RE: Mini Titan thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Mini Titan thread
Page: <<   < prev  13 14 15 16 [17] 18 19 20 21 22   next >   >>
Login
RE: Mini Titan thread - 6/30/2008 3:49:18 AM
redvtr1000
Status: offline
not at all, its about the same size as the air thunder and kong power packs which are only 2200mah packs. The flight power packs are a bit more costly but fly very well imo and you get an extra min or so of flight time.
kinda hard to beat the airthunder packs for value and being able to charge them at higher than 1c. Less time waiting on a pack to finish...
(in reply to redbaron9898)
       Post #: 401
RE: Mini Titan thread - 6/30/2008 6:28:07 AM
smarks
Status: offline
quote:
ORIGINAL: redbaron9898
Thanks for helping guys
I am going to get a logictech 2100t gyro
hs-65mgs
2100mah 3c battery
35A align esc
recomendations on the motor?
Scorpion HK-2221-8 V2. Sweet motor, can't beat it. But upgrade the ESC to a Scorpion 45A.
http://www.innov8tivedesigns.com/product_info.php?cPath=21_25_49&products_id=160
http://www.innov8tivedesigns.com/product_info.php?products_id=45
       Post #: 402
RE: Mini Titan thread - 6/30/2008 2:37:41 PM
redvtr1000
Status: offline
personally, I'd run the stock esc unless you have problems with it. I have one of the early models without the heatsink and it has been trouble free for a full year of flying. Its powering a jgf 500th which is another good choice for motors. It probably falls just short of the scorpion if you ask me (in the power department anyhow) though it is very efficient, lightweight, and runs pretty cool.
My stock esc has at least 500 packs through it and since I programmed it the first time it has pretty much performed flawlessly.
(in reply to smarks)
       Post #: 403
RE: Mini Titan thread - 6/30/2008 5:10:56 PM
redbaron9898
Status: offline
Im already dropping a load of cash on this heli
as long as the stock motor and esc will work through basic 3D it will be good enough for me
what about this for the battery
http://www.amainhobbies.com/product_info.php/products_id/19352
(in reply to redvtr1000)
       Post #: 404
RE: Mini Titan thread - 6/30/2008 5:51:47 PM
smarks
Status: offline
I don't think the stock ESC would work with the Scorpion motor. It requires a 45A ESC and the stock is a 35A I think.
I would be leery of that battery. Many no-name batteries are lower quality, but who knows, it may work fine. But I did notice the max burst discharge is only 30C. Not enough IMO.
I would go with something like this:
http://www.rcheliworkz.com/product.asp?specific=113214
Or this:
http://www.thunderpowerrc.com/html/extreme-V2.html
< Message edited by smarks -- 6/30/2008 5:56:37 PM >
       Post #: 405
RE: Mini Titan thread - 7/1/2008 12:47:33 AM
osterizer
Status: offline
The load on the motor is what defines what the motor needs power-wise, not the motor itself. The Ace ESC will drive the HK2221-8 without a problem. I switched it for a Castle Phoenix 35, but that was just because the governor in the Ace ESC wasn't all that. It works fine with throttle curves, though, and with the 2221-8 on 3S packs you shouldn't push over about 30A or 300W unless you're seriously slamming it around.
       Post #: 406
RE: Mini Titan thread - 7/2/2008 1:10:32 AM
BarnyardPilot
Status: offline
Ok all I am having a problem I cant pin down. Not even close to an expert on these little devils(planker) The last two times I had the MT out I have had the same problem. When in hover it will for lack of a better word jolt. It's almost seems like for a split second it reverses pitch. It doesn't stall like the motor is cutting out it just like burps straight down no yawl and pops back up. The tail is rock solid,blade tracking is spot on, new gears etc. Running stock motor and ESC, GY 201, JR XP662 TX, GWS RX, E75 servos , Align 325's, the head is stock except for the Micro Heli seesaw. Any thoughts would be great.
(in reply to osterizer)
       Post #: 407
RE: Mini Titan thread - 7/2/2008 3:38:30 AM
redbaron9898
Status: offline
sounds like radio interference
(in reply to BarnyardPilot)
       Post #: 408
RE: Mini Titan thread - 7/2/2008 4:01:10 PM
BarnyardPilot
Status: offline
I havn't ruled that out but I live in the country and never had a problem before but it is a possibility.
       Post #: 409
RE: Mini Titan thread - 7/2/2008 5:53:31 PM
redbaron9898
Status: offline
maybe there is a metal on metal contact on your heli that is making some interference
check your heli and see if anything needs to be lubed
       Post #: 410
RE: Mini Titan thread - 7/2/2008 6:23:39 PM
smarks
Status: offline
quote:
ORIGINAL: BarnyardPilot
It doesn't matter that you live in the country, like redbaron mentioned, if there is significant electrical noise being generated in your heli, you will most likely get radio interference.
       Post #: 411
RE: Mini Titan thread - 7/2/2008 10:18:06 PM
BarnyardPilot
Status: offline
Ok thanks for the responses I will go over it again and see what I can find.
       Post #: 412
RE: Mini Titan thread - 7/3/2008 4:04:04 PM
smarks
Status: offline
Quickest, easiest, but most expensive solution is to go 2.4Ghz. Then you can almost always rule out radio interference right off the bat on not worry about airframe electrical noise.
Good luck, hope you can figure it out.
       Post #: 413
RE: Mini Titan thread - 7/3/2008 4:48:55 PM
Roadtorque
Status: offline
Just wondering what it cost you guys to get your heli flyable. I'm looking into getting a mini-titan but would like to know the average cost after completion before I dive into it
       Post #: 414
RE: Mini Titan thread - 7/3/2008 4:53:11 PM
redbaron9898
Status: offline
Roadtorque- You mean starting from scratch?
(in reply to Roadtorque)
       Post #: 415
