RE: Mini Titan thread    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Mini Titan thread
Page: <<   < prev  15 16 17 18 19 20 21 [22] 23 24   next >   >>
Login
RE: Mini Titan thread - 8/2/2008 7:03 AM
noobflyer01
Score: 157
Last Login: 5/21/2012
Status: offline
quote:
ORIGINAL: redbaron9898
this happens in idle up though...
I don't think its the headspeed.
when i am just hovering the tail will shake up and down
have it been crashed? check all shafts. and bearings. check the head for any slop.
i too had the same problem. but after i swapped out blades the vibe went away.
_____________________________
Trex 550e FBL - Scorpion 4025-1100kv -18T , CC ICE100, CC bec pro, Mikado Mini-Vstabi , DS610 cyclic, DS650 on tail.
Hide Signatures
(in reply to redbaron9898)
       Post #: 526
RE: Mini Titan thread - 8/2/2008 7:08 AM
noobflyer01
Score: 157
Status: offline
i went to an empty parking lot today with the mini titan. there was a storm approaching as usuall this time in orlando florida. had lots of gust and 15+ mph winds. that didnt stop me from flying however . i didnt dare to do any flips or rolls in this much wind. just flew taking it easy and enjoying it.
at the 3 minute mark i flew close to the camera for a flyby. awesome!
http://www.youtube.com/watch?v=GsmyMkPAdjU
Hide Signatures
(in reply to noobflyer01)
       Post #: 527
RE: Mini Titan thread - 8/2/2008 9:18 AM
osterizer
Score: 100
Last Login: 2/2/2013
Status: offline
redbaron- please don't take this wrong, but saying that it is in idle-up doesn't mean a lot. If you were talking about a RTF King 2 we'd know what you were talking about, but the MiniT is a bit of a step up, and you can program idle-up a lot of different ways.
Please post the following so we can think about it:
- motor brand and model
- pinion you're using
- ESC model and what you've set
- transmitter type, and throttle and pitch curves
- battery brand and model
The symptoms you're describing are a little complicated to sort out, so the above information will make it clearer. I may not be the guy with the answer, but that info may strike a chord with one of us.
Thanks.
Hide Signatures
       Post #: 528
RE: Mini Titan thread - 8/2/2008 9:19 AM
osterizer
Score: 100
Status: offline
quote:
ORIGINAL: noobflyer01
cool.
Hide Signatures
       Post #: 529
RE: Mini Titan thread - 8/3/2008 12:51 AM
redbaron9898
Score: 100
Last Login: 4/16/2013
Status: offline
I am using:
align 430L motor
align RCE-BL35X speed control medium response
13t pinion
2150 mAH battery 20c
DX6i transmitter
idle up pitch curve: 20...40...50...60...80
Hide Signatures
(in reply to osterizer)
       Post #: 530
RE: Mini Titan thread - 8/3/2008 2:06 AM
osterizer
Score: 100
Status: offline
I'd start by checking that the dampers are OK, and then try raising the throttle curve.
Hide Signatures
       Post #: 531
RE: Mini Titan thread - 8/3/2008 7:50 AM
noobflyer01
Score: 157
Status: offline
had a major crash today with mini titan. main gear, rotor head, skids, feathering shaft, main shaft, tail fin, bottom base. . about 130 bucks worth of damage. crashed coming out of a roll. i did way too low and hit the ground coming out. to be honest it wasnt flying that great. the cost of repairs is about the cost of a new kit. . i dont think i'm going to repair it. gonna get a new bird instead. all electronics survived the crash. . after all the different helis i have flown in these short months the EXI 450 at 99 bucks is by far the easiest and smoothest heli i have flown. flips and rolls are crisp and clean. i will either get the all metal version of exi 450 or the trex 500. i would like the trex 500 but the electronics requirement for that heli is really steep. since i can get a trex clone setup in 3 hours i'm gonna strip the titan and transfer eletronics into the exi.
Hide Signatures
       Post #: 532
RE: Mini Titan thread - 8/3/2008 10:40 AM
redbaron9898
Score: 100
Status: offline
my throttle curve is 100...90...80...90...100
Hide Signatures
       Post #: 533
RE: Mini Titan thread - 8/3/2008 9:16 PM
osterizer
Score: 100
Status: offline
You're running me out of ideas here . I'd still be looking for something sticking or loose in the head, though, starting with the dampers (o-rings) and making sure the bearings in the grips are in the right order/orientation.
Hide Signatures
       Post #: 534
RE: Mini Titan thread - 8/5/2008 9:51 PM
redbaron9898
Score: 100
Status: offline
I just checked the dampers...they still are pretty firm.
It only really happens when i do a hard manuver where i move the stick all the way to one direction.
I just crashed it pretty bad... so hopefully when i rebuild it i can find the problem
Hide Signatures
       Post #: 535
RE: Mini Titan thread - 8/6/2008 4:30 AM
osterizer
Score: 100
Status: offline
Oh, my, important bit of info there . When you're putting things back together, disengage the motor from the spur gear so the head/main/tail turn freely. While you're gently turning the shaft, move the cyclic through all directions and make sure it isn't binding up. With the stock head, it's easy to put too much cyclic travel in it, and in extremis, you can impact the grips with the linkages and tear up servo gears.
Hide Signatures
       Post #: 536
RE: Mini Titan thread - 8/7/2008 4:43 AM
Crossfade
Score: 100
Last Login: 4/3/2013
Status: offline
I still have not fixed my tracking problem and it's still bad enough to keep it grounded, i have inspected everything and i have found that there is a good amount of slope in the stock swashplate i wonder if this is my problem, i have also been told i need to glue my outter bearing races in the main shaft becuz the whole bearing as been know to spin and wear the plastic which creates even more slope and a vibration which i also have.
I think i may just glue my main bearings and upgrade to the assembled cnc head for $104
http://www.cnchelicopter.com/servlet/the-1009/Mini-Titan-E325-CNC/Detail
< Message edited by Crossfade -- 8/7/2008 4:44 AM >
Hide Signatures
       Post #: 537
RE: Mini Titan thread - 8/7/2008 8:03 AM
osterizer
Score: 100
Status: offline
Sorry there's still a problem there. The swash is always going to have some play in it, but unless it's really excessive it shouldn't cause a tracking problem. If the bearings are loose enough to cause that, you should be able to tell by wiggling them- if they're flopping around from wear, then that would definitely be a problem.
quote:
ORIGINAL: Crossfade
Hide Signatures
(in reply to Crossfade)
       Post #: 538
RE: Mini Titan thread - 8/7/2008 11:11 PM
smarks
Score: 100
Last Login: 5/17/2013
Status: offline
quote:
ORIGINAL: Crossfade
Nice find on the head. Wonder how it compares to the Kasama head? They have some nice CNC stuff if it all fits without modification.
www.Smart-Fly.com
www.mksservosusa.com
Hide Signatures
       Post #: 539
RE: Mini Titan thread - 8/8/2008 9:58 AM
GRR_Mojo
Score: 100
Last Login: 6/29/2009
Status: offline
I have this one and I like it http://www.cnchelicopter.com/servlet/the-895/Mini-Titan-E325-CNC/Detail
Will these bearings work for the main https://www.helidirect.com/advanced_search_result.php?keywords=5x11x5&osCsid=92e28d4a4719af3b6c96b78b99af4212
Hide Signatures
(in reply to smarks)
       Post #: 540
RE: Mini Titan thread - 11/5/2008 6:03 AM
Guizmo17
Score: 100
Last Login: 2/10/2009
Status: offline
Alright. I've started this thread and some months ago I left a bit the hobby because I had a bit of a .... finatial problem. But now I'm back on ! I just want to know between 2 Gyros and 2 servos witch one is the best
SERVOS :
1. Futaba Digital Rudder Servo S3153
2. Maxwell MX65 Metal Gear Digital Rudder Servo
GYRO :
1.Futaba GY240 Head Lock Gyro
2.Gaui Gyro GU210
2 Combos witch 1 is the best ?
1.Gaui Gyro GU210 , Maxwell MX65 Metal Gear Digital Rudder Servo
2.Futaba GY240 Head Lock Gyro , Futaba Digital Rudder Servo S3153
So.. what do you thing ?
Hide Signatures
(in reply to GRR_Mojo)
       Post #: 541
RE: Mini Titan thread - 11/5/2008 6:52 AM
osterizer
Score: 100
Status: offline
I don't think I ever tried a 3153 on the tail (used a 9257)- I have them on the swash, though, and they're very sturdy and precise for that, very good stuff. It'd probably work fine on the tail.
If you're looking at a Futaba gyro, I'd suggest kicking in the extra and getting the 401; the remote gain control is extremely useful.
Hide Signatures
(in reply to Guizmo17)
       Post #: 542
RE: Mini Titan thread - 1/15/2009 1:53 AM
3d-wanna-b
Score: 100
Last Login: 1/15/2013
Status: offline
Well I just joined the MT club... Hope I made a good choice. Seems to be a lot of people that like it. What's this I hear about having to glue bearings?? that part makes me wonder about my choice in birds as I hate to have to modify something that shouldnt need to be.
Hide Signatures
       Post #: 543
RE: Mini Titan thread - 1/17/2009 8:32 PM
smarks
Score: 100
Status: offline
I have the ARF and didn't need to glue any bearings. It's a great heli, I love mine!
www.Smart-Fly.com
Hide Signatures
(in reply to 3d-wanna-b)
       Post #: 544
RE: Mini Titan thread - 1/19/2009 10:00 AM
3d-wanna-b
Score: 100
Status: offline
quote:
ORIGINAL: smarks
Thats good to hear... I hate to have to mod stuff that I realy shouldnt have to. I'm sure I'll love the heli also, it will be a big step up from my Axe CPv3.
Hide Signatures
       Post #: 545
RE: Mini Titan thread - 1/19/2009 6:50 PM
noobflyer01
Score: 157
Status: offline
check out this mini titan clone here. all metal head and tail.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 546
RE: Mini Titan thread - 1/20/2009 5:44 AM
Guizmo17
Score: 100
Status: offline
Where did you find that ?!?. Is there clones on Mini Titan like the T-rex 450 clones ?
Hide Signatures
       Post #: 547
RE: Mini Titan thread - 1/20/2009 7:00 AM
noobflyer01
Score: 157
Status: offline
i got this for 120 bucks during xheli's xmas sale. this is the only mini titan clone that i know of. i also have a genuine mini titan e325 and this clone just blows it away. carbon frames, metal head and tail, carbon blades.
Hide Signatures
       Post #: 548
RE: Mini Titan thread - 1/20/2009 7:34 AM
osterizer
Score: 100
Status: offline
Depends on what you're after. I don't like flat plate carbon frames, and I pick my own blades. It looks like a very nice heli, but it wouldn't be for me.
Hide Signatures
       Post #: 549
RE: Mini Titan thread - 1/20/2009 6:12 PM
noobflyer01
Score: 157
Status: offline
Os. if you like the mini titan i think you would like this. feels extremely solid. it shares the same feathering shaft, main shaft, flybar, dampners, etc...with the mini titan. the main gear is compatible with trex 450. boom and all tail parts are compatible with mini titan. only thing difference is the frame. design is different. its more narrow. i'm very pleased with it.
< Message edited by noobflyer01 -- 1/20/2009 6:13 PM >
Hide Signatures
       Post #: 550
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.984RCU1
