch I rename them to letters, and I almost ran out of alphabet!
- Bruce
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 46
RE: Another Custom Camera Mount - 8/4/2007 1:14 AM
geoffff
Score: 100
Last Login: 2/11/2008
Status: offline
How do you lift that much weight with your DF? I can barely lift the 4.2 oz for my little camera. And for that, the DF batteries have to be just recently fully charged up!
-- Geoff
Hide Signatures
       Post #: 47
RE: Another Custom Camera Mount - 8/4/2007 3:33 AM
Sky High
Score: 100
Status: offline
... (Cloudy conditions seemed to make TI mode fly erratic)
I don't know if you were kidding but if not, it is well documented that heavy cloud cover will create erratic flying behavior when using Ti. I wouldn't advise flying at altitude with all of your gear on board when there are heavy clouds. It's not like it will fly erratically only when at altitude though. You'll notice it immediately. However, I have purposefully flown in dense fog too thick to see through and was able to maintain remarkable control.
Hide Signatures
       Post #: 48
RE: Another Custom Camera Mount - 8/4/2007 6:42 AM
BB_DF
Score: 100
Status: offline
quote:
ORIGINAL: Sky High
There's a real art to calibrating the DF. I have two patents for equipment similar to the Ti circuitry, so I have spent a lot of time on the phone talking to the FMA engineers, and also to Mike Dammar, trying to understand how the system really works.
There are a lot of tricks for calibrating the DF, like holding the DF at an angle when you press the arming button, but it's all based on a very thorough knowledge of the algorithms used to determine sky vs. land. The DF can fly over large bodies of water, for instance, if you calibrate it correctly. The main problem that occurs is when the sensors read an abnormal difference in temperature between ground & sky. This can be too great a delta, such as over asphalt, or too small a delta, such as under a heavy overcast.
A general rule of thumb is to try and calibrate it over the coolest patch of land you can find. Thus if the sky is reflecting and retaining a large amount of heat from the earth, you should be able to tell from the green LEDs that the temperature differential is not adequate. My experience: DON'T fly on one LED!
- Bruce
Hide Signatures
       Post #: 49
RE: Another Custom Camera Mount - 8/4/2007 7:51 AM
Old Man Mike
Score: 102
Status: offline
quote:
ORIGINAL: geoffff
-- Geoff
Are you running the HD motors?
Mike
Hide Signatures
(in reply to geoffff)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.563RCU1
