redvtr1000
GA, USA Status: offline
Dave, I didn't use those servos so I would be hard pressed to give you real facts on the servos and associated hardware. I had issues with the hitecs I used and it required a trip to the lhs. If I remember correctly, something with the 9650 on the tail required me to use a trex ball on the servo end. I think the screws that the mt kit comes with were too small in diameter to screw into the hole of the servo arm. If you have a lhs handy you may just want to get your parts together and make a trip to get the required hardware. I skipped the rubber grommets. When you mount the servos, you may or may not end up shimming them a bit. The mini titan was designed around the Ace C1016 servo from what I have read and the mounting tabs on that servo are positioned further down the case. Using the hitecs, I trimmed a piece of servo horn on the elevator servo and fit it between the mount and the servo. This shimmed the servo forward 3-4 mm and got a nice straight run on the pushrod to the swash, also prevented it from rubbing the fram. I don't know if you will need to do this on those servos but it is something to think about. I think some have gotten by without doing anything in that department but look at yours on a case by case basis. As far as the collars go, I wouldn't bother. I used that trick on my axe cp and it seemed to help a bit but I can't be sure. With the mini titan, I think you would accomplish the same thing by adding in some extra expo to your controls to soften the response around center. The MT is really quite stable, just throw on the training gear and pop it into a low hover and see what you think. If it feels like it is all over the place, and you are overcorrecting, maybe add a bit more expo and try to keep your control inputs very small. The collars won't hurt you if you decide to try em, to find a size that fits, take your flybar to the lhs and get a set of them that go on. Usually four in a pack or so, put one on either side out by the paddles and try it. I can't remember what the exact size I had was or I'd give you more info. It will all be depend on your skill (or lack thereof) but I think you should be okay without the weights. Set it up in per the manual for beginner and not 3d, that reduces your control a bit and I found it to be pretty docile that way.
< Message edited by redvtr1000 -- 2/7/2008 6:47:00 PM >
