redvtr1000
GA, USA Status: offline
I have a "feeling" that Barracudas review is pretty good stuff. Lots of detailed setup info explaining the little details/issues you will come across during the build. Devens: I shimmed the elevator servo forward a bit (I think you only need to do this with hs-65s as the mini titan was designed to accept ace's 1016 servos if I remember right. The two aileron servos I left alone, some have shimmed them but save the work it works fine without doing so. If you use the s9650 you will either have to use the Align ball and link on the servo (stock mini titan rod and ball/link on the tail rotors slider is fine). The s9650 servo horns have holes in them that are too large for the mini titans hardware to thread into. Or, you can do a little grinding work on the back of the futaba horn and attach a piece of horn cut off one of the extras from your hs-65s and attach it by using it as a plate behind the 9650. Most have used the round wheel from the 9650, I used the regular 4 way horn and cut off all but one of the tabs. Threw on an align ball and it was good to go.
