osterizer
MD, USA Status: online
So how many stories on RCU start, one way or another, with "the sun was going down, and it was really time to leave, but I figured I had time for One More Pack?" I almost had one of those for you folks tonight, but thankfully, not. I had the MX450 (3S) out today to the field, but the wind was all over the place and I gave up after 4 packs. Later in the day, though, the wind died down and I took the Titan and went back. I flew two packs through it and had a ball. It really is that good-- FFF, backwards flight with rock solid tail, and flips and loops track perfectly. I even landed nose-in just because it was so easy. I only had one issue, and that was that at one point it seemed to mush a little bit and then snap back when I went from neutral to positive collective. Strange, I thought, but it flew perfectly otherwise and I kept going. Mistake! So, I was thinking, I should go home, but I had One More Pack . Took it up, flipped to idle up, did one flip, OK, did another, and BLAM, passing through inverted I blipped negative collective and it jerked like someone hit it with a hammer! I rolled it back upright and flipped back to normal to drop the head speed in case it went out of control, but I was at about 60 feet so I figured I had a little time. I wiggled cyclic a little bit to see if I wanted to just plant it or fly it back, and it responded OK so I flew it back and set it down, smoothly as if nothing had ever happened. I disconnected the battery, and started wiggling arms in the head to see if something was sticking; nope. Grasped the grips and turned them gently, just a little toward positive pitch to see if anything wiggled- snap!, and the port front servo stopped providing any resistance at all and just swung back and forth freely. O... M... G.... Just dodged a bullet, compadres, but don't know what kind it was-- whether the servo was going bad, or if that last snapping was a head part binding up and the shock when it let go stripped the servo. Either way-- there's a new set of gears and a careful going over for the servo, and whether it's Kasama or I get the TT allie head I asked for for Christmas, next time it flies it's with an aluminum head. I was spinning 2800+, and I know better than to do that with plastic, but it worked really well so far so I went with it. Still does, for that matter-- hover with a stripped cyclic servo was still smooth . But let's not try that again......
< Message edited by osterizer -- 12/24/2007 10:14:01 PM >
