polecat help
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> General Racing Discussion >> polecat help
Page: [1]
Login
polecat help - 6/11/2007 2:49:42 AM
acam37
Status: offline
I recently got this kit from a club member. He got it from a friend who was clearing out his hobby room. I can't find any info about this plane. Is anyone familiar with this kit ? I need some building instructions or at least a little guidance. This is all it came with, and there are no tail plans.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: polecat help - 6/11/2007 5:40:59 PM
daven
Status: offline
Measure the length of the wing (actual wing) , then measure the length of the wing (on the plans), then measure the length of the tail on the plans.
Take the Actual Length of the wing and multiply by the measured tail length (on the plans) and divide by the Length of the wing on the plans. This will give you the length of what the tail should be.
Is there an elevator Joiner included with the kit?
What specifically do you have questions about? There are enough people here that can talk you through each step, looks like most of the hard work is done. It is a nice looking plane.
_____________________________
Dave Norman
klasskote.com
supertrc.com
(in reply to acam37)
       Post #: 2
RE: polecat help - 6/11/2007 5:42:13 PM
daven
Status: offline
Even looks like the firewall may be glued in??
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 3
RE: polecat help - 6/11/2007 6:18:03 PM
acam37
Status: offline
Thanks DAVEN. There are no tail plans to measure. Yes, it does have an elevator joiner, which hooks up inside the fuse. I did find the rudder (which is fiberglass also). The firewall is already glued in and the wing is already sheeted (foam core). It appears the formers are all here. I plan on putting a West .50 with a tuned pipe on this plane, but not sure which way to mount it. The pipe may give me problems. I am not new to kit building, however this is my first fiberglass fuselage.
(in reply to daven)
       Post #: 4
RE: polecat help - 6/11/2007 8:20:53 PM
daven
Status: offline
In your second picture above (the middle one) there is a top view of the plane. Measure the tail on there.
Dave Norman
klasskote.com
supertrc.com
       Post #: 5
RE: polecat help - 6/11/2007 10:13:39 PM
HighPlains
Status: online
Hmm, this is interesting. I think that it may have been designed by Bob Root, since the isometric drawing is nearly identical to the Stinger that Root designed before handing it off to Don Rice. The basic glass work and shape matches up with the Stinger as well, like one was made from the other's plug to make the mold. "SRS" might refer to Bob Smith, his brother and Root, but that's a guess without researching the history. Email Bob at his glue factory and he could surely tell you for certain.
You have an interesting piece of history, and more than likely the molds are long lost. You should have someone splash the glass before building.
The tail would have had around 75 squares with a 15-16" span, of 1/4 balsa sheet.
In politics if you want anything said, ask a man. If you want anything done, ask a woman - Margaret Thatcher
(in reply to daven)
       Post #: 6
RE: polecat help - 6/12/2007 12:03:48 AM
acam37
Status: offline
HighPlains, what does this mean? BTW I will find out the name of the man who initially had this kit. I know he is from the Houston area.
(in reply to HighPlains)
       Post #: 7
RE: polecat help - 6/12/2007 12:18:34 AM
HighPlains
Status: online
Pull a mold of the fuselage before building.
       Post #: 8
RE: polecat help - 6/12/2007 5:00:18 AM
s-10promod
Status: offline
Good looking polecat, I'm taking a break from glassing the wing on a LR1-A as I'm posting this. What do you plan to use for power? I've got a rire K&B and going to add a tuned pipe just to scare the locals at the field! I've got a second LR1-A fuse and cores if you decide you don't want to finish the cat. I'd be interested in buying old F-1 kits or projects anyone else has they want to sell!
       Post #: 9
RE: polecat help - 6/12/2007 5:56:36 AM
acam37
Status: offline
I plan on using a weston .50v1 with a tuned pipe if it will fit. http://www.westonuk.co.uk/index_021.htm
I don't intend to race, just burn holes in the sky.
(in reply to s-10promod)
       Post #: 10
RE: polecat help - 6/12/2007 11:35:24 PM
acam37
Status: offline
What I would really like to see is a good tutorial on finishing a fiberglass fuselage and glassing the wing.
       Post #: 11
RE: polecat help - 6/13/2007 12:01:53 AM
DHG
Status: offline
quote:
ORIGINAL: acam37
It's probably Dave Layman, possibly J.P. Hanway, possibly one of the Cranfill clan. FWIW.
       Post #: 12
RE: polecat help - 6/13/2007 1:06:52 AM
daven
Status: offline
there are quite a few tutorials / posts out there on fiberglassing a wing. This one has some good tips:
http://www.rcuniverse.com/forum/m_5869620/tm.htm
A good resin to start with, is Z-Poxy finishing resin. Especially if your not sure if Fiberglassing is something you may want to do. Its sold in 4 oz bottles for 10-$15. Take a look at your local hobby store.
As to finishing the fiberglass fuze, there is a great tutorial at www.darrolcady.com . One thing about fiberglass fuses is that you want to make sure that the fiberglass is completely cleaned with warm soapy water to remove all mold release and wax before you start working on it.
Dave Norman
klasskote.com
supertrc.com
(in reply to DHG)
       Post #: 13
RE: polecat help - 6/13/2007 2:51:23 AM
acam37
Status: offline
Kieth Frederickson
(in reply to daven)
       Post #: 14
RE: polecat help - 10/13/2007 1:40:58 AM
racer639
Status: offline
I realize this is an old post but I just joined, The kit for the polecat was sold by
bob violet in the mid to late seventies. I am curently building one that I have had since around 1977, I also have another unbuilt kit.
